Question about Bosch 24 in. SHU43 Built-in Dishwasher
Dishes do not get clean.
There is a film of dust like material after each cycle
  • Bosch Master
  • 43,501 Answers
Nasty white residue left on dishes at end of cycle, and dishes not cleaned
The ****, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and **** in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101
Aug 23, 2011 | Kenmore Dishwashers
After running a full cycle the dishes have a film left on them. Sometimes soap is not rinsred off the dishes. Tried different soaps for dish washers. It seems the only thing to take the film off of the...
Film on dishes post cycle is caused by 2 things.... Poor water flow during the wash / rinse cycle.... i.e clogged sump inlets or restricted drains. Clean the drain hose first. Start at the cink connection and clean EVERY connection and in-line componenet from the port hole at the sink connection all the way back to the drain hise connection port at the dishwasher.
If you still have dirty dishes post cycle after drain cleaning... then remove the lower wash arm support and clean the accumulator / sump area thoroughly. See this link: (items 1 and 4) http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5140844&diagram_id=28222738#d28222738
Test again.
If the problem persists you will have to gain access to the pump impeller. Inspect the impeller, and pump housing for damage. UNDER the dishwasher. Item 22 of the above link.
This should get your diswasher performing properly again.
I used this model number as a reference: GU2400XTPB1
Thanks for choosing FixYa,
Kelly
Jun 03, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
I noticed dishwashing detergent residue on my dishes and then I discovered the dishes were not being rinsed. I've discovered it will not fill in the normal or rinse modes. It only fills in the auto clean...
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
heatman101';;;;;;;;;;;;
Apr 22, 2011 | Maytag MDB7100AWB Dishwasher
After washing the dishes are not clean. There is a white film over-all. Our water is "hard." I have had this dishwasher several years.
It probably isn't a problem with the dishwasher.
Manufacturers of dishwashing detergents have recently been required to stop using phosphates, resulting in a lot of upset people complaining about the same thing you described.
You can try adding vinegar to the final rinse of the cycle, or you can install a water softener.
Mar 19, 2011 | Dishwashers
Frigidaire dishwasher FDB1500LFCO is not cleaning dishes properly. Glasses have a cloudy apprearance, other dishes are not clean, silveware is a mess. Have hard water so am using LemonShine for hard...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Dishwasher Residue and Film on Dishes
heatman101
Dec 28, 2010 | Frigidaire FDB1502RG Built-in Dishwasher
Dishes have residue..how do I run the cycle to clean the machine only..there is a clean button but does not light up when pressed..does it have to be pressed along with another button...
heatman101
Oct 11, 2010 | Jenn-Air 24 in. JDB1270AW Built-in...
Dishwasher leaving a white film on dishes after wash/dry cycle
Well, that usually happens if the water in the area has too much alkali metals, such as calcium and magnesium.
Try putting some salt together with the detergent before you start the cycle.
And if it still does, try washing the finished dishes again with clean water, i mean, without detergent...
Mar 18, 2010 | Kenmore 16764 Dishwasher
Dish water not emptying out after a full cycle.
heatman101
Feb 22, 2010 | Neff 24 in. S5443X2 Built-in Dishwasher
Dishes aren't clean. i have run vingegar and CR through the cycle but dishes and glasses still have a film.
The most common cause of film left behind is a broken heating element.
The heating element is not only used during the dry cycle, but also to raise the water temp. during the main wash cycle to activate the dishwasher detergent. Fixing the heating element should "clear" this problem right up!
Aug 04, 2009 | Zanussi 24 in. DA6141 Built-in Dishwasher
Soapy film left on dishes
Turns out it was my water softener leaving hard water on my dishes...now I have to fix that.
May 18, 2008 | Dishwashers
Bosch 24 in. SHU43 Built-in Dishwasher Logo
117 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
