Have sony STR DE445,sound cuts off ,will come back when I tap on cabinet,seems to work ok with headphones.
  • 105 Answers
Remove all the speakers clean wires and connectors put a drop of oil in headphone socket and try again this is due to rusting and dust
Posted on Jun 04, 2010
Sony STR DE-445 unit powers up but no sound
Check the fuse, Sony is known for its random problems with sound. The one I have you must tap it on the side. Its a flicker switch inside.
Feb 13, 2010 | Sony STR-DE445 Receiver
NO SOUND FROM REAR OR CENTER SPEAKERS.JUST THE FRONTS AND SUB WOOFER WORK.
have you checked the wiring of the speaker some time the can cut internally so to check use a small wire and connect just like the one which is in the manual this Can solve the problem
Nov 19, 2009 | Sony STR-DE445 Receiver
I have a sony str de445 and it overheated one nite and stoped working. when i click the power button it clicks as if it turn on but no display or sound or anything, could you help please
you might have burned up some internal parts, it is very important that you keep your unit well ventalated so that it has less of a chance at overheating, check for any internal fuses that might have blown.
Jun 27, 2009 | Sony STR-DE445 Receiver
Cant get sony sub woofer model no. ss-wg60 working on my sony receiver model no. str-de445
First, go into the "setup" mode of the receiver and go to speaker select, then toggle to sub, highlight and make sure it's "on" Then toggle to speaker volume and check the sub level. Maximum setting is "0". Make sure you are connected to the subwoofer output on the receiver as well. If you still have a problem, post a comment and I can help you some more.Hope this helps
Jun 20, 2009 | Sony STR-DE445 Receiver
Trying to use a passive subwoofer with STR-DE445
The output of the Sony is "signal only" not power. Being "passive" like your sub. What you need is a sub amp, and they are not cheap, 400-600 on average "min". Unless you have a Velodyne 15 or 18, just get an amplified sub, they start around 150 new. Hope this helps
Mar 27, 2009 | Sony STR-DE445 Receiver
Speakers pop and rear speakers cut out of surround sound
your problem is a bad solder connection of the relay linked to the lautspeaker sockets. I had the same problem and googled for the solution. Since I resoldered the pins everything is fine. That problem is well known and happens to a lot of Sony receivers.
I can send you a link with a detailed how-to-do solution with pictures, however it's written in german language. But you can use some online translators.
Here is the link: http://www.bmw-syndikat.de/bmwsyndikatforum/topic.asp?TOPIC_ID=28280&FORUM_ID=20&CAT_ID=9&Forum_Title=Geplaudere&Topic_Title=Problem+Sony+STR-DE445
Ralf (from Germany)
Jan 07, 2009 | Sony STR-DE445 Receiver
Receiver str de 445
Hi - You can download the manual from the link underlined in blue below:
STR-DE445
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Aug 28, 2008 | Sony STR-DE445 Receiver
STR-DE445 Works, but goes into protect when you turn up/down volume
This is a piece of **** unit. Mine only works on the left side, sometimes. When those times are I have NO idea. It doesn't seem to play 5.1 correctly and it goes into speaker protect mode for NO reason. It is TRUE lemon !!! ..let me know if you have any other problems with this JUNK .....schafe1001@aol.com
Sony STR-DE445 protect displayed
It sounds like a bad solder connection. It just needs to be soldered up, if you take it into a shop just tell them it doesn't need any new parts, it just needs to be soldered up.
Or, if you can solder it yourself, or know someone that can, that would be much easier.
Aug 04, 2008 | Sony STR-DE445 Receiver
KN 7000 Keyboard. While playing a
speaker maybe busted tyr to change it.. or test it first before changing
Feb 29, 2008 | Sony STR-DE445 Receiver
103 people viewed this question
 Grubhead
Grubhead
