Question about Sony Computers & Internet
Hi, I have a VAIO model PCG-6L1L. Some liquid was spilled on the keyboard and the next day the LCD and the connector for an external screen is not working. The laptop seems to bootup just fine I just can't see anything. I was told the video chip on the motherboard was bad and since it is soldered on I have to replace the motherboard. Is this true and do you have this motherboard? Todd
SOURCE: LCD flashes and flickers, partial display of bootup and then black screen
Try the following:
Sometimes when you press and hold the corners of the LCD area (not on the LCD itself, but on the frame), and see if it gives you a picture (or at least flickers when you do so).
My opinion is that your LCD could need rewiring or replacing.
Posted on Dec 15, 2007
  • 135 Answers
SOURCE: sony pcg-fx140 bootup problem
1. check bios for first boot option to hard drive.
2. If xp, run repair from cd (enable cd boot in bios).
Posted on Feb 16, 2009
  • 34 Answers
SOURCE: I spilled sticky liquid on my Sony Vaio PCV-W1/G
Yes you can buy a replacement.
Posted on Dec 30, 2009
  • 109 Answers
SOURCE: Hi. I have a Vaio laptop that worked fine. Now it
Is the laptop getting very hot if so then the laptop is turning off because of this. You will need to get it cleaned out around the fan, if you are still getting the same problem after this you could ues one of these USB cooling fan stands. i use one with my acer6530g when i am working with it for hours at one time. hope this helps.
Posted on Jul 22, 2010
Sony vaio pcg 4a1l blank screen after replacing a new screen
Take it apart again, remove housings, disconnect cables, reconnect cables, and then power on. If that works then re-assemble
Oct 18, 2013 | Sony VAIO Computers & Internet
I have spilled just a spoon of water on my laptop, after it the keyboard is not working a t all, i cant even log into bios. i have sony vaio vgn z series laptop, i tried to delete the driver, and when...
When this happens, you should fully disassemble the laptop & thoroughly inspect its inside. Look for any traces of liquid on the circuit boards & on other components. On circuit boards, liquid damage appears in the form of whitish traces. These needs to be wiped off. This can be done using a tooth brush moistened with few drops of hand sanitizer liquid.
Check all internal connectors & make sure that no liquid seeped into them. Dry them if needed.
When you are done, re-assemble back the laptop.
If the liquid fell on the keyboard & you found out that the keyboard is no longer working, then you will have to replace the keyboard.
Jan 16, 2011 | Computers & Internet
Vaio notebook cloudy/hazy/streaking display following spill
nothing we can do for this problem. throw it away and get a new one
Feb 27, 2017 | Sony VAIO VGN-FE670G Notebook
Hi . is vgn sz430n the same as PCG 6Q1L ?? I
Yes, VGN-SZ430N is similar to the PCG-6Q1L.
The only difference between the two coding is that the first one is the model # of the Computer used by the technical support team or sales support team for providing assistance however, the later is the Hardware configuration code of the Computer that categorizes a few models.
Oct 01, 2009 | Sony VAIO VGN-SZ430N/B Notebook
I have spilt coffee over my Sony Vaio PCG-FX501 and now it will not boot. I would like to try to repair it but don't know where to start. Can anyone help please?
if you've spilled sugary liquids over electronic devices, the most common problem is power supply. The power is not getting through to your laptop. Try taking out all the power supplyl; ac power cord, battery, and any other external devices (ipods, usb cables, etc.) Next, dry out your laptop. The most effective way, for me at least, is to open your laptop so that the keyboard and screen is perpendicular to each other Then, turn it upside down and let it hang over the desk. This way the keyboard part is resting upside down, while the flat surface is resting on your desk while the screen hangs over the edge
Jun 15, 2009 | Sony Computers & Internet
Screen is white
You could have a video controller problem or a LCD screen problem, what you are seeing is the backlighting but no video information.
To check if you have a video problem, connect an external monitor to your laptop and bootup your laptop, if you see Windows booting up the external monitor then the video controller is OK, and your problem is the LCD screen or the video cable connection on the motherboard (may need reseating).
If you cannot fix the LCD screen then use your laptop with an external monitor.
Jan 28, 2009 | Sony VAIO PCG-Z1WAMP2 PC Notebook
Spill on laptop..how do I clean
ok -
First:
Disassembly guides with pictures:
How to remove keyboard.
http://irisvista.com/tech/laptops/ToshibaA55/SatelliteA55_remove_keyboard.htm
Remove laptop LCD screen. http://tech.irisvista.com/laptops/ToshibaA3/remove_laptop_LCD_screen.htm
Second:
ONLY clean with 95% - 99% rubbing alcohol, then wait till COMPLETLY dry before re-assembling.
Hope this helps.
Jul 03, 2008 | Computers & Internet
LCD laptop screen
It is definitely the screen or the inverter. Usually the screen and inverter come as one piece. I would check with the manufacturer. Unfortunately for you, the LCD is one of the most expensive parts to replace on a laptop.
Just the simple fact of you mentioning that it works fine with an external monitor tells me that its not the video card. If it was the video card, you would see the exact same thing happening on your external monitor as well.
Hope this helps!
Apr 22, 2008 | Sony VAIO PCG-K23 Notebook
Computers & Internet Logo
94 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
