Facing copying problem from scanning section
My problem comes from scanning & copy printing only, not from any printing from PC.
A thin line appears in the print copy at the same position of every and any print while scanning and printing. However there is no unwanted mark whtsoever while printing direct from PC. Also, any scanned image when viewed in the monitor the same line additionally appears. The line is in the transverse direction of the scanner light movement. Problem is indicative of the scanner section troubleshooting.
Please help me in getting rid of the line mark from scanning.
  • manob Apr 09, 2008
    As I couldn't find any edit button on my first posting, treat this an annexure to that.
    There is also no line mark in the glass or the in the white background, neither the glass is hazy.
  • 589 Answers
Although you didn't specify the scanner model, this solution should work.
If the scanner has a top feeder, open it.
You will see a thin strip of glass, either to the left, or right of the large scanner glass.
There is most likely a small spec of ink, white out, etc on it.
Clean the strip glass with rubbing alcohol and the line should go away.
Posted on Apr 09, 2008
Clean the slit glass under the document feeder. Lift the feeder and find the thin piece of glass on either the left or right side and give it a good cleaning - you marks will likely go away.
Here is a how-to for removing lines from Sharp copiers.
How To Remove Lines from copies prints on Sharp copier
Jan 17, 2014 | Sharp Mx-C402sc mx-C402sc
Equally spaced lines across page only on color copies
If not in the direction of the paper feed then in the direction of the scan head. Dirt on the scan head or bad scan head or scan head connection. Send it back.
Nov 15, 2013 | Konica Minolta Bizhub C284 Color Copier /...
When copying we are getting 2 lines down one side of the copies
Only when copying? What about printing? There are a couple possible causes. The easy one to check for is to make a copy by laying your original on the glass. Now make the same copy using the automatic feeder on top. If the feeder copy has the lines but the glass copy does not then the problem is coming from the ADF scanner glass which is the thin strip of glass that is just to the right of the large main glass. If so then just clean the strip of glass with a soft cloth and some glass cleaner. Note that sometimes the stuff that might be stuck to the glass is hard to get off. If BOTH the ADF copy and the main glass copy have the lines then most likely the lines are coming from the drum unit. If you have the copier hooked up for use as a PC printer then does the print from the computer have the lines as well? Then it most definately is coming from the drum unit and you would need to replace it. If the PC prints are clean then the drum is not the cause.
Good Luck and Thank You for using Fixya.
Dec 28, 2010 | Sharp AL 1631 Copier
I am scanning a photo. I have translucent lines running horizontal through the picture before i print it.
Documents scanned/copied from the document feeder pass over a thin glass area where scanning occurs. Clean this area if sent faxes, copies or scans have black or white vertical lines.
  1. Lift the document cover to expose the platen glass.
  2. Wipe the ADF scan area (C) with a clean, soft, lint-free cloth moistened with water.
  3. Then wipe with a clean, soft, dry, lint-free cloth making sure there are no residues left, especially on the platen glass.
  4. Close the document cover and make a copy of a text document to confirm the black line has disappeared.
Dec 20, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Getting a black strip in copy mode on X6575 lexmark printer. No line in print or test mode
Most likely a page was scanned with 'white out' (Liquid Paper), still wet on the page. As the page feeds over the scanner, (a narrow strip of glass that runs across the width of the page along the feed path) the wet liquid paper comes off on the glass as a thin line and dries. Thereafter, when copying, the scanner light does not go through the liquid paper streak and the result when printed is a thin vertical line that runs the full length of the page.
If this is your problem: follow the path that the paper travels when sending a fax or making a copy, until you find the scanner (narrow glass strip). Take a clean, soft cloth and a small amount of methylated spirit (or white spirit) and remove the now dried Liquid Paper from the glass. Clean the whole strip ensuring that the glass is left clean and dry.
Mar 16, 2010 | Lexmark X6100 Flatbed Scanner
I have a thin line all the way down the page when making a copy.
Check scanner glass and clean. Further test - Scan from the computer. If the line is still present, the scanner CCD is failing and requires service as there is no user servicable part inside.
Nov 21, 2008 | HP LaserJet 3050 All-In-One Printer
Thin black line on Xerox 4011 laser printer
Does the same thing occur with a different document.. Because it is not repetative, it leads me to believe the line is being drawn at the direction of the software. Try printing a test page, and see if the line appears. If not the issue is from within the word processsing software. It almost sounds like a legal template for a pleading..
Nov 21, 2008 | Computers & Internet
Print Black Page
Is the scanning lamp coming on ? No, replace lamp
is there a print in the background? Yes, check Seperation unit ( inside under the drum, usually three thin wires)
Nov 19, 2008 | Sharp AR-M450N Copier
Problem while copying
mark on scan glass, clean glass slit in where original is fed for copying
Nov 07, 2007 | HP LaserJet 3050 All-In-One Printer
156 people viewed this question
