Question about Refrigerators
Our samsung refrigerator model number RS25455H has a problem keeping it cool enough I have it set at the coolest settings and it never reaches it , what should we do?
  • Refrigerators Master
  • 43,501 Answers
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigeratorour samsung refrigerator model number RS25455H has - 2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on Jun 04, 2010
How to change the temp in a frigidaire galaxy refrigerator
Units will vary give or take a few degrees from the control panel display. Keep in mind once you change the temperature it will take up to 10-12 hours to stabilize and reach that temperature. If the unit is not cool, even at the bottom of the refrigeration portion (where the coolest air will be found) then contact a professional to diagnose the control pane and board.
Dec 29, 2012 | Frigidaire FGHB2844L (27.8 cu. ft.) French...
My Samsung Refrigerator can not keep the set temperature.
Normally your fridge is set +2 degrees C. with a differential of 3 so when it reaches +5 it should switch back on. if this is not doing this then a new thermostat may be in order.
Apr 16, 2010 | Samsung RB2155 Bottom Freezer Refrigerator
Not cool enough
can you cofirm what your model number is,this will be on a tag inside the fridge behind the salad box or behind the bottom draw in your freezer.
Aug 02, 2009 | Refrigerators
Freezer works fine, refrigerator only cools to 58 degrees on coolest setting!
replace the evaporator fan, this fan problem is hard to diagnose because the fan will spin but not fast enough to circulate the chilled air thru the freezer and the refrigerator. The minimum cost to repair/replace is around $300.00
Jul 29, 2009 | Refrigerators
The refrigerator and freezer both are to warm. We have them set on the coolest setting and it keeps running and won't cool enough to put food back in.
see if you have frost running down the back wall of freezer. if you do remove panel and defrost evaporator..there would be a defective part in the defrost system if this is whats going on.
if not, check to makes sure the freezer fans are running and condensor fan is running. a failure of one of these causes the same problem..lastly, make sure compressor is running, not just condensor fan motor. do you hear a click every few minutes? if so, maybe a bad relay. there is no model for me to go on, so check these first...Bruce
Jul 26, 2009 | Refrigerators
Freezer, Ice Maker and Water dispenser not working
it has to get down to the proper temperature after the reset the set point is -4 for the freezer and 38 for the refrigerator. the numbers shown o\n the digital display panel stands for the actual temperatures. When the compartmnet tempertures go down, so do the numbers on thge display panel, and finally they reach the set temperatures. Once the system is stabilized , the display tempoeratures are the set temperature.
Jan 26, 2009 | Samsung RS2578BB Side by Side Refrigerator
Refrigerators Logo
157 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
