Question about HP LaserJet M1522nf Multifunction Printer (CC372A)
What is the Hostname of hplaser jet M1522nf
I cant find the hostname of my hp laser jet M1522nf printer
    Sniper:
  • 126 Answers
Any queries regarding Ip-details, please log in to, http://www.ip-details.com/ which gives you the latest information and a accurate solution for your search.
Posted on Aug 18, 2010
  • 223 Answers
Print out a configuration report, go to the printer and press the set up key, look for reports, press ok, look for the configuration report and press ok, all of the settings and info will be listed on the report including the mac address as well as the ipv4 address, if you are installing on a network that should be all you need.
Al
Posted on Jul 16, 2010
4 Suggested Answers
POCBM
  • 121 Answers
SOURCE: Printed confirmation on faxes sent form HP Laser Jet Fax M1522nf
To get confirmation page do this:
1. On the control panel, press Setup ( ).
2. Use the arrow buttons to select Reports, and then press OK.
3. Use the arrow buttons to select Fax Reports, and then press OK.
4. Use the arrow buttons to select Fax Confirmation, and then press OK.
5. Use the arrow buttons to select the option for when you want the fax error reports to be printed.
6. Press OK to save the selection.
To iclude first page with report:
4. Use the arrow buttons to select Include 1st page, and then press OK.
5. Use the arrow buttons to select On, and then press OK to confirm the selection.
Posted on Mar 25, 2009
SOURCE: HP Laser Jet 1320 Printer installation
Just downloading the PCL5 driver was not enough for my computer. Maybe it is enough for other users' computers. But in addition to downloading the drivers, i had to also download and install the "HP Laserjet 1320 plug and play print driver solution" at the bottom of the driver list. Save the file to your desktop, double-click it and follow instructions to install, then reboot. Then when I checked my printer list, the HP Laserjet 1320 was there. I printed a test page, and now i am good to go. Hope this helps.
Posted on Jun 13, 2009
SOURCE: download driver for Window 7 the HP Laser Jet M1522nf MFP
go to folowing link you will get drivers for windows7
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=3442754&lang=en&cc=us&prodTypeId=18972&prodSeriesId=3442750&taskId=135
Posted on May 04, 2010
Cartige area jam in hp laserjet m1522nf
Open the cover and remove the toner cartridge, check to see if there is any paper or bits of paper along the path (check on the back as well).
Dec 30, 2013 | HP LaserJet 3050 All-In-One Printer
Tip
Requirements RedHat Linux (should apply to 7.x and up) This tutorial covers...
Requirements
This tutorial covers changing your hostname in RedHat Linux without having to do a reboot for the changes to take effect. I’ve tested this on RedHat 7.3, 9, Fedora Core 9, and RHEL 5.3. It should work for all the versions in between since they all closely follow the same RedHat configuration. What’s the point of this tutorial? Never reboot if you don’t have to and keep your uptime intact.
Make sure you are logged in as root and move to /etc/sysconfig and open the network file in vi.
cd /etc/sysconfig
vi network
Look for the HOSTNAME line and replace it with the new hostname you want to use. In this example I want to replace localhost with “MyServer”.
HOSTNAME=MyServer
When you are done, save your changes and exit vi. Next we will edit the /etc/hosts file and set the new hostname.
vi /etc/hosts
In hosts, edit the line that has the old hostname and replace it with your new one.
10.33.44.55 MyServer
Save your changes and exit vi. The changes to /etc/hosts and/etc/sysconfig/network are necessary to make your changes persistent(in the event of an unscheduled reboot).
Now we use the hostname program to change the hostname that is currently set.
hostname MyServer
And run it again without any parameters to see if the hostname changed.
hostname
Finally we will restart the network to apply the changes we made to /etc/hosts and /etc/sysconfig/network.
service network restart
To verify the hostname has been fully changed, logout of your system and you should see your new hostname being used at the login prompt and after you’ve logged back in.
Quick, painless, and you won’t lose your server’s uptime.
on Jan 13, 2010 | Computers & Internet
Tip
Change your Hostname without Rebooting in RedHat Linux
Requirements
This tutorial covers changing your hostname in RedHat Linux without having to do a reboot for the changes to take effect. I’ve tested this on RedHat 7.3, 9, Fedora Core 9, and RHEL 5.3. It should work for all the versions in between since they all closely follow the same RedHa tconfiguration. What’s the point of this tutorial? Never reboot if you don’t have to and keep your uptime intact.
cd /etc/sysconfig
vi network
Look for the HOSTNAME line and replace it with the new hostname youwant to use. In this example I want to replace localhost with“MyServer”.
HOSTNAME=MyServer
vi /etc/hosts
Save your changes and exit vi. The changes to /etc/hosts and/etc/sysconfig/network are necessary to make your changes persistent (in the event of an unscheduled reboot).
hostname MyServer
hostname
My printer is HP laser jet M1522nf series. It rotates inside while switching on but no display comes.
Formatter faulty,
Symptoms: No display, not recognized by system,if network cable connected to the port data transferring LED are wont glow or low brightness,
Sep 13, 2011 | HP LaserJet M1522nf Multifunction Printer...
My 7310xi worked fine on our network with my DELL VOSTRO 430 / WIN7 until 4 days ago. Than I ralized that I cannot scan from Adobe anymore and the HP solution Center reports that there is no printer...
first try to connect to the computer where the printer is installed be sure you can access the computer, then go to printer & fax if you dont see the printer there click on add a printer if ask location, select network printer double click that computer that appear in the network where the printer is installed then click next wait till finish then scan you document,
Aug 07, 2011 | HP OfficeJet 7310 All-In-One InkJet...
My pc is not seeing my printer. i'm using laserjet 1100, and using windows 7. i have installed the driver, but still no progress. thanks in anticipation. Akpoviri Paul, Nigeria.
There is no sign of hp laser jet 1100 printer in my pc which mean the programe of hplaser jet 1100 is downloaded in my computer or could be any other prob
Feb 03, 2011 | HP LaserJet 1100 Printer
How to install HP laser jet M1522nf and connect my
How are you connecting this printer to your computer ? usb or network ?
If its network i would recommend you to make sure that the IP Address on the printer matches with the one set on the printer driver on the pc
Tryn reinstalling the software a detecting the printer automaticly
Jul 07, 2010 | HP LaserJet M1522nf Multifunction Printer...
How to create subinterfaces on a 3845 series cisco router? I am trying to setup a trunk port for VLAN configuration. Thanks
Its like router on stick configuration??enter the interface which you have to configure and in that interface as mentioned below
Hostname(config)#interface FastEthernet0/1
Hostname(config-if)#no ip address
Hostname(config-if)#no shutdown
Hostname(config)#interface FastEthernet0/1.1
Hostname(config-if)#encapsulation dot1Q 1 native
Hostname(config-if)#ip address x.x.y.y < subnet mask >
interface FastEthernet0/1.2
Hostname(config-if)#encapsulation dot1Q 2
Apr 09, 2010 | Cisco 3845 Integrated Services Router...
Lexmark T644 network settings missing on menu
These are options that you must add via the Network Setup Menu.
Don
Jan 16, 2009 | Lexmark T644 Laser Printer
HP LaserJet M1522nf Multifunction Printer (CC372A) Logo
402 people viewed this question
Seeker5211
Seeker5211
