Question about Poulan 38-Inch Steel Deck 15.5 HP Briggs & Stratton I/C Engine With 5 Speed
16 HP briggs and stratton poulan severe flooding
When you let it set overnight the cylinder floods with gas and locks the motor the only way to start it is to take the sparkplug out and crank over the engine to blow out the gas before it will start.Why does it flood so bad?
    President:
  • 1,902 Answers
The carb is not closing down properly. You will need to either rebuild the carb or just replace it. Basically the float is staying open after you shut the machine down. Please rate
Posted on Jun 04, 2010
My 5.5 hp Briggs & Stratton pressure washer won't start and gas leaks out of the air intake after several attempts on trying to start.
sounds like it's flooding . it could be a spark problem it could be that the carb needs to be rebuilt i would check for spark first you could also run a compression test on the engine . also keep in mind some times if your pump is clogged it will not let your engine start and will be hard to turn over .
Oct 27, 2013 | Briggs & Stratton Garden
Briggs and stratton 13.5 ic will not start keeps flooding
You need to adjust your float in your carb.
May 08, 2012 | Poulan Garden
Engine pops, wants to start,fresh gas,every things been gone through
Needle valve on the carb isn't set right. Try adjusting it and see what happens. Also, make sure it isn't flooded. Sounds like it is
Aug 04, 2011 | Briggs & Stratton Briggs Stratton Intek V...
16 h v-tech briggs-stratton is blowing oil into carburator, what could cause this problem and possable solutions
see if the oils coming out of the rubber hose by the air cleaner ,if it is it could be the pcv valve the rubber hose is connected to. order could be too much oil in the engine, sometimes the carburetor will flood the crankcase with gas , you have to rebuild the carburetor and change the oil.
Feb 18, 2011 | Briggs & Stratton Briggs Stratton Vanguard...
Engine won't turn over
Is the engine flooding the cylinder with gas and hydro locking it? Try pulling the spark plug and seeing if the engine can be turned over and keep note if any gas comes out.
May 07, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
I have a briggs and stratton 14 hp ohv engine on my murray lawn mower it starts and runs good until i go to full throttle or engage the blades then it seems to flood out and start backfiring i can lower...
It sounds like you are putting it into choke mode. The choke is usually all the way up on tractors. And it will make it backfire and flood out. Just rev it high enough to work and don't go into the choke mode. hope this helps.
Apr 21, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Craftsman 19.5 - keeps flooding getting too much gas
I think that you have a sticking float in the carb. You probably will have to rebuild it. hope this helps
Sep 19, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
17hp b/s intek OHV after 30 min mowing starts running rough
if gas is in the oil the needle and seat in the carb are bad or some thing in it. the gas will go in to the crank case and load the cylinder with gas. you can take the carb apart to see if something is in the seat. or replace the carb
Jul 26, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Murray riding mower 12.5 hp briggs & stratton spitting oil & gas out of carb & muffler when trying to start
Drain oil... it is full of gasoline due to a bad float pin and rubber gromet in your carb. When your float pin and gromet fail, gas just keeps flowing into your carburetor, eventually flooding your motor with gas and oil mix.
Jul 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Poulan 38-Inch Steel Deck 15.5 HP Briggs & Stratton I/C Engine With 5 Speed Logo
726 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
