Question about Garden
After start mower wont run unless I press the primer bulb
My craftsman lawnmower model #917-376741 won't run, after starting, mower won't run unless I press the primer bulb continuosly
    Problem Solver:
  • 8 Answers
I got exasperated (sp?) with this happening on my last two mowers. New gas, spark plug, filter, etc. Ran fine for 10 minutes, then wouldn't run without the primer bulb being pushed in. In desperation, I wiped off the gas tank filler neck, put my mouth over the whole thing, and blew like h*ll. Now I couldn't say whether the mower got excited or what, but it started right up and ran fine (long enough for me to finish the front lawn). After all my frustration with this thing, I'm still kinda laughing at the fix, even if it's not long term.
Posted on Jul 02, 2014
  • 177 Answers
Carby service maybe required
Posted on Jun 07, 2010
Craftsman lawnmower wont stay running
Michael it sounds like there may be a blokage on you air filter. Check it and clean it then make sure there is not too much oil in the mower.
Jul 18, 2013 | Garden
Craftsman tiller won't start unless I manually prime cylinder with gas. There is no primer bulb. Can I retrofit a primer bulb in the gas line?
Hi
You can insert a primer system into your fuel system
Just follow the fuel flow below
Please take time to rate me
Bud
Oct 23, 2012 | Craftsman Garden
Lawnmower won't start. There is no primer bulb,supposed to start on first pull
Do you have fresh gas? Make sure the choke on carb is working, maybe drain the gas out of carb and or clean it out, check for spark
Aug 19, 2012 | Snapper 20 HP Lawn Tractor 2690578
My lawnmower starts up and shuts right off
check for fuel flow the needle valve might be hanging up not allowing enough fuel if its just runs form pushing the primer bulb the whole car might need cleaning
Apr 18, 2012 | Craftsman Garden
Hi, I have a Craftsman lawnmower, sel propelled, over 10 years old. It doesn't seem to start unless I spray gasoline into the carburetor. Also, it will only keep runnning if I continue to spray into...
the Primer bulb most likely has a crack in it. If it does then there won't be sufficient suction to draw in the fuel. Also, if you remove the carburetor, separate the upper and lower halves so you can get to the fuel bowl, check that the float needle isn't sticking inside the hole. Look for dirt and other contaminates.
Do you by chance have the model # of the mower? It will be in the following format: XXX.XXXXXXX The model # sticker is usually located on the deck behind the engine. And what HP is the Engine? (It should be a Briggs and Stratton.
May 27, 2011 | Garden
I BOUGHT A BRAND NEW TORO LAWNMOWER, MODDEL 20330,
don't waste time looking for the primer bulb. probably wont work anyway if its over 6 months old and repairs probably wont do any good either. bad design for a primer system.
Apr 08, 2010 | Toro Lawn Mower With Toro Power Tools
Lawn mower will not start and run
Sounds like a clogged carb or a cracked primer bulb. I would install a carb rebuild kit and new primer bulb if your mower uses one.
May 18, 2009 | Craftsman Garden
Wont stay running without pushing primer
Hi... I have a Poulan PRO Quantum xnp 6.75. Garage kept, unused approximately 2 yrs. Added fuel, primed & mower started but then shut down immediately. Then fuel began leaking from the primer button. I'm a single mom & CANNOT afford to have anyone fix this. However I am attempting to repair myself. PLEASE.... If you have any suggestions &/or solutions I would LOVE to know.
Apr 12, 2009 | Garden
Push mower runs then quits!!
My toro mower starts and will run for ablut 15 minutes and starts to cut out and eventually stop running. What could be the problem
Apr 01, 2009 | Craftsman Garden
Garden Logo
677 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
