Question about Dewalt DW735R Reconditioned Heavy Duty 13" Three Knife, Two Speed Thickness Planer
Dewalt 735 ...How do you calibrate the planer head to be level with the table.
4 Suggested Answers
  • 10865 Answers
SOURCE: planer does not cut evenly across the table
You have to loosen the screws on the blades and adjust them. It tells you how to proceed in your owner manual
Posted on Apr 05, 2009
wentlanv
  • 710 Answers
SOURCE: Hi, I have a Dewalt
Hi Jay,
Bad news!
Was your planer out of level before the chain broke? If it was, this could be the cause of the chain breaking. If that was the case, then it's possible something in one of the front posts has broken.
If the out-of-level situation happened after the chain broke, then the chain may have not only have broken the handle connections but also a part at the top of the post.
I am pasting a website where you can easily get parts and you can see a schematic of the planer: http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/dewalt/DW735_TYPE_1
Their delivery is pretty quick.
If you have any more questions about this, please reply back.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie, woodworker by night
Posted on May 03, 2011
rowdy45176
  • 2176 Answers
SOURCE: I bought a dewalt planer model DW 735 but did not
try going to dewaltservicenet.com and on the left hand side under find parts (small print manuals) type in your model number it will redirect you to the manual/breakdown page. the manual is 60 pages long if you download the complete one. Let me know if you are still having trouble.
Posted on Jun 27, 2011
My Dewalt 735 planer won't turn on. I blew the house fuse a few times, it would start after I came out. Now it won't start at all and it's been a couple days
The 735 draws 15 amps, which is the rating of typical lighting circuits in homes. The receptical in the wall is sometimes 15 amps although those circuits usually have 20 amp breakers. Since you said "fuse", it might be a bad fuse or even the wiring between the two. Circuit breakers go bad also. If you can confirm the receptical supplies voltage, it is time to check the 735.
Unknown if the device has a termal switch inside. I doubt it would go bad, but you implied a resting period allowed it to run several more times after the fuse in the basement was replaced. If it reset once, it should do it again. If you can find a diagram, there might be a fuse inside, but someone would have to take it apart to check.
A motor can get so hot that a solder joint inside can let loose and it will never run again. Sometimes the coil (windings of the motor) can short out (melt together) and this will increase how much current goes through it and also generate more heat and melt more windings together. Besides producing a smell, your house fuse would burn out real quick.
I had a chuckle over your 2nd sentence but I dare not say why. If it started after you came out (of the house), why did you not run it for a longer time?
A motor requires more power at the instant of turn on. 15 amps of running current will require 20 amps or more when starting. "slow blow" fuses (vs quick action) and circuit breakers can deal with the short period over current requirements.
Nov 23, 2015 | Dewalt Planer (DW734)
Dewalt 735 planer wont start
Power? circuit breaker? Plug? Owner's manual. Troubleshooting
Does the motor hum? if so you have something jamed in the planer cutter.
Feb 28, 2015 | Dewalt Tools & Hardware - Others
Adjustment on dewalt planer
I don't know which planer you have, but if all the planing happens on the top side of your stock then all surfaces underneath should be at the same level.
If you have a fancy planer that cuts on the bottom side, then the outfeed table should align with the cutters and the infeed table would be adjusted below that by the cut thickness (like a jointer
Mar 17, 2014 | Dewalt DW7351 Folding Table for DW735
Dewalt 735 screws holding knives in place get stuck and won't come out
My problem exactly. Very hard to change blades. I've used wd40, heat, drilled out center of screw, but more of them get stripped all the time.
Dec 13, 2012 | Dewalt DW735R Reconditioned Heavy Duty 13"...
Download the manual from the link below.
de-waltdw735.com/manual-dewalt-dw735/
Hope it helps.Thanks!
Jan 06, 2012 | Dewalt 13 in Planer
The drive belt on a dewalt 735 planer dosnot track
The pully which quides the belt must be perfectly level in both the horizontal and vertical positions. Use a metal square to check alignement and adjust using adjustment screws.
Apr 25, 2011 | Dewalt 13 in Planer
Can I get a paper manual for the 735 planer?
Got to:
www.servicenet.com.
You can order a replacement manual for the dw735 from them.
Hope this helps.
Apr 23, 2011 | Dewalt 13 in Planer
I need instruction manual book of DeWalt DW 735 planer to replace the blades
Hi mmh9894,
You may view the manual. Click the link below.
http://lib.store.yahoo.net/lib/tylertool/DW735m.pdf
Hope I help you.
Have a nice day!
Thanks for using Fixya.
Feb 24, 2011 | Dewalt DW735R Reconditioned Heavy Duty 13"...
Dewalt 735
There is a wheel on the left hand side. Typically, it won't let you LOWER it below what that wheel is set to, but that may have something to do with it.
May 27, 2010 | Dewalt DW735R Reconditioned Heavy Duty 13"...
Dewalt 735 planer. dust is accumulating in the
Had the same problem. Drove me nuts trying to figure out where it is coming from. It most likely is a worn in hole in the squirrel cage where the two halves go together. You won't see it unless you remove the fan and both halves of the blower housing. Take them out and put the two together and have a look from the inside. The wear is along the seam. I used hot glue in that area to fill the gap. Squirt it on one half and put the two halves together while hot. Also, you can buy replacements for these. Hope this helps.
Jan 12, 2010 | Masonry Tools
Dewalt DW735R Reconditioned Heavy Duty 13" Three Knife, Two Speed Thickness Planer Logo
232 people viewed this question
Top Dewalt Cutter Tools Experts
Are you a Dewalt Cutter Tool Expert? Answer questions, earn points and help others
