Question about Refrigerators
Buzzer is going off about every 4 minutes. freezer stoped working
Frigidaire upright freezer
Hello Susan, thank you for your post!
Did your freezer previously experience a power loss? If the temperature of food rises to an unsafe level, the buzzer will sound and the red light, if equipped, will also glow. First, deactivate the alarm to your appliance by unplugging it or flipping the household circuit breaker. Wait approximately ten minutes and then turn on your freezer. After deactivating the alarm and your freezer has run approximately four hours, the red light/alarm should go off on its own. If the red light/alarm continues to stay on, your freezer may possibly have a communication problem with the control board, temperature control or a wiring harness. If this is the case, I would recommend connecting with an experienced technician to determine the underlying cause.
Dec 07, 2013 | Frigidaire 20.6 cu. ft. / 583 liter...
Red light stays on
Hi - Did the unit previously experience a power loss? If the temperature of the food rises to a level unsafe for a long-term storage, the buzzer will sound and the red light, if equipped, will also glow. After deactivating the alarm and the unit has run approximately 4 hours, the red light should go off. Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn unit back on. If the red light continues to stay on, I would contact a professional to move forward accurately. The freezer may possibly have a communication problem with the control board, temperature control or a wiring harness.
Oct 12, 2012 | Frigidaire 20.6 cu. ft. / 583 liter...
GE chest type freezer buzzer going off
If you have a fast freeze button try that and see if the alarm goes off within a few hours. It bypasses the thermostat switch. Check condenser clean etc but be prepared for compressor failure
May 19, 2012 | GE Freezers
I have a small magic chef freezer that opens from the top. I has about 3 or 4 cu. ft. of freezer space. Lately a buzzer has been going off every 15 or 20 minutes. It buzzes for about 5-10 seconds and then...
With the time as the compressor gets old the buzzing will increased, its not a bid deal, just set the thermostat to 1 during the winter, saves you energy and give the compressor more time to rest.
Sep 28, 2011 | Magic Chef Chest Freezer MCCF5WBX
Sharp SJ-F80SP-BK 4 Door refrigerator doesn't cool, freezer (bottom) working fine
When the freezer section gets cold and reaches its required cooling temperature, after that the frost on freezer section starts defrosting and the cooling fan in the freezer section blows this cool air from freezer to fridge. But if the defrost cycle does not start then over ice will get collected on freezer ventilations and that will block the air passing section from freezer to fridge, so the freezer gets cool but fridge section does not cool.Its defrost problem. Try manual defrost by unplugging the refrigerator from main power outlet for 4 hours then reconnect it and check, if the same problem is noticed again,. If yes then its defrost board problem. The defrost board located in the back of fridge section. You can get required parts from www.repairclinic.com or from online sears part site. ------------- Thank you.
Jan 31, 2011 | Sharp Refrigerators
Making alarming buzzing sound. Still freezing fine
putting unfrozen food in a freezer can raise the temp to cause it to go off allow 24 hours for it to stop if it dont replace the buzzer
May 23, 2010 | Whirlpool Upright Freezer EV161NZRQ
Alarm buzzer went off and the yellow and redlights are "on."
The on/off switch is only for the alarm. Some people do not want the buzzer to sound for them. If your buzzer is going off then the temperature in the freezer is too warm. It usually means the door was not closed all the way or there is a malfunction in the cooling system. Check the door and seal, make sure it is closing all the way around. If it is and the alarm does not stop on it's own then you will need service done on the unit.
May 08, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
The buzzer is loud
Frigidaire # LFFH2067DoW2 # WB52430831 upright freezer (frost free commercial)
Freezer is still freezing. The alarm sounded and I switched the switch off to turn off. The manual says that the temperature isn't at the right temperature and once it reaches the correct freezing temperature the light will come back on or the sound would go off after at least 4 hours. This was since last night about 6:00 and if i switch the switch the alarm is still sounding. The left side of the freezer is a little warmer than usual. Any suggestions
Mar 02, 2008 | Frigidaire 20 cu. ft. / 566 liter Upright...
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
