Question about KitchenAid A-9 Electric Burr Grinder
Clogged? My coffeegrinder suddenly stopped working correctly. The beans seem to be going down into the grinder, and it is grinding I think, but there are no grounds coming out. Seems clogged or something? And the machine gets very hot.  Any suggestions?
I took the jar off and cleaned/scraped the port out(the square hole that the gounds come out of) then gently "bumped" the top and side of the unit on newspapers to get the accumulation of 40 years of stray grounds out and it runs great now!!
Posted on Nov 26, 2008
Talea ring the grinder will not stop gringing
The Talea model is with a Ceramic grinder system. This can happen when the grinder outlet is clogged with coffee grounds. Fresh beans cannot enter the grinder as the outlet is clogged. Remember, the grinder in any machine is a grinder. It does not shovel the coffee grounds out and clean the outlet when it is clogged.
1- Check if the grind setting is too fine (powder like). If so change the setting to coarse. Fully automatic machines do not need fine grind. Keep the grind fineness like the table slat grain.
2- Check if the beans are dark roast and oily. Oily beans are a slow poison for any fully automatic machine. Change the beans to Non oily medium roast type.
Oct 16, 2014 | Saeco Talea Ring Plus Espresso Machine
I owe the miele CVA4075 BUT my whole bean grinder is not grinding the bean and only water gets dispensed, anyone have a solution?
Make sure the hopper is working correctly to see if there are any blockages, then check under the hopper to the opening where the beans go to the grinder. My guess is that there are a few beans and chipped portions of beans which are clogged under there.
Jun 28, 2011 | Miele Coffee Makers & Espresso Machines
Hi. I have a miele cva4060. The grinder is working but it does not seem to be getting any beans through it and I am only getting water dispensed instead of a coffee shot! It was working fine a few days...
Hi
If you hear its 'grinding' then that's good - problem is where is the ground coffee going or supposed to go??
Check there is no build up of damp/dried coffee grinds in the pathway between grinder and brew unit - this can happen if the machine is not properly cleaned say every 3 mths or more often depending on usage - coffee 'dust' can build up.
Also suggest remove all beans from grinder, vacumn last ones out. clean all around grinder opening. Add a dozen or so beans to the grinder, turn on and try again. If the beans disappear, its grinding properly. If they don't end up in the brew unit, then the hold up is as I said in that pathway - grinder to brew unit. If you cant see an obvious blockage/build up, suggest you have a tech look at it.
Cheers
Mike
Dec 10, 2017 | Miele Coffee System
Jura E8 beans will not pass through grinder resulting in "Fill Beans" error message. Saw reference to Kaffeestudio.com for dissasembly instructions but that link no longer works. I assume that the chute...
It seems withthis model you have a 1 year or 4000 cups warranty with this.
If you are within this, then give them a call - here is the Manual if you don't have it -
MANUAL -
I suggest you start by removing the beans in the hopper and wiping around to remove oils.
Then refill with fresh dry beans.
Plug in and set up as normal
Set to brew a standard large cup - and adjust grinder to coarse setting while grinding.
Do not adjust with grinder quiet - it must be done while rotating.
Make at least 10 cups this way at the coarse setting.
I think what has happened is that damp beans (frozen or cold) have entered the unit and caused the coffee to gum up at the top of the burr.
This will just push fresh beans out of the way instead of starting to grind them.
If you use dry (light loast) beans, it doesn't seem to happen as much.
Just ake sure you refrigerate most of your stocks, but keep a small stock at room temperature in an airtight tin to prevent this kind of thing.
You can actually push down on the bean stack slightly with a wooden object while the grinder is running if nothing moves on the coarse setting to get things moving.
Feb 10, 2010 | Microwave Ovens
Oily beans seem to have clogged our coffee grinder up. What can we do?
Rotate the bean hopper counter clockwise until it stops. Lift it off. Remove the outer burr with the 2 wings and clean under the burr. Clean the opening going to the chute for ground coffee(inside where the burr was).
Install the outer burr. Install the bean hopper. Rotate the bean hopper to the French press grind (coarsest) and operate the grinder. This will clean the burrs and the passages. If it starts to clog, repeat the last part to clean the burrs and passage. It must be grinding to go to a finer setting, but you can go to a coarser setting any time. Another thing. Turn the grinder upside down (empty) and rotate the bean hopper back and forth to clean the threads of the adjusting burr..
Dec 20, 2009 | Solis Maestro Electric Burr Grinder
All of sudden my grinder plugs up. coffee settles in around the base of the burr and does not seem to fall into the grind bucket, so the machine still runs but grinding basically stops as no more more...
This fixes almost all the "beans will not feed or beans will not grind" problems caused by coffee bean dust packed in the burrs. Oily beans cause this problem more fequently.
a. Pour all the beans out the top.
b. Open the settings up all the way and see what else can be poured out. Use your shop vacuum to **** grounds out the spout and backward out the bean bin.
c. Pour in some instant rice and start grinding. Reduce the grind to a small setting like six and then open the settings all the way again. (The grinder will not start at a low setting with the rice in it. If you let it stop, open the settings to about 16 before trying to restart.)
d. Pour out the rice and vacuum out the ground rice.
e. Adjust the grinder to your favorite setting and try a coffee grind. Grind until most of the rice dust is expelled (any remaining trace of rice dust will not affect the flavor of the coffee).
Nov 03, 2009 | Solis Maestro Electric Burr Grinder
Cuisinart DGB-700BC grinds but no grounds in the basket.
Hi there, you have some kind of blockage, If the beans are going down, you need to remove the brewer unit and wash it, if the beans arent going down the exit of the grinder is blocked and needs to be removed, cleaned and replaced
Jul 26, 2009 | Cuisinart DCC-1200 Coffee Maker
Cuisinart grind and brew 10 cup grinder stopped working
My grind and brew is a little different, but when I have this problem, I havve to remove the beans and vaccuum out the bean reseviour. It gets clogged and then it won't grind.
Mar 23, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
The grinder itseld seems to be working because it makes the grinding noise. However, the beans are not going down the shaft into the grinder. I have cleaned out the top and removed the container holding...
Make sure the filter basket is in the open position, and that the area that runs from the grind basket to the filter basket is free from grinds and mositure.
Jun 28, 2008 | Cuisinart Thermal DGB-600 Grinder
My Saeco won't grind the beans
There's moisture in the grinder & it's clogged - just dismantle the grinder & clean it, then ensure you don't splash water into the bean hopper when you fill the water tank.
Mar 29, 2008 | Saeco Magic De Luxe Espresso Machine
KitchenAid A-9 Electric Burr Grinder Logo
251 people viewed this question
Top KitchenAid Coffee Makers & Espresso Machines Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you a KitchenAid Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
