Question about Bh Fitness G637 Explorer Evolution Folding Treadmill
How to choose Stabilizer
I recently bought BH G6448E treadmill with 1200W I would like to know about suitable stabilizer pls give details about maintenance also
How to calculate the stabilizer rating for my new BH-6446E tread mill
Posted on Oct 03, 2010
Pool stabilizer
Their are no test kits available for residential home owners. Wherev you can take your water sample to will be able to test for cyanaric acid(stabilizer). They will give you the value to add to the water. Follow the instructions on the stabilizer container to add the amount based on the water volume you have for your pool. Most recommend adding it into a stocking and hanking it from the ladder or inside the skimmer to allow for slow dissolving
Jun 28, 2013 | Arch Chemical HTH Pool 4 LB Stabilizer &...
LG lcd 26 inch
No,
because stabilizer have power wattage rate you can't exceed to that giving wattage or else the stabilizer got burnt you can only use one appliance on one stabilizer or you buy more higher wattage to connect more than one appliances but be sure not more than to the given wattage of stabilizer..
Dec 16, 2011 | LG Televison & Video
A friend recently gave me a ProForm 700 treadmill that folds up & the front left side of what appears to be the belt or possibly the rotor sounds like dolphins talking when you turn it on. How can I...
dEAR Sir:
I will help you inmediately.
HOW TO LEVEL THE ELLIPTICAL CROSSTRAINER:
After the elliptical
crosstrainer has
been moved to
the location
where it will be
used, make sure
that the ends of
both stabilizers
are touching the
floor. If the elliptical
crosstrainer
rocks slightly during use, turn one or both of the leveling
feet under the front stabilizer until the rocking
motion is eliminated.
2) You must put a little oil ( tree in one oil) +a little grease in the rotor shaft.
Hoping that you fix this, anyway if you need some extra help, contact me.sincerely.
blessing.
E.CUADRA
Managua, Nicaragua C.A.
Sep 13, 2011 | Proform CrossWalk TreadSoft Treadmill
Can't find the serial number -- there is no tag or it has been removed. It's a precor efx 546, MANUAL not electric and I either need a new battery or a battery charger. What do I do without the serial...
Precor Serial # Locations Type of Unit Serial # Location Treadmills Located on the label near the power cord entry and on the frame under the left rear of the treadmill. Upright Bikes Located on the front stabilizer. Recumbent Bikes Located on the front stabilizer. Ellipticals Located on the front stabilizer. Stair Climbers Located on the bottom side of one of the foot pedals. http://www.sportsmith.net/
Jan 22, 2011 | Precor EFX 546i Elliptical Version 4
Remove and replace Front Sway bar
Hello ggagne.
Here is the procedure.
  1. Raise and suitably support the vehicle.
  2. Remove the left tire and wheel assembly.
  3. Remove the pinch bolt from the lower intermediate steering shaft
  4. Loosen all insulator clamp attaching bolts.
  5. Place a jack stand under the center of the rear frame cross member.
  6. Remove the rear frame-to-body bolts.
  7. Lower the rear of the frame just enough to gain access to the stabilizer shaft.
  8. Remove the insulator clamp bolts and the clamps from the frame.
  9. Remove the insulators from the stabilizer bar.
  10. Remove the stabilizer bar links from the control arms.
  11. Pull the stabilizer shaft rearward.
Installation
  1. Insert the stabilizer shaft to the left side of the vehicle. Important: DO NOT tighten the stabilizer link nut at this time. The weight of the vehicle must be supported by the control arms such that you can obtain the vehicle design trim heights before tightening the link nut.
  2. Loosely install the stabilizer shaft link at the control arm.
  3. Install the insulators on to the stabilizer bar.
  4. Connect the insulator clamps to the frame.
    • Tighten the stabilizer shaft bracket bolts to 48 Nm (35 ft. lbs.) .
  5. Raise the frame into position while you guide the steering shaft onto the gear.
  6. Install the new frame-to-body attaching bolts.
  7. Remove the jack stand.
  8. Install the pinch bolt and tighten.
  9. Install the left tire and wheel assembly.
  10. Lower the vehicle.
  11. Support the weight of the vehicle by the control arms.
  12. Tighten the stabilizer link nut.
    • Tighten the stabilizer shaft link nut to 23 Nm (17 ft. lbs.)
There you are, I hope your job goes well.
Thank you for using FixYa.
KL
Nov 13, 2010 | 2002 Buick Century
Closed player without stabilizer.
I dont know this player, but you can unscrew the top of the housing and look if you can see the CD tray. Just giving a shot.
regards,
Gerard
Jan 11, 2010 | Sony CDP-XB930 CD Player
Front Sway bar(Stabilizer bar)
please give good rating if this helps
Section 04-01: Suspension and Wheel Hubs, Front 1996 Taurus, Sable Workshop Manual REMOVAL AND INSTALLATION Stabilizer Bar Removal
  1. Raise vehicle on a hoist. Refer to Section 00-02 .
  1. Support vehicle with hoist or safety stands behind front sub-frame (5C145).
  1. sth~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Use extreme care not to damage boot seal. Do not use power tools to tighten nut, or bearing and seal damage will result. Install nut using hex hold feature to prevent the stud from rotating.
    Remove and discard nuts retaining stabilizer bar link (5K484) assembly to front stabilizer bar (5482) and front shock absorber (18124) with an 8 mm closed-end wrench and an 18 mm open-end wrench.
  1. Remove nuts retaining steering gear (3504) to front sub-frame, and move steering gear off the front sub-frame.
  1. With another set of support safety stands under front sub-frame, remove two rear subframe retaining bolts. Lower rear of the front sub-frame to obtain access to stabilizer bar brackets (5486).
  1. Remove front stabilizer bar U-bracket bolts and replacestabilizer bar brackets and/or front stabilizer bar as required. Discard lower suspension arm stabilizer bar insulator (5493) and bolts.
Installation
  1. Clean front stabilizer bar to remove dirt and contamination in area of stabilizer bar insulator installation position.
  1. Lubricate inside diameter of new lower suspension arm stabilizer bar insulator with Rubber Suspension Insulator Lube E25Y-19553-A or equivalent meeting Ford specification ESF-M99B112-A. Do not use any mineral or petroleum based lubricants as they will deteriorate the rubber lower suspension arm stabilizer bar insulators.
  1. Install new lower suspension arm stabilizer bar insulators onto front stabilizer bar and position them in approximate location.
  1. Install stabilizer bar bracket on front sub-frames and install new bolts. Tighten to 30-40 Nm (22-29 lb-ft).
  1. Raise front sub-frame and install new front sub-frame-to-body retaining bolts. Position steering gear onto front sub-frame and install retaining nuts. Tighten to 115-135 Nm (85-99 lb-ft).
    Install stabilizer bar link to front shock absorber and to front stabilizer bar, making sure that the stabilizer bar link is properly positioned. The letters "Top LH" and "Top RH" are moulded into the stabilizer bar link for correct assembly to the front shock absorber strut.
  1. Install new nuts and secure stabilizer bar link assembly to front stabilizer bar and front shock absorber. Tighten to 77-103 Nm (57-75 lb-ft) at front shock absorber strut and 47-63 Nm (35-46 lb-ft) at front stabilizer bar.
  1. Remove safety stands.
  1. Lower vehicle.
Apr 11, 2009 | 1995 Ford Taurus
Embroidery machine patterns are not consistant
I'm just beginning to work with my machine, but I have had a similar issue. Some of the possible solutions that I have found include (note: I've tried #1, I will try 2 and 3 soon)...
1. use stabilizer fabric.
2. if you're using tear-away stabilizer, and it is tearing prematurely, try a cut-away stabilizer (or maybe iron-on stabilizer?).
3. if you're embroidering on fabric like fleece, try 'hoopless embroidery' This involves using adhesive stabilizer - put the stabilizer in the hoop with no fabric, (if you don't have adhesive stabilizer, use regular stabilizer and spray it with a craft adehesive) then lay your fabric over the hoop and press the fabric onto the adhesive.
good luck.
Dec 17, 2008 | Brother SE-270D Computerized Sewing...
Stutters
These types of faults can be in the motor, motor drive, controler, or in the velocity sensor (external or internal). If you call the manufacture, they should have statistics on the parts that fail most frequently. They would be the best guide to use for finding out what parts to order. You may have to try a number of parts to find out which one is actualy defective.
Jerry G.
Nov 01, 2008 | Bowflex Treadmill Series 7
Bh Fitness G637 Explorer Evolution Folding Treadmill Logo
597 people viewed this question
Top Bh Fitness Exercise & Fitness Experts
Shehu Pro
Shehu Pro
Electro Med Services...
Tom Chichester
Are you a Bh Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
