Question about Maytag MDE2400A Electric Dryer
Drum is binding - Maytag MDE2400A Electric Dryer
  • Maytag Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryerdrum is binding - 2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
Posted on Jun 08, 2010
How do I adjust parking brake
If Disc brakes jack up wheels , make sure the cable is not binding or frozen , pull hand leaver on three clicks, adjust cable till brakes just start to bind, release hand brake and check the wheels are free to turn. Drum brake check cables are free, back off cable till slack, check lining to drum adjusters are free and adjust if need be, pull hand brake on three clicks, adjust cable so brakes just start to bind release hand brake and make sure the wheels are free to turn ,
May 27, 2015 | Cars & Trucks
Whirlpool duet dryer drum binding up after replacing belt. What should I look for?
  • The drum has to be seated properly on the front and back panels. The rollers that the drum rides on have to be free and not in a bind. The belt has to be installed properly thru the the idler.
Oct 04, 2014 | Whirlpool Dryers
The back brakes on my 02 cavalier started to lock up the back tires when I hit the brakes. I put new brake pads an wheel cylinders on both sides. It was really hard to get the drums back on and now(1 week...
Sounds like the brake shoes are binding on the drums. After a run put your hand on the drum (carefully) and confirm that excessive heat is not being generated by binding brakes.
If it was hard to get the drums on It may be that the adjusters were not backed off. This is normally done to get the drums on and then the brakes adjusted in the usual manner.
Dec 15, 2017 | Cars & Trucks
Konica c353 double side print
ARE you sure you have checked the box on print properties on you computer that says either left binding or top binding have to let the copier know which way to do binding will go so you don't have to flip the paper over to read correctly or it will be upside down on the other side. Left binding like reading a book,top binding like a classroom lecture notebook.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 02, 2012 | Konica Minolta Konica Bizhub C353 Drum...
Dryer won't start.. has power sounds like something binding. long buzzing sound when starter depressed. try once or twice and then nothing for a while. come back try again ..long buzzing sound again
Hi and welcome to FixYa, I am Kelly.
You did not include a make and model number for your dryer so... this is a GENERIC response. With a make and model number we can better help you.
The long buzzing your hearing is the motor winding trying to start the motor. After 30 - 45 seconds if the motor does not start the thermal overload will cycle and prevent further attempts for around 5 - 6 minutes until the motor winding cools down.
Causes of a dryer motor not starting:
1. Binding.
a. Broken dryer fan blade lodged inside the blower housing
b. Motor start switch failure
c. Motor bearing failure
2. Dryer drum bearing / roller problems
a. The drum can be bound up and dragging on internal components of the dryer
b. The Idler pulley bearing may have failed and it is now a brake.
c. Front or rear drum seals failed / pinched against rear or front of the chassis
d. Drum roller bearing failure and is now a brake.
Reach inside the drum and see if you can turn the drum. If you can not turn it with a little effort, you need to find out where the binding is inside your dryer.
This is the best I can do for the moment without a model number. With a Make and Model number I can provide parts listings and item numbers of where to check.
Thanks for choosing FixYa.
Kelly
Feb 06, 2011 | Dryers
Cirrus 2000 rear brake jam
if it's drum brake, remove the drum and check for dust collected inside the drum. also check the emergency brake cables for free of rust and are not binding
May 25, 2010 | 2000 Chrysler Cirrus
Hey when we turn on our dryer we get a burning smell and the drum doesnt turn, any ideas? we think the engine might have burnt out?
Either something is binding the drum, or the motor has failed. Can you turn the drum by hand? If you can, then most likely the motor has failed, if you can't turn it by hand, then the drum is stuck and the motor just isn't able to turn it until you find whatever is binding the drum. You might have to remove the back panel to get in to see what might be causing the problem if it is binding.
Let me know what you find with this.
Benjamin
Feb 06, 2010 | Kenmore 62602 Electric Dryer
Will not start consistently. Will make humming
This is a very hazardous condition and you should not use the dryer until it is repaired. First, unplug the dryer! Then, remove the front panel screws (if any), and gently pry it off of the cabinet, door and all. The panel is usually retained by steel clips. Next, check for foreign objects that may be causing the drum to bind. Whether you find anything or not, slide the drive belt to the rear and lift out the drum. Notice how the drive belt is routed through the motor drive pulley and belt tensioner.
Inspect the motor, drum suspension rollers, and belt tensioner for any binding or discoloration. However, if the motor was throwing sparks, replace it. Check wiring harness and connectors and repair or replace if damaged.
If any drum suspension rollers or the tensioner pulley binds, replace them. They're relatively cheap. Upon reassembly, make sure the drive belt is routed correctly around the tensioner before reinstalling the drum, being careful not to twist the belt. Upon reinstalling the front panel, turn drum by hand at least two revolutions -- it should turn smoothly. Plug it in and test the operation.
Jul 09, 2009 | Dryers
Binding brake
hand brake cable adjuster lives under centre console at rear 10mm spanner required unadjust this and then remove rear drums to adjust linings so they just drag on drum then go back and adjust cable in car
Jun 03, 2009 | 1999 Daewoo Lanos
Maytag MDE6000AYQ Dryer
ritz, it could be the motor, but eliminate these other things first. You want to make sure you don't have a drum roller in back binding, I see a lot of this on Maytags. Another would be the blower wheel, it could be binding or have something stuck in it. The blower wheel will be in front. You will have to remove the door, remove the screws holding the hinges in, the door will lift up and off. Then the spacers on the other side. Now the front panel will pull out and off. Here you can get a look at the blower wheel, and rear rollers. Just hang the door back on and close it to run it. You may have to remove the front drum support and remove the tumbler to get into it further if necessary. Catriver.
Jan 05, 2008 | Maytag Atlantis MDE6400AY Electric Dryer
Maytag MDE2400A Electric Dryer Logo
127 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
