Question about Traxxas Stampede Monster Truck Rtrw/Xl 5
The steering does not always work how it should. sometimes it goes to the right alot and very little movement to the left.
  • 748 Answers
Hi
Servo gears have been striped. Replace the standard servo with a heavy duty model.
Posted on Jun 06, 2010
2006 Ford Fiesta, Indicators not always working. It sometimes goes slowly on either side. Sometimes when I take a left it doesnt work at all but then I tap on the stick and it starts working. Sometimes it...
It turned out to be the pc board where the relay mounts Located under the plastic shroud around the steering column behind the steering wheel .. I soldered it and it started functioning
Sep 17, 2013 | 1993 Ford Festiva
1999 ford explorer limited whining noise in front end
Whining noise is probably in one of the pulleys or belts. Probably the power steering. And the popping is probably CV axles.
Aug 02, 2012 | 1999 Ford Explorer
What causse the steering column on a 2002 pontaic aztek to have alot of play with it
that area is a joint and it has a pin there that maybe bad and that would cause some play. i think that you aiso check your pitman arm and gear box that is most likely where the play is. good luck!
Jul 23, 2012 | 2002 Pontiac Aztek
Intermittent buzzing sound at turn signal switch - 97 suburban
You found it. and you verified it the solution and the fix is the turn signal switch
Mar 17, 2012 | 1997 Chevrolet Suburban
Had about 4 pairs of the same brand of headset and after about 7 or 8 months lose hearing of sound form the left side. Always the left. their is no sign of tear in cable from out side and it cost a lot of...
The Left Side speaker unit(driver) of the headphone is different from right side. left side has more connections and soldering points, main cable goes to left side and chances of oxidization is more, because of cable movement(if cable goes to both sides of the headset, than it damages the side where cable movement is high). try to carefully open the headset and check the connectivity with multi-meter, If it is cable problem then trim the cable and re-solder. Or as you told you have 4 pairs, and you have broken ones. swipe the speaker unit (drivers). Besides both left and right drivers have different connections, it is possible with little soldering knowledge. hope you got it. thank you
Sep 02, 2017 | Labtec Radio Communications
My ignition key wont turn at all , batteray is good , i tried with both keys
This sometimes happens when the steering wheel is locked up make sure the car in all the way in park then turn the wheel as far as you can to the left and the right you should get a little movement turn the key while doing this it should allow it to work. Let me know
Dec 08, 2010 | 2002 Mercedes-Benz C-Class
My car makes a bad growling noise. Everyone said that it was a front wheel bearing because that tire was worn down really bad on the outside. I replaced the passenger front wheel bearing, and it is still...
WHEEL BEARING USUALLY STARTS MAKING A ROARING TYPE NOISE WHICH USUALLY GETS LOUDER THE FASTER YOU DRIVE, SOMETIMES THEY WILL BE LOOSE , TO CHECK JACK UP THAT WHEEL AND GRAB TOP AND BOTTOM OF TIRE AND SHAKE, IF THERE IS MOVEMENT, TRY TO GET SOMEONE TO ROCK TIRE FOR YPU AND WATCH WHERE AXLE GOES INTO CENTER OF BEARING AND SEE IF AXLE IS MOVING WITH TIRE MOVEMENT AND SPINDLE REMAINS STATIONARY, THEN IT IS BAD BEARING, OR SOMETIMES THERE WILL BE NO MOVEMENT, THEN BLOCK REAR WHEELS AND RUN CAR WITH THAT WHEEL IN AIR AND SEE IF YOU HEAR NOISE, GOOD LUCK.
Mar 20, 2010 | 2001 Chevrolet Cavalier
2004 dodge caravan , when i turn the steering left or right a loud vibration from the front ,i change'd the links and the rubbers and i still have the same vibration,what i have to do??
it sounds like the power steering pump is low on pressure as the vibration is almost always caused by low pressure,check that the drive belt for the pump is tight(meeds to have alittle movement but only a little with a gentle press of the thumb on it)if the belts ok and tight enough just look carefully at the pump with a friend cranking the steering,pump may be moving on mounts but unlikley,and check nothings binding up the steering
Nov 25, 2009 | Dodge Caravan Cars & Trucks
'89 chevy k1500 sloppy steering wheel (HELP PLEASE)
Everyone always gravitates to the suspension but folks, it's 99% sure that it is the EVO. The EVO is the sensor built into the steering column that senses movement of the steering wheel then controls the power steering pump accordingly. When it goes out (which is all too frequently) you get sloppy and loose steering at lower speeds and it does tighten up a bit on the highway at higher speeds. This is the way it is supposed to work but when it fails it's downright scary trying to keep the truck straight on a narrow two lane road!
Jun 14, 2009 | 1998 Jeep Grand Cherokee
Traxxas Stampede Monster Truck Rtrw/Xl 5 Logo
112 people viewed this question
Top Traxxas Toys Experts
Michael Brisco
Level 1 Expert
gbob59
cwradio73
Are you a Traxxas Toy Expert? Answer questions, earn points and help others
