Question about Vacuums
Dust shoots out the back of my shop vac...
Why is it everytime that I use my sholp vac... The area behind my shop vac is full of the dust i just sweeped up..what can I do?
Use collection bags or change the filter.
Posted on May 06, 2011
Sucking and blowing
Shop-Vac® Brand. The Original Wet/Dry Vac™
https://www.shopvac.com/
Shop-Vac® is proud to be an American-based company. ... When we say the Shop-Vac® is powerful, we're talking debris cleaning, leaf-blowing, heavy-duty, wet or ... Many of our vacs are backed with a 3 to 5 year warranty, but we've seen ... I had just gotten back from work, so my arm was hurting, and I really didn't want to ...
My ShopVac Blows - WOOD Community
community.woodmagazine.com > Forums > Tools and Tool Buying
Nov 23, 2009 - My ShopVac suddenly started blowing dust out the exhaust ports. I don't mean a little dust, it blows almost as much dust as it sucks in!!!! ... ... I'd look it over very carefully looking for tears or splits. Might be a good idea just .... A few months ago I purchased a Dust Deputy and hooked it up to my shop vacuum.
10 Shop-Vac Vacuum Hacks For Around The House - Thrillist
https://www.thrillist.com/.../10-shop-vac-vacuum-hacks-for-around-the-...
Sep 14, 2015 - Simply flip the switch from suck to blow and blow leaves to your heart's... you really need to get your act together if you're using a Shop-Vac for ...
Shop Vacs...and dust control? - Home Forums - GardenWeb
ths.gardenweb.com > Home Forums > Cleaning Tips
Jan 09, 2016 | Shop Vac Vacuums
Tip
Safe way to vacuum drywall dust
SAVE THAT VAC
One of the hardest things on a shop vac is drywall dust. It is so fine that it gets through the regular filter and destroys bearings/bushings and ruins the motor. Just the other day, a friend commented that he had to get a longer hose as his vac was blowing out a lot of drywall dust because the filter was slipping down!
High performance filters are available at most hardwares and box stores. They resemble the paperbag filters in carpet vacuums and catch the drywall dust so that the bag can just be thrown away when done. The bag is U-shaped to install in the shop vac and have clearance around the regular cartridge filter. The inlet has a rubber seal that pushes around the inlet on the inside of the tank. Just run the vac normally but spare it and your lungs!!!
on Mar 02, 2010 | Vacuums
Kobalt 10 saw blows dust everywhere ,even with a 2 shop vac connected to the dust chute .
It is possible that the dust chute on the Kobalt saw is plugged, not allowing the vacuum to pick up the dust. Run a rod through the dust tube and see if that clears it.
Jun 19, 2015 | Shop Vac Vacuums
How to correct a saw dust problem on a kobalt 10 .dust does not go into chot a 2 shop vac hel
The hole behind the saw blade can become blocked solid with sawdust ( especially if the timber is green or wet). clean out the vacuum hose back to the collector.
Can I use shop-vac without bag 5gal5.5 hp
If you are using it for wet pick up, you would not use the bag. If you are using it for dry pick up, I would recommend using the bag to keep dust from going thru the vacuum and back into the area you are trying to vacuum.
Apr 06, 2014 | Shop-Vac Corporation Shop Vac Wet & Dry...
When dry vacuuming, my shop vac is shooting dust out the back. What do I need to do?
Sounds like you need to re-install the air filter so there is a tight seal between it and the vacuum. You may have removed it to do the wet vacuuming and then did not re-install it properly to do the dry vacuuming.
Sep 05, 2010 | Shop Vac 85L500 Wet/Dry Vacuum
Why does my shop vac back fire dust when I vacuum?
HI,
A vac bag will disperse Dust. If there is a tear Or rip In The Bag.
Try replacing or emptying the existing Bag. ensuring That Any Clips Are Intact.
Mike @ Compurepair.
Oct 16, 2009 | Vacuums
Dust blowing right back into the air
You need to check the filter and make sure it's on all the way. To do this take the top off the vac, make sure the filter is all the way up and in place. There should be a plastic nut to hold it in place. If you are using it for fine dust particles such as drywall dust, you need a special filter for small particles. The filter that comes with the vac just won't do it!
Mar 23, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Dirt smell
If this thing has a fast-spinning belt in the "head" of the unit, you are smelling the dust that is being collected in the back of the little drive "chamber" and is being heated up by the motor and the friction of the belt. This is a pretty common thing on vacuum cleaners designed like the Oreck. If it is huge bunnies of dust, well then that means there is a leak somewhere...
Mar 11, 2009 | Oreck XL Ultra Bagged Upright Vacuum
My bissell bagless vac has no vaccum. ihave
You will have to clean the filter and clean the main motor.  I had this issue on mine and the main motor was so full of dust bunnies, that it stopped it from creating a vacuum.
Mar 06, 2009 | Vacuums
Vacuums Logo
195 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
