Question about Bosch Dishwashers
Model shu9915 has water supply but no voltage at fill valve
  • 6,784 Answers
Hi. This inlet valve assembly may be damaged. Use this quick testing procedure to confirm.
There are two wires (four, if it has two solenoids) connected to the water inlet valve. Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals. You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced. Use a multimeter to test for continuity. Set the multimeter to the ohms setting X1. Touch one probe to each terminal. A reading of infinity indicates a bad solenoid that must be replaced. Different brands and models will have various measurements, but the valve should show some resistance if it is functioning properly. If your valve has two solenoids, test the second one in the same way as the first.
  • Note_ If the valve proves to be functional, this will lead to a faulty control sector. Possibly a bad wiring connection at the valve or control board.
Posted on Jun 04, 2010
Mine DU1055XTSS3 is not taking on water after initial rinse.
test this steps and fix it. GOd bless you
Water Inlet Valve
The dishwasher has an electrical water valve called a water inlet valve. If the dishwasher won't fill with water, the water inlet valve might be defective. These valves are not repairable and will have to be replaced.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Float
The float assembly is normally inside the dishwasher near the door on the floor of the dishwasher. If something gets stuck underneath it and holds the float assembly up, the dishwasher won't fill with water. If the float assembly moves freely up and down, the float switch might be defective.
Float Switch
The float switch is actuated by the float assembly. It is a protection device designed to prevent the dishwasher from overfilling. If the dishwasher won't fill with water, it may be because this float switch is defective or stuck.
Water Supply Problem
The dishwasher is connected to the hot water supply from the house. Check to be sure the household water supply valve is turned on. Over time, calcium deposits can build up in the water supply valve or in the small filter screen inside the water inlet valve. The water supply line may need to be removed from the water inlet valve of the dishwasher, then run some water into a bucket to see if there is enough pressure. Be certain to turn off the water before working on the water line.
Jul 30, 2013 | Dishwashers
Does not fill with water.
follow this steps and fix it. God bless you
Water Inlet Valve
Float
Float Switch
Jul 08, 2013 | Thermador 24 in. DWHD64CS Stainless Steel...
Kenmore 17621 model--wife says it's making all the right noises,but no water entering.removed bottom panel-no filter visible.obstruction in water supply line is my guess.
Open the door and look for the water level float in the bottom of the dishwasher.
Make sure there is nothing stuck under the float holding it in the up position.
Wiggle the float up and down to make sure it can move freely and then run the dishwasher again to see if it fills with water.
If the float is not stuck up then chances are you will need to replace the water inlet valve.
If you know how to use a volt meter you could check to see if voltage is at the valve during the fill cycle. If there is voltage to the valve but you are not getting any water then you know the water inlet valve is bad for sure.
I find that 90% of the time I need to replace the water valve on dishwasher that no longer fill with water and the other 10% of the time I find the water float is stuck.
Aug 07, 2011 | Kenmore Dishwashers
Kenmore model 70 series 110.82673810 Will not fill or agitate. It will drain and spin
Hello, Thank You for using FixYa. I will be helping you today.I would start by disconnecting the water supply hoses and making sure the screens are clean and clear and while the hoses are off flush the in a bucket to make sure your getting water. If the unit is not filling it wont agitate either. If the water supply seems ok you will have to check for voltage at the fill valve.
Thank You and please ACCEPT my answer and Rate my answer if it was helpful..
Jul 02, 2011 | Washing Machines
My GE Model GSS201ETA, Serial # VL204167 does not dispense water. The ice maker works good. There is no water filter for this model.
I would start by making sure there is water going to it. If so it could possibly be the fill valve is bad. I would first volt out the vill valve supply plug just to make sure it is getting voltage when in use. If so I would recommend replacing the valve itself.
Mar 24, 2011 | GE Refrigerators
Hi my bosch washing machine is leaking water from underneath, in fact when you turn the water tap on, it sounds like it is filling up, but the machine is not even plugged in.
Welcome to FixYa.
Based on your description, " machine is leaking water from underneath... it sounds like it is filling up, but the machine is not even plugged in "... the issue is likely with the inlet/water valve.
**To remedy this you will need to replace the valve, not surprising for Bosch unfortunately**
This is what to look for..i.e.
As long as your model number is indeed SHU9915 series, this info below will be accurate.
I say not surprising because this part has been an issue for the B/S/H/ built machines in the past and as a result the original part number 189553 now substitutes to 425458. It usually retails for about $20 - $30USD at places such as "searspartsdirect.com" "repairclinic.com" to name a couple.
**Before attempting to repair the unit please turn off the power and the water supply to the dishwasher...safety first**
If you remove the lower kick plate/toe panel, you will see the inlet valve to your left...
i.e.
Replacing it is pretty straight forward. Here`s how...
1) undo the water line.
2) the two #20 torx screws fastening it in place.
3) the feed tube to the machine at the back of the valve and swap it with the new one.
and
Once the new one is in you should be good to go.
Let me know if you need any further assistance, otherwise good luck.
Thanks for visiting FixYa.
Regards,
Macmarkus :)
Nov 08, 2010 | Bosch SHU9915UC Dishwasher
My front loading washer always fills with water when i am not using it
It sounds like one of the automatic water fill valves in the machine is leaking water when washer is off and the valves are closed. There are two manual water supply valves at the wall behind the washer, one for hot water and one for cold. Close the manual hot water supply valve and allow the washer to sit and see if it fills with water. If it does fill, then the cold water automatic fill valve is leaking. If not, then open the hot water manual supply valve and close the cold water manual supply valve. Allow the washer to sit again and see if it fills. If it does then the hot water automatic fill valve is leaking. Replace the leaking valve in your washer. You can order the new valve online using washer brand and model number on a appliance parts web store, or maybe even find it at a local appliance parts store.
May 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Maytag performa PAV2200 - cold water fill does not work, but hot does
Check the solenoids at the water inlet valve. They can be checked using a multimeter or ohm meter for continuity. If either solenoid has none, it is defective and the water inlet valve assy will need to be replaced. I am attaching a photo for reference. Hope this helped and best wishes.
Aug 04, 2009 | Maytag Performa PAV2200
LAT7300AAW Model washer will not fill with water , only spin then shut down as a comp[letion of a normal washing load .
First ensure that water is flowing regularly through the inlet hose. Check the water supply at the back of the machine.
If you find nothing in there, then the thing to do is accessing to the inlet valve and testing it.
Also test and eventually replace the water level membrane switch.
The inlet valve is tested by reading voltages, reading continuity, and physically checking if it is closed.
If it turns out that inlet valve is fine, water level is fine, there is no blockage and water supply is fine. Then only in that case test and eventually replace timer board.
Click here to access all the spare parts and diagrams for your model.
Apr 16, 2009 | Maytag Washing Machines
No water in dishwasher
You need the check the water level switch which is located on the diaphram of the water fill assembly. This is located on the laft side of your machine behind the metal panel. if this switch sticks it will not allow water into the machine
Mar 03, 2007 | Bosch SHU9915UC Dishwasher
Dishwashers Logo
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
