Ok ifixed my other sound problems!! but i still cant get sound from my tv to through my stereo! i also have a shaw converter!!
    Brigadier General:
  • 3,513 Answers
Check if your tv have red/white audio output. If so just plug them from the tv into a red/white input on your stereo receiver and select that input on your receiver. Turn off the tv sound and it should work.
If your tv doesn't have red/white outputs, your cable box will. Then just run the red/white output from the cable box into the red/white input on your receiver, bypass the tv, turn off the tv sound and select the input on the receiver, again as above, where it's plugged in.
Also check this link if it helps….
http://blog.mymediasystem.net/my-media-system/solved-no-sound-via-stereo-jack-with-philips-lcd-tv/
Let us know if you want something more else please accept the solution.
Thank You for contacting Fixya.com
Posted on Jun 04, 2010
  • osama_bin11 Jun 04, 2010
    hmmnn tried both ...no go...do i actually have to press mute on the tv rather than just turn it down??
  • osama_bin11 Jun 05, 2010
    ok thx bud... it turned out my cords were faulty, only took a million trys to realize, however, thx!!!
Have Technics SA-EX500 connected to Samsung Smart TV. For tv channels the sound is perfect but when I switch to Netflix or HBOGO the sound is static/cackling.
Suggest connecting via the headphones jack or if available the RCA audio output jacks. If you connect via the headphone jack you will need to adjust the TV volume to a lower setting to avoid distortion/./ The The problem is that the optical output connection is a digital connection and depending on the digital format the Digital to Analog converter may not be a configuration that the audio stream to the stereo required for the tv/vcr in.
How does the audio sound using the Samsung Smart TV internal speakers>
Also under menus/audio/settings you may need to change the Optical output to stereo.
Netflix also has settings that will change the audio stream.
Hope This helps?
Nov 21, 2016 | Samsung Audio Players & Recorders
How to pvr a future show on shaw?
Take your Shaw remote.
Press the GUIDE button.
Use the up/down buttons to select the channel for the program.
Use the RIGHT button to move forward in time until you see the name of the desired program.
Press the INFO button.
Press the RIGHT button, to highlight the "red" RECORD button.
Press OK.
Apr 02, 2014 | Televison & Video
The size on the TV Guide on Screen is too small, can that be changed?
Take your Shaw Remote Control.
Press SETTINGS.
Use the LEFT/RIGHT buttons to highlight the "home" icon.
Press OK.
Press the DOWN button to highlight the "Setup" button.
Press OK.
Highlight GUIDE SETUP.
Press OK.
Select GRID CELL HEIGHT.
Set it to DOUBLE HEIGHT.
Press OK
Press EXIT.
Mar 16, 2014 | Samsung Heating & Cooling
Dynex remote codes
Take your Shaw remote control, and follow the instructions on the back. If that does not work, telephone Shaw, and ask for technical support for TV.
Feb 26, 2014 | Televison & Video
Shaw pvr expander not working
Take your Shaw remote control.
Press SETTINGS.
Use the LEFT/RIGHT keys to highlight PVR.
Click OK.
Use the LEFT/RIGHT/UP/DOWN keys to highlight PVR HISTORY.
Click OK.
Scroll through the entries, looking for any "hardware failed" or "hardware error" messages -- finding any implies a failing disk-drive inside the Expander.
Need more help? Telephone Shaw, and ask for "technical support" for TV/PVR.
Jul 21, 2012 | Motorola Televison & Video
I need the codes for shaw remote control.
Follow the instructions on the back of the Shaw remote control to program the remote to be compatible with your VCR/Stereo/TV.
Dec 03, 2011 | shaw.ca
My Aiwa Colour TV, model No. TV-A2019, has developed audio problems. 1. The audio output from the speaker is high even when volume is set at level one. Audio output is constant for volume level 1 to...
You just come aroung the sound decoder section of your tv. Decoder problems may cause the fult you pointed out. Since all the controls are electronically controlled, and all are through sound decoder, which converts sound to stereo the problem must be there. Since sound comes from two channels are ok, there is no problem around sound output. Check for some soldering loose contact, wire socket loose cotanct also.
Oct 14, 2010 | Aiwa F2000 20" TV
Sound drop with Shaw pvr box with hdmi. How do
This is a very common problem with no real solution. If your TV can be programmed to accept separate audio from HDMI video on the same input, you can feed the audio through standard RCA cables. Unfortunately most TV's do not allow this. Alternatively run them into a stereo receiver. Buying high end HDMI cables will not help. Most people I know with this issue have bit the bullet & just used component video instead. The difference in quality is minimal.
Apr 25, 2010 | Arris DCT6200 DTV Receiver
How to Connect Converter to TV, DVD/VCR and a Stereo?
Connect converter box to your DVD/VCR player at the ant in. Depending on your location you might need a new ant for UHF.
Jun 15, 2009 | Philips DVDR3435V/37 DVD Recorder/VCR
22 people viewed this question
 Grubhead
Grubhead
