Question about HP LaserJet 2430 Printer
Grinding noise from the unit HP2430 - HP LaserJet 2430 Printer
  • 241 Answers
The grinding noise can be caused by your fuser. Have a certified technician do an assessment on the printer to see if this is the case. You may need to have it replaced. If printer is still under warranty, contact HP and have it covered by them.
Posted on Jun 04, 2010
Testimonial: "I will check the fuser gears and other intern-connecting gear, anyway thanks."
Grinding noise
Could be photoconductor gears are bad will have to replace unit or fuser unit you will have to decide which one first
May 28, 2014 | Ricoh Aficio 1018D All-In-One Laser...
Noisy printer
The printer or the drum/toner unit may cause the grinding or clicking noise.
  1. Power off the printer and open the front cover.
  2. Remove the drum/toner unit and close the front cover.
  3. Power the printer back on.
If the grinding or clicking noise dose not occur when the drum/toner unit is removed from the printer, then the drum/toner unit is the cause of the noise. Install a brand new drum unit and/or toner cartridge may be necessary to stop the noise.
Still having Problem Then follow Us For
Brother Printer Support
Feb 25, 2014 | Brother DCP Office Equipment & Supplies
Make noise when copying
dear u dont have mention the model and make witch some grinding noise or some other kide of noise if grinding there is any gear problem or if any other kine of noise may be any bushing dryed, other noise for the bearings in the heater unit i hope tis will help you
thanks
May 10, 2010 | Office Equipment & Supplies
HP2430 PRINTER TRAY 2 SAYS JAM BUT NO PAPER IS STUCK IN THEIR
look it the tray there is what we call a paper sensor or a paper flag it's a small lever that is spring loaded if there is a problem with that sensor the paper will not register as being picked up by the rollers. or the paper pick arm best way to fix would to provide the serial info and I can upload you a manual for if with detailed diagram that show how to replace this part.
Mar 15, 2010 | HP LaserJet 2430 Printer
Loud grinding noise from unit when flushed like
take the pump out and haul it outside and spray it off and check in the bottom of the pump to make sure there isn't anything stuck in there. then shop vac the bottom of the tank out to make sure there isn't anything funky in there that would get clogged in the pump. sometimes the out let line gets clogged as well you can buy a drain king ( it's a rubber deal that hooks on the end of a hose and when you turn water on it swells up and sprays water out) then stick it in the outlet pipe and let her rip and see if it lets the water through.
Jul 28, 2009 | Saniflo & Saniplus& Macerator Pump
Loud grinding noise from agitator. How hard is this to fix.
Removing the agitator will not stop the grinding noise. Usually a bearing/gearbox problem going bad will create a howling grinding noise. You'll definitely hear it in the spin cycle. These are an expensive fix and require special technician tools to disassemble the unit. The gearbox is a sealed unit. Most manufacturers warranty their unit's gearbox for 5 years regardless the warranty you got when you purchased the unit, so check into this before you void your warranty. (The manufacturer requires their factory authorized service technicians to do the replacement) All in all if you do the work yourself it'll be approx $250 for the parts and gearbox transmission. To have the work done is usually much more.
Nov 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Grinding noise,unit stopped, burning smell?
broken or slipping drive belt, motor to spin pulley defective drive clutch, spin brake fails to release to transmission is frozzen
Oct 07, 2008 | Admiral AW22 Top Load Washer
Loud grinding noise when washer is draining
something in the impeller housing. not usually serviceable. not sure if that unit has two pumps. you could look underneath the tub and try to determine that, and where the noise is coming from.
i am confident the issue relates to a pump unit.
good luck
mark
Oct 22, 2007 | KitchenAid KUDR01TJ Dishwasher
HP LaserJet 2430 Printer Logo
538 people viewed this question
Seeker5211
Seeker5211
