Question about Refrigerators
Is the condenser fan supposed to run continually? My Amana top freezer isn't cooling right and if I nudge the fan it will start spinning. Is there a control switch for the motor?
    President:
  • 1,902 Answers
To answer your first question no it is not suppose to run all the time. There is a relay that control the motor that is bad and you will need to replace it. The reason you can bump it and it works is because you are shacking loose the items inside the relay
Posted on Jun 04, 2010
Amana - Top freezer model ATB1915HR. Freezer is not cooling. The fan is running. Tried increasing and decreasing cooling settings. Emptied and cleaned out.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 31, 2011 | Amana ATB1830 Top Freezer Refrigerator
Amana refrigerator model #ARB1914CW fan quit running. quit cooling
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Apr 07, 2011 | Amana Refrigerators
My 1999 TX18 Amana Top Freezer/ Fridge won't get cold. I cleaned it, plugged it in. The light and fan work and it stayed cold for 4 days but it won't get cold.
heatman101
Apr 03, 2011 | Amana Refrigerators
Our Top Freezer Refrigerator, Amana, doesn't seem to be cooling sufficiently. Particularly the freezer. It's about 10 years old. I've vacuumed the condenser and grille at the back.
Refrigerator
heatman101
Mar 01, 2011 | Amana ATB2135HR Top Freezer Refrigerator
Fan works but not getting cold enough top freezer and the bootm freige
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Oct 07, 2010 | Amana ATB1832AR Top Freezer Refrigerator
Refrigerator not cooling...makes hissing noise
From your problem description I would say it sounds like maybe the condenser fan is not running. If that fan does not run, the compressor will overheat, and get very unhappy, LOUDLY. There is a fiberboard cover on the back of the unit, unplug the unit, remove the cover and inspect the fan, it should turn freely if you nudge it with your finger. If it does not turn freely, you will need to make it so by lube, removing foreign object (dead mouse once for me) dust dragons etc... or replace the fan if necessary.
Dec 16, 2009 | Amana Refrigerators
Amana Cooling Condensing Unit fan won't kick on
be aware that not repairing this asap that you are causing yourself more problems First I would change out the fan capacitor and see if this could be the problem. Secondly if the capacitor isn,t the problem change out the motor . By continuing to allow the system to cycle like this the compressor will take a dive on you costing more . Good Luck
Dave
Aug 04, 2009 | Amana PTH123B25AJ Heat Pump Air...
Condenser fan torque question (F'aire side-by-side)
It should not need help getting started and will hurt a little to stop with one finger also it will cause the sides of the frig to get warm maybe even hot around the door try puting a small fan behind the frig with the back panel off till you can replace the fan that will help you know if that is causeing your cooling problem
Mar 30, 2009 | Frigidaire FRS26R4A Side by Side...
Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Oct 29, 2008 | Amana ABB2227DE Bottom Freezer...
Refrigerators Logo
138 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
