Question about Danby Heating & Cooling
Bought a Danby Premiere DPAC11010 and when I plug it in I get an E1 code on the top panel. Unit won't come on.
4 Suggested Answers
SpotBert
  • 231 Answers
SOURCE: We have a Danby A/C
E1 is a problem with air filter.
Clean or replace the air filter. Make sure filter is seated properly.
Posted on Jan 03, 2009
  • 20 Answers
SOURCE: we bought the danby Premiere
check service tag on unit what is the amp rating on the unit does it exceed your breaker size??
Posted on Jul 03, 2011
  • 50 Answers
SOURCE: i have the portable danby
The water is being removed from the air, you need to empty the water out of the unit as needed, sometimes as often as every two hours, the beeping is a water tank full alarm telling you to empty the tank as per instructions, there is a drain plug on the bottom of the unit you may want to move the unit to a drain until you know the amount of water the tank holds so you know how big of a containor to use
Posted on Jul 22, 2011
I have a Danby Premiere mobile ac unit and it has been working just fine, as of yesterday it all of a sudden just quit working. I can plug it in and it will run for a few seconds and then quit. once i
Hi There,
I would like to help you with this but I need some more information.
Is the display showing any error codes?
Is there a red light blinking?
From what I have learned from a technician, with the weather being so hot and humid in most areas it is likely that the water bucket is full.
If this is not the case, please either respond to the questions above and I will look into this further or you can contact our Customer Service department at 1-800-26 Danby for assistance.
Thanks!
Jul 18, 2012 | Danby Premiere Series DPAC12010H 12,000...
I have the portable danby premiere #317825 model#DPAC11010 its the 3-1 portable air conditioner we just got it last summer and today for the 2nd time in the last month it is shutting its self off there is...
Jul 22, 2011 | Heating & Cooling
We bought the danby Premiere DPAC 13009 for our trailer and it is blowing the breaker.
Jul 03, 2011 | Danby DPAC13009 Air Conditioner
E1 CODE ERROR
E1 code for the primary humidity sensor behind right side grill. Unit MUST be unplugged from outlet. Take right side grill out, unplug sensor from wire socket and plug back. If no help, you need new sensor.
Dec 30, 2009 | Danby DDR451 Dehumidifier
My DANBY Dehumidifier model DDR4588EE has been working ok until it showed a E1 error code and since then it does not work properly. Any ideas please?
Dec 30, 2009 | Dehumidifiers
My model DDR6588EE dehumidifier runs for a while and then stops displaying an E1. If I hit power button it will run a while and do the same thing. This also happens on Continuous mode. Is there some thing...
Dec 25, 2009 | Danby DDR6588EE Dehumidifier
E1 code flashing on my air conditioner
E1 indicates that it is time to clean the air
filter hope it helps
Jul 26, 2008 | Danby DAC8003D Air Conditioner
Danby Dehumidifier
I dropped the water bucket by accident on the dehumidifier, and I have the same problem. Here what I found :
First, remove the water bucket and find the circuit diagram, it is very useful.
E1 code is related to the room humidity sensor, E2 code is related to the room temperature sensor and E3 code is related to the safety thermistor sensor. If you have one of these error code displayed, you will probably have to replace the sensor.
The humidity and temp sensors are located on the same board. To access it, remove the water bucket and you will see the 2 screws holding the front panel. Remove the screws, then gently prayed the front panel. Be careful, there is two plastic clip on the top of the panel and they are really easy to break. The board is located at the top right, under the cover. The safety thermistor is located on a pipe on the right side of the dehumidifier.
Aug 02, 2006 | Danby DDR583R Dehumidifier
Heating & Cooling Logo
396 people viewed this question
Top Danby Heating & Cooling Experts
Dan Webster
Dan Webster
Dennis Boxerman
mintvl
Level 1 Expert
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
