Question about Frigidaire FRS26R4A Side by Side Refrigerator
Where is reset button for ice maker - Frigidaire FRS26R4A Side by Side Refrigerator
4 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: Ice maker only produces crushed ice
not really a reset button but htere is a solenoid that controls the type of ice coming out of dispenser. with the ice bucket in place give a look at it from underneath and find the brass rod spanning from front to back of bucket. that rod hooks into a solenoid catch that when activated lifts the rod up and down for crushed/ or cubed ice.. after locating the "hole" in which the rod enters you should also see a corresponding plastic ring that would catch the rod upn activating stich and pull/up and down.. Ill assume that the "catch ring" is tuck in the up positon , might only be frozen up in which case you can hit it with a hair dryer to melt it, its also possible that the \solenoid had melted it self in the up position in which case you need to replace it.. to check this theory you can hook the brass rod into the ring assy in which case youll only dispense cubed no crushed
Posted on Nov 03, 2008
  • 3 Answers
SOURCE: Ice Maker quit making ice cubes
Look on the bottom of the rectangular motor housing for the ice maker. This is the white box that holds the front end of the ice tray. In the past, this was normally a small patch of black 'runner' that covered the switch and helped kkep moisture out.
If you cannot locate it by feel, try using a small mirror and a flashlight to help you locate it.
Posted on Jan 14, 2009
nanbuenbrazo
  • 553 Answers
SOURCE: The lock light for the ice maker keeps coming on
this is normally happen to most fridge wich has an electronic board controller, this is due to the moisture that causes your electronic board shorted and malfunction.
have it clean first, but if you do not know how to dis-assemble the part I suggest have it services by a technician to avoid more damages.
Posted on Nov 05, 2009
The Ice maker is not making ice. The water is on is there a reset button?
No Reset call the manafacture or go the Store where you bought it and get an Exchange sound like its defective
Mar 06, 2017 | Refrigerators
Where is the reset button on the refridgerator ice makers.
4X??????? Hard to fathom you got 4 bad units in a row.
Check internal freezer temp. If not less than 10 degrees the thermostat inside the ice maker will not allow the unit to cycle and make ice. The issue could be with your refrigerator and not the ice maker.
Sep 26, 2016 | Refrigerators
I have to press the reset button to get the ice maker to release the ice.
Hello Christine;
My name is Peter. I am a retired field service refrigeration technician, living in Baltimore, Maryland, USA.
You have not provided a model number so I will address the basics of a ice maker. There are many different kinds.
Not many ice makers have reset buttons. If you have a ice maker with a red reset button in the front you probably have a plastic flex mold. Your ice maker like many others has a control module assembly at the front. This module is actually a computer with a circuit board and a motor. The module tells the ice maker solenoid valve to open and fill the mold with water and what volume of water. Then the temperature sensor tells the control module that the ice cubes are frozen. The module turns on the motor to harvest and flex the mold.
Under your ice maker mold has a white wire beneath it. This is the temperature sensor. Your temperature sensor has failed. This is an solid state part of your ice maker and not replaceable. The ice maker that you have is not repairable. Some ice makers are repairable, but not yours.
When you push the restart button you are forcing your ice maker motor to turn on and harvest the ice cubes.
Normally you should get 8-10 ice cube harvest within a 24 hour period.
Nov 23, 2014 | Refrigerators
My ice maker model RS2545SH does not work I could not locate the reset button How to fix please
Have you checked the temperature, inside of the freezer? It must be at least, 0 degrees, before the water will freeze into ice. Is the ice maker getting power? Why do you need to find a reset button? I don't know your ice maker. I've never heard, of a rest button on an ice maker. Your question isn't specific enough. Other than that, I can't help you. Good luck.
Sep 07, 2014 | Refrigerators
Ice maker stopped working on bottom freezer amana. Is there a reset button?
There is n such reset button,but first check and confirm that water line is running in to the ice maker drawer.Is the water getting into icemaker or not.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Amana ARB2214C Bottom Freezer Refrigerator
The refrigerator icemaker does not make ice.
you have to hold in the ice type and the childlock button for about 6 seconds and that will take the filter light off. To reset the ice maker open the freezer door and then pull out the ice bin. on the bottom of the ice maker theres a button that you have to hold in to reset the ice maker. Good luck and thanks for using FixYa
Jan 21, 2009 | Samsung RS2534 Side by Side Refrigerator
Amana Side-by-Side Fridge Model SBD21VPSE Problem started when water stopped flowing from in-door dispenser and ice maker stopped making ice. I emptied fridge and freezer, left unit off for several...
If there is a reset button on your ice maker try pushing it. Many ice makers have two holes for reset. A general rule of thumb is if the ice maker fingers are stopped in a slightly vertical position then your ice maker unit is working. If the fingers are stopped anywhere else then it needs some sort of attention or replaced. Make sure there is water, or ice in the ice maker tray, if not then the problem is with water supply.
Nov 29, 2008 | Refrigerators
Ice maker not working.........
Reset button on the bottem front right of ice maker
Jul 22, 2008 | Samsung RB215LASH
Ice maker
1 may have frozen water line
2 reset ice maker press in ice lever 5 times
3check check ice maker plug
May 03, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Frigidaire FRS26R4A Side by Side Refrigerator Logo
370 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
