Question about Dewalt DW056 18 Volt Cordless Impact Driver - 1/4" Drive Hex Shank (Battery Charger and Case Not Included) - Tool Only
Only full power for full trigger pull
no slow speed
  • 34 Answers
I had same issue with Metabo hammer drill. It was faulty triggrer. Replace it and it shoul be fine.
Juraj
Posted on Jun 08, 2010
Acquired snap on ya219 that didn't weld. Replaced the capacitor. Powered on and struck an arc on the the ground lead. I removed the welding wire and noticed that when the wire speed was turned all the way...
Could be a shorted output rectifier (diode). This would cause a lot of current pull, and therefore voltage drop (fan slowing down). The electrolytic capacitors are for dc voltage, and will blow with wrong polarity, which means ac voltage would be the wrong polarity half the time.
Feb 27, 2015 | Snap-On Welding Tools
I have a 16 horse v twin on my power washer,every time i pull the trigger the engine slow down
When you pull the trigger the motor comes under load as the pump starts to work at full pressure. Check for throttle control and setting for engine speed under load.
Apr 20, 2013 | Briggs & Stratton Briggs Stratton Vanguard...
Low output on 110 when using power tools
Take and plug in a variable speed drill now when your generator is powered up slowly hit the trigger on the drill start it at low speeds run it for 30 seconds then give it half speed for 30 then full speed fo 30 seconds then try your chop saw
Nov 25, 2012 | 5.5 HP GX160 Engine
My drill stopped running, the battery is charged,but wont turn. started only working in certain positions then quit alltogether
It sounds like the switch but check the brushes on the motor and the connections from the switch to the motor.
May 31, 2012 | RTO Drills
Wall chaser running slow
Check bearings or bushings
May 16, 2012 | Hand Tools
Engine starts but dies when I pull throttle trigger
you need to adjust the high speed needle turn it out in 1/4 increments as you throttle it, low speed may have to come out alittle but do high speed first. I had to answer this as I use to have a pastor john in sturgeon bay, miss him alot.
Jul 22, 2009 | Ryobi Garden
Poulon Wildthing 18" Gas Chain Saw
Some Poulans vent thru a fuel line going from the tank to the carburetor. Some vent thru the cap but eventually the duck bill valve starts leaking fuel. Then I suspect some people change that cap to one without a vent, which causes the problem you are describing.
Sep 11, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Dewalt DW056 18 Volt Cordless Impact Driver - 1/4" Drive Hex Shank (Battery Charger and Case Not Included) - Tool Only Logo
167 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
