Question about Whirlpool Dishwashers
Dishes are still disgustingly dirty after being washed. I don't think the rinse cycle is working very well or at all.
  • Whirlpool Master
  • 909 Answers
Remove the rotors and clean them thoroughly. If they dont rotate, no cleaning will take place.(this will also effect the rince cycle).
Posted on Jun 04, 2010
Dishwasher not cleaning very well.
Hello do it heat up ok is the water Hot please
Nov 13, 2015 | Siemens Dishwashers
Our dishwasher takes about 3-4 hours to run a cycle. My brother has the same model and it takes about an hour. Is there an adjustment that we can make to correct this? Thanks, Karla
make sure that your filter in the bottom is clean and if you are using the automatic wash cycle, it will wash until the water is clean. Sometimes it will take an hour, sometimes it will take close to 2 depending upon the level of dirty dishes in the dishwasher. And don't rinse! They work better on dirty dishes.
Jan 05, 2011 | Bosch 24 in. SHX46A05UC Built-In...
Manual for hotpoint how to work it
  • Load the appliance with dirty dishes, placing soiled pots and pans on the lower rack where they will be subjected to the most vigorous cleaning. Glassware and dishwasher-safe plastics should go on the top rack. It is not necessary to rinse dishes before loading them in the Hotpoint appliance, unless the dishes have been sitting for awhile and the food particles have dried.
  • Fill the detergent compartment with your preferred brand of dishwashing detergent, and add glass rinse solution to the rinse reservoir on the inside of the door if your model is equipped with one, then close the door to lock in place.
  • Select the cycle you wish to use and press the button. For pots and pans, use the heavy-duty cycle. Normal wash is fine for dishes and utensils.
  • Save on your energy bill by running the dishwasher only when it is full and by allowing the dishes to air dry instead of using the heat dry function on the appliance.
  • Oct 10, 2010 | Dishwashers
    White film on dishes and still dirty.
    Check rinse aid is actually dispensing - turn it up to max for a while to clear it, and check level is going down after a week.
    If you suffer with hard water - your heating element may need replacing as it is probably furred up.
    Jun 06, 2010 | Miele G892SC SS Dishwasher
    Gritty/sandy feeling on dishes from dishwasher
    You could only check the basics. Since the dishes are clean, it means they went through the wash cycle. It also means that that the holes on the washer arm are not blocked. If they were salty and dirty the wash arms would be something to check. And since they came out feeling like salt is on them its possible they didn't rinse and its also possible the dirty water didn't drain.Were your drain and fill hoses checked or did the techs just check the dish washing machine itself? Its also possible the water for rinse is not hot enough. Before the rinse cycle comes around try running the hot water at your kitchen faucet. Any other issues may be within the cycling of the machine.
    Apr 29, 2010 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
    Mold growing on dishes
    Recommend that you run another cycle with no DW soap aded, waiting until the dishwasher has filled with hot water and begins to do the first wash cycle. Then add 1/2 cup of bleach to the water and close the door. Allow the cycle to finish. Run it normally with a standard load of dirty dishes. Note: These high efficiency dishwashers count on the "dirt" of the dirty dishes to help wash/clean the dishes. Recommend you not rinse/wash the dishes before you put them in the dishwasher.
    Watch for any occurrence of the black dots and repeat the bleach treatment.
    Jul 22, 2009 | LG 24 in. LDF 7811 Stainless Steel...
    Food particles are on dishes after washing
    Try adding bicarb of soda/baking soda and vinegar in the detergent dispenser. Bicarb fizzes off hardened particles and vinegar strips off grease and aids rinsing.
    Jan 26, 2009 | Maytag 24 in. PDB1420 Built-in Dishwasher
    Water seems to be hot enough, drains properly, arnms not blocked, dishes not being cleaned at end of cycle. Almost seems like it is skipping the wash cycle.
    Hi smiller8565,
    There is 3 basic problems that will cause a dishwasher to not clean the dishes. You can check these problems and see if any will solve your problems.
    1: If there is water or suds left in the dishwasher after the cycle is complete. This will cause dirty water to be used in the final rinse and the dishes will not get clean.
    2: The pump that supplies water to the spray arms is jammed or defective and unable to pump the water properly, thus causing the dishes to remain dirty.
    3: Timer, the timer is not allowing the machine to work in the wash cycle.
    The solutions for these 3 are as follows.
    1: check the drain line for blockage, if you have a disposal make sure it is clear and water flows down the drain properly. If you have suds left in the dishwasher, clean them out and run a couple cycles with not detergent to rinse away the old suds.
    2: Look down in the bottom for any obstructions in the pump. Popcorn seeds, broken glass, etc.
    3: If the unit is skipping the wash cycle you will most likely need a new timer or control assembly.
    Good luck and I really hope this will Fix Ya
    Mike
    Sep 24, 2008 | Dishwashers
    Whirlpool gold builtin dishwasher
    Do not recommend premeasured tablets, usually too much soap. If pre-rinsing dishes use only 1 or two teaspoons of soap in the main wash cup..do not put soap in the prewash cup. Excess soap can cause oversudsing and make the soil sensor think the dishes are real dirty initiating additional wash cycles. Use rinse-aid for better drying performance
    Apr 28, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
    Indesit D63 dishwasher dishes not getting clean
    Dishwasher seems to cycle through but dishes are still dirty, like there is no water being sprayed?
    Jan 23, 2008 | Dishwashers
    Dishwashers Logo
    44 people viewed this question
    Top Whirlpool Dishwashers Experts
    Mike
    Owen Barnes
    Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
