Question about Maytag Ensignia MAV2757AWW Top Load Washer
Washer won't spin and drain, repair man said it was the transmission and should cost over 300 to fix it????
  • Maytag Master
  • 43,501 Answers
If you are having a problem with your top load washer then check out this tip...
Washing Machinewasher won't spin and drain - 2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on Jun 05, 2010
Whirlpool duet fw95hedco washer won't spin at max speed & leaves all clothes wet. No error codes during tech diagnostic visit. Washer only 18 months old.
Possible Defective washer transmission. Do you overload the washer with heavy items like towels or blue jeans very often? That can cause early failure.
Feb 16, 2017 | Whirlpool Washing Machines
What will cause the washing machine to not spin fast enough to spin the clothes dry or not spin the fabric softener out of the agitator cup?
If your towels are coming out the dryest it is probably a problem with it being off balance. Did you make sure that the clothes are even placed in the washer. If you have a bunch of heavy stuff on one side and light stuff on the other side it could cause the same problem.
Dec 05, 2012 | Maytag Legacy Series Top Load Washer
The machine doesn't spin properly and doesn't drain the water
see this causes and fix it. God bless you
Lid Switch Assembly If the washer won't spin the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Motor Coupling If the washer won't spin the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission. Another common problem is the lid switch.
Drive Belt If the washer won't spin, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin properly.
Door Lock Motor and Switch Assembly If the washer spin the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Drive Block If the washer won't spin the drive block might be worn out or may have come loose. Underneath the agitator the drive block connects the inner tub (the one that spins around) to the transmission. If the drive block wears out the transmission shaft will still spin but the tub may not - or it may spin slowly. This also usually causes a lot of noise. The drive block is relatively easy to replace.
Clutch Assembly If the washer won't spin, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. The clutch is not repairable, if it is loud or not working properly it will need to be replaced.
Clutch Band kit If the washer won't spin, the clutch band kit might be worn out. The clutch makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. If the washer won't spin, this clutch band kit may need to be replaced.
Drive Motor If the washer won't spin the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged It will have to be replaced.
Tub Bearing If the washer won't spin the tub bearing might have seized. This is a common problem and relatively easy to replace.
Tub Seal and Bearing Kit If the washer won't spin the tub seal and bearing might have seized. This is a common problem and relatively easy to replace.
Bearing If the washer won't spin the bearing might have seized. This is not common. The bearing doesn't require any normal maintenance. They generally go bad when the tub seal fails and allows water to leak past into the bearing.
Basket Drive If the washer won't spin the basket drive clutch might be worn out. The basket drive sits on top of the transmission and engages with the inner tub. If the basket drive wears out the tub won't spin.
Basket Drive Hub Kit If the washer won't spin the basket drive hub might be worn out. The hub is a set of plastic gears underneath the agitator. The basket drive hub kit is easy to replace with standard hand tools.
Transmission If the washer won't spin the transmission might be worn out or defective. There are numerous more likely causes when a washer won't spin, which should be checked first.
Sep 28, 2012 | Hotpoint Washing Machines
Squeaky washer in spin cycle
you have a broken coupler...this is a plastic and rubber part that connects the motor to the transmission.  A $20 part
How good are you and your tools?
Mar 27, 2009 | GE WBSR3140DW Top Load Washer
Washer kenmore series 80 after wash or rense cycle wont start to spin when dumping water. Sears repair man says that is normal and I say it used to spin. what is the problem?
There is no problem, unless the drum doesn't spin at all.
In a wash or rinse cycle there is a neutral drain just before the spin. During the neutral drain, the drum does not spin. If you open the lid or pause the timer during the neutral drain, the motor will stop (same as the short pause just before the actual spin) and the "kicker" in the transmission will disengage the brake. At this point the drum will start to spin. The neutral drain prevents wear and tear to the transmission since the drum will be very heavy while it's full of water and wet clothes.
If it doesn't spin at all, you may have a problem with the motor coupling, the brake/clutch assembly or the transmission.
Hope this helps to clarify things.
Mar 02, 2009 | Washing Machines
Kenmore toploader spin cycle is slow leaving clothes very wet
I don't want to be the bearer of bad news, but it does sounds like it's the clutch. The clutch is not engaging fully and letting basket is not spinning enough. To repair this you have to remove the transmission which if you do not know what you are doing, you may do more damage then good.
A clutch job on a top load, would run approx $250-300 parts and labour. It's would cost just about the same to replace the machine.
Hope this helps. Good luck
Feb 10, 2009 | Kenmore 24032\24036 Top Load Washer
90 series top loading Kenmore washer
if it fills and drains but no agitate no spin it is likely the motor to transmission coupling easy fix 10 dollar part. chat can talk you through it let me know if you need help
Mar 29, 2008 | Kenmore 22422 Top Load Washer
Here are the answers to your questions about my washer
Based on your answers your basket drive is out in the unit this is a Major repair $300-$350 or so parts and labor you will have to weight the cost of a new machine verses the repair how old is the machine??
Feb 13, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Cloths remained wet after spin cycle
This is a direct drive washer and the trans is not hard to replace. You want to make sure it is the trans giving you the problem. The trans is covered for 5 years under warranty parts only. Other problems could be a worn spin tube, brake or clutch. Did the washer loose its nuetral drain? If your washer is over 8 years old, maybe it's time for a new one. Otherwise, check out the link for the trans. http://www.repairclinic.com/0080.asp Catriver..post back.
Feb 27, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag Ensignia MAV2757AWW Top Load Washer Logo
166 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
