Question about Sylvania 6313CC 13 in. TV/VCR Combo
Model src413ac tv/vcr combo, tape wont eject,then tv shuts off
In 30 seconds by itself. I CAN TURN TV BACK ON BUT ONLY FOR ABOUT 30 MORE SECONDS IT SAYS EJECT IN THE UPPER LEFT HAND CORNER,THE VCR TAPE WILL NOT COME OUT
  • 458 Answers
NEED REPLACED VCR LODING BELT OR REPLAIRED MECH ASSY
Posted on Jun 04, 2010
The TV turns off when i put a VHS tape in the VCR. The tape will play for a few seconds, then the Power goes off. When i turn the Tv back on the tape immediately ejects.
Possibly have a tape drive motor issue it powers down to save itself .Thats the dickens with those combo sets they are hard to look at ,you have to take it half apart just to see whats going on
Feb 16, 2011 | Sylvania 6719DC 19 in. TV/VCR/DVD Combo
I also have a 19" Symphonic tv vcr combo which
The problem is with the vcr section, it is stuck in eject mode thinking there is a tape. This a mechanical problem that might be repairable. The tv and vcr share some of the same circuits, you can try resetting the tray in the out position as if it fully ejected the tape. Now if this does not work it means you have a gear timing problem or bad sensor.
Dec 23, 2010 | Symphonic SC319C 19 in. TV/VCR Combo
Symphonic tv vcr combo will not eject tape
You need a new VCR belt it located on right side of the vcr tray take your finger and start rotate the belt clockwise, it should release the tape. or the motor is going bad.
Apr 25, 2009 | Symphonic SC319C 19 in. TV/VCR Combo
TV/VCR COMBO problem
My dear friend your problem is the charge motor belt who is in bad conditions you got ta replace him.Good luck.
May 28, 2008 | Zenith Televison & Video
My Tv is turning off by itself
Call tech support! That's why these people get paid. Sites like this wouldn't need to exist if they did their jobs correctly!
Mar 11, 2008 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
What do I do when my Emerson TV keeps turning off by itself?
I had the same problem with mine turning off after 3-5 seconds. After much research I found a suggestion that on some combo units the vcr part could have a power supply cutout if it is not working correctly. I tried to insert a tape and found that the tape mechanism would not accept a tape. I used a little bit of force and managed to insert a tape. I then played the tape forwards and backwards and the power stayed on! I ejected the tape and found the TV then worked just fine. The power has now been on for over one hour. I hope this give you another avenue to try and fix your problem.
Nov 30, 2007 | Televison & Video
Emerson Television
cambiale las bandas de la casetera
Nov 14, 2007 | Emerson EWC1303 13 in. TV/VCR Combo
TV keeps turning off after 30 seconds
This is usually a sign that a function has not completed or a switch has stuck in an incorrect position. eject can only happen if the sensor (either optical or mechanical senses that a tape is present. The swich might be stuck or the sensor might be blocked or bad. You can open up the unit and try to determine if the sensors are not being blocked by any of the mechanical parts of the unit. You will need the service docs to show you where the components are located. I hope this helps. Shuttle83
Feb 16, 2007 | Symphonic SC3813 13 in. TV/VCR Combo
if all you want to do is disable the vcr portion turn the set on , install a blank vhs tape it has to be blank or the vcr will try to read it .and the tv and dvd should work fine. this is a timing problem in the vcr deck its not hard to fix but it is a pain.
Nov 05, 2006 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Sylvania 6313CC 13 in. TV/VCR Combo Logo
285 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
