Question about TechView P4204TW Television
Techveiw flat panel plasma no picture when turned on
Recently when I press the on button the tv light will turn green but iwill only get a picture once in a while.
Recently when i press the on button the tv light will turn green but i will only get a picture once in a while
Posted on Jul 31, 2010
Standby light changes from red to green
hi this fault could be down to capacitor in the power supply, they bulge or go leaky, you need to take the back off the tv, to have a look. try and find a tv tech in your area hope it helps
regards
shaun
Jan 05, 2014 | LG 42PX5D 42 in. Plasma HDTV
Sanyo dp50747
sounds like a mainboard problem
Jan 31, 2013 | Sanyo DP50747 50 in. Plasma TV
Turn tv on. green light solid display, no picture or sound
The flashing green light is likely indicative of a self-test failure, indicating the TV has detected some sort of internal fault. With no picture or sound, one strong suspect is the power supply. Flat-panel TV's have an internal DC power supply that converts the inbound AC current, and when these fail, or are unable to supply a minimum level of power to the set, it can behave as you describe, providing only enough power for the green light to illuminate.
Jul 28, 2012 | LG 50PG60UD 50 in. HD-Ready Plasma TV
My nec plasma tv seems to turn on for a few secconds then returns to standby,I took the back of it and tested fuses. 2 hi temp ceramic fuses were blown 4Amp any ideas?
Have you tried pressing the "Input select/Exit" button? Right after pressing the power button and the light turns green, press this button until you get to the right input that you are connected to, and hopefully you should see your picture. I had this same issue when I first got this T.V., Hopefully this helps!
Jan 25, 2010 | NEC PlasmaSync 42MP2 42 in. Television
Lost picture. When using main power button, the
Tries unplug,replug the tv an hour later might work.But this a temp.fix,must replaced the backlight video board sooner or later.
Dec 22, 2009 | Planar PDP-42BK 42 in. Plasma HDTV
Sanyo dp50747 Plasma HD TV
sanyo recommends using the reset button with cable box on, vcr off and press the reset button 2x, then try pressing channel up button if no message appears on the screen. i have not trid it yet... but good luck
Sep 23, 2008 | Sanyo PDP-42H2W 42 in. HD-Ready Plasma...
No picture, no sound.
Hi i have a pilips 42" plasma tv (42PF5320/79) i can hear clicking the green light is on and the tv will go into stand by if i press the power button and the red light also comes on .I have turned it on and off and it works now nothing just the light on the front as if its working looking at the back through the slots two green lights come on then the tv clicks and they turn off,thanks
Aug 06, 2008 | Philips 42PF9630A 42 in. Plasma Television
Sony FWD50PX2/S 50 in. Plasma Television power problem
It does sound like a power supply problem but that can be misleading because a problem somewhere else in the TV can be "holding down" the power supply. This can usually be determined by using some isolation techniques.
Aug 08, 2007 | Sony FWD50PX2/S 50 in. Plasma Television
TechView P4204TW Television Logo
175 people viewed this question
Top TechView Televison & Video Experts
Electro Med Services...
Are you a TechView Televison and Video Expert? Answer questions, earn points and help others
