Question about LG WD-3243RHD Front Load Washer / Dryer
Change drain hose
Main drain hose is broken.I have new .
It is easy to change or i need service?
thanks
Eddie
    Genius:
  • LG Master
  • 1,474 Answers
Should be quite simple to do Eddie. Its secured by a clip onto the pump outlet undo this fit new hose resecure .Fully Watertest before use ..
Posted on Jun 04, 2010
Alternator belt snapped twice. It squeels really bad at times i have no idea what im doing wrong. Easy to put it but keeps ripping apart. Also bought new alternator and same problem still persists.
Hi, Eddie there are 3 main reasons a belt will shred
1. Tension to tight.
2. Pulleys out of alignment.
3. Contaminated or damaged pulleys.
For more information about your question and valuable free downloads that you will need please visit the websites below. Good luck and have a nice day.
http://www.kawasaki-rider.co.uk/phpBB3/viewtopic.php?t=6200 Kawasaki Motorcycle Service Manuals
Kawasaki Belt Change 3gp
Feb 25, 2016 | 1987 kawasaki GPX 750 R
Ge washing machine will not drain
Drain by lowering main drain hose below pump into shallow bucket, remove front lower panel , take large hose off back of pump clean out hose, may have to take 2 screws out of pump mount to look in pump mine was being stopped by a nail,the$6.75 in change was still in the hose
Jan 23, 2013 | GE Wsxh208a1ww Front Load Washer Washing...
Washing machine leaks during spin and drain cycle
If the leak is still present after you replace the hoses , you may need to get a new water pump ( cheap part ) it is probably leaking , it removes the dirty water from the washer during spin and rinse cycle . hope this helps
Jun 28, 2012 | Washing Machines
Our washing machine was not daring fully. My partner had examined for a blockage in the drainage pipe and found two semi circular steel rods. After taking them out the plug fuses on the mains shortage when...
There are several reasons that a washing machine won't drain or spin. The cause could be something as easy as a clog or something difficult that will need a licensed repairman. Start with the simplest possible cause and work down to the more difficult causes.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); });
Tools Needed
  • Screwdrivers,Flashlight,Voltmeter,Wrenches,Bucket,Rags or mo.
  1. A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
  2. If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
  3. Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car, lawn mower or even a bicycle chain should be able to accomplish the task.
  4. Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
  5. If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall
Hope this help?
Thanks.
Dec 04, 2010 | Hoover Washing Machines
Squeaks when tub changes direction during wash cycle
Hi
Thanks for using FixYa. The squeaking sound comes when the belt that has gone bad and to resolve this it should be replaced. Please check this video on how to replace the belt in dryer. Also check the tensioner pulley and replace it. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 17, 2010 | Whirlpool WTW6600SW Top Load
Does everything but drain
Look for a blockage or a kink in the drain hose.
Some washers will also have a valve and pump on the drain line independent of the main drive. Due to high vibration of the washer, it is not uncommon for wires to come off here.
Checking the drain hose for kinds is easy, just have to look at it and see if there are any sharp bends and such. To do the rest, you are going to have to drain it using expedient methods. Try taping a garden hose to the end of the drain hose, roll the garden hose outside. Lower the drain hose to the floor. If the washer starts to drain with a pretty good flow (washer should be turned off at this point), then you likely don't have a valve on the drain, but the pump isn't working for whatever reason. Let the washer drain as much as it will, remove clothing, and turn the washer over onto its front side.
Remove the bottom cover (if present), and follow the drain line back to the pump assembly. If you have a pump near the drain connection, check its wiring (unplug first) to make sure everything is tight. If the drain line goes to a pump that is driven off the main motor, then the impeller is damaged or coupler is broken.
Most washers will drive the water pump off the same motor that turns everything else. To avoid draining during wash cycle, the main motor will turn in reverse to engage the water pump. If the coupler is damaged, it is able to still run through cycles normally, but can't turn the water pump. The opposite is also true, if it is able to drain, but can't spin or agitate.
Jun 13, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer does not drain after rinse cycle
Hi
Thanks for using FixYa. Usually water not draining at all is due to the drain line that is clogged and/or because of kinked drain hoses that’s attached to the Drain Pump. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. If you think that this isn't easy to do--and you may need special tools—then you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump. Please do rate the solution and revert for further assistance.
Thanks
Rylee
May 08, 2010 | Whirlpool GHW9200L Front Load Washer
My GE Profile washing machine will not drain at all , it washes fine but does not drain Model # S3200YIWW
It possible something is jamming pump impellor, like a coin or hair pin, or pump itself is seized, or impeller is broken or loose.
Remove front panel, there are two clips in between front panel and top that you have to push in with metal putty blade or thin slot screw driver while pulling front panel away on either then pull up from bottom clips. Shop vac water from machine clamp off hose going from tub to pump.
Lean machine back if poosible so remaining water goes to back of tub, remove hoses, remove wiring to pump.
Unscrew pump from base observe inside ports for objects or broken or seized impeller on shaft if there things in pump remove them reatach wires put machine to drain or cancel and see if pump impellor turns freely, if so reassemble and try, otherwise buy new pump. Not very expensive.
Hope helped.
Nov 17, 2009 | Washing Machines
Dishwasher stops after 10 minutes inlet/drain light flashing
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
May 31, 2009 | Miele 24 in. G646SC Plus Free-Standing...
LG WD-3243RHD Front Load Washer / Dryer Logo
67 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
