Question about Garmin nuvi 765T GPS Receiver
Unit began posting a message "Acquiring satellittes". This message never left the screen and after and hour or so the screen went blank and the unit has been dead ever since??
  • Garmin Master
  • 3,289 Answers
Make sure the device's internal batteries are charged - or connect to the car charger. If the unit will not turn on, connect via USB cable to your computer's USB port overnight, before trying again.
With a clear view of the southern sky (in other words: not indoors, under heavy foliage, or between tall buildings), turn the nuvi ON. It can take anywhere between 1 and 2 minutes for the nuvi to get a "fix" from a cold start like this. It is best to be stationary to get the fix if having difficulty. It is not uncommon for the nuvi to take up to 20 minutes to get its very first fix (since leaving the factory). After that, a fix may be had sometimes in as little as 30 seconds.
please rate this reply if found to be helpful - good luck!
Posted on Jul 08, 2010
Greetings . . . I turned my Garmin 2720 on in my
Take the GPS out of your van to an area with a clear view of the sky. Power the unit on. If the unit is working correctly, then it will acquire the satellites. You can then put the unit back in your van. You may have to reposition the unit to keep the satellite lock.
If the unit does not acquire satellites outside, then the unit is defective.
Mar 03, 2017 | Garmin StreetPilot 2720 GPS Receiver
Won't boot up. Error message "
did you try pluging into charger, my galaxy 2 if i run battery all the way down it wont do anything after it shuts down. at times i have had to plug in and wait sometimes 15-20 min before it will even flicker. hope it helps
Dec 31, 2012 | Cell Phones
Lines on screen
The screen has a connection for each line on the display and the soldier on some of these connections has gone intermittent. When the unit becomes warm enough, the soldier expands and the connections become more consistent.
If you're skilled, this can be repaired. If not, either replace the unit or take it to a reputable technician.
Nov 01, 2017 | Jensen VM9424 Car Video Player
My garmin 210 just went to blank screen
saving activity is due to a voltage problem check your connections and don't leave it in the sun!
Sep 06, 2012 | Garmin Forerunner 210 - Unit Only
I own 3 of these. Two of them have been hooked up for over 3 years and worked perfectly until yesterday. All of a sudden, the remote wouldn't work and I couldn't turn the unit off with the power button. ...
If you are using these DVRs over the air only, with 1.2.06 installed you have to run the G* Test in the 9012 menu, to get the digital data going, after removing power. That is why your clocks are --:--. I highly recommend that you update the firmware in both of these units to 1.2.21, to avoid having to mess with the G* Test.
Aug 17, 2010 | Sony DHG-HDD500 400-Hours Video Recorder
Lose satellite signal unable to reconnect until unit off for hours, have tried turning of GPS and turn back on. Turn simulates on and off but still it does not reconnect and the unit is in a clear space...
If your nüvi is no longer acquiring satellites please read the article linked below to ensure that this is not being caused by something in your environment:
Why won't my unit acquire satellites?
If after reading the above article your unit is still having problems, please ensure that your unit's software is up to date. You can do this by using our WebUpdater® program.
If you have tried all of the above suggestions and your unit is still not acquiring satellites, you can perform a master reset by doing the following:
Note: A master reset will erase all waypoints or favorites and will restore your unit to the default factory settings.
Follow the steps below to perform a master reset on the nuvi 2xx, 6xx, or 7xx:
  1. Turn the device OFF.
  2. Place your fingertip or the eraser end of a pencil in the bottom right corner of the touchscreen
  3. While pressing down on the screen, power ON the unit and continue pressing on the screen. A message displays to confirm if you really want to delete all user data?
  4. Touch Yes.
  5. The unit will now restart.
  6. Follow the onscreen prompts to set up the nuvi.
Once the reset is complete, please place your unit in an area with clear view of the sky until it acquires satellites. If you are still having issues please contact product support at (800) 800-1020
Aug 07, 2009 | Garmin nuvi 205W GPS Receiver
Acquiring Signal
Try resetting it to defaults if you haven't done that yet. I had a similar problem with a Stratus 4, and that took care of it for me.. Sounds like perhaps some kind of NVRAM gets corrupted and a full reset clears it up.
Good Luck. Hope it helps you like it did me.. Just remember to jot down all your presets first, because you will need to reset them.
Jun 03, 2009 | Sirius Satellite Radio Receiver
Trouble acquiring satellites
Garmin nuvi
will not acquire satellites
Apr 30, 2008 | Garmin StreetPilot C330 GPS Receiver
GPS screen went blank
My problem exactly. Unit would start up, acquire satellites, then the screen would go blank with a single vertical line. Unit would not respond to buttons or even turn off. Unit works fine after I did the reset:
- w/unit OFF, press and hold QUIT+DOWN+MENU
- press and release the power button, release DOWN, keep holding QUIT+MENU for 5 seconds.
- unit prompts something like: "erase all data;" choose yes.
- you will lose waypoints, etc.
Go to the Garmin support area for details.
http://www.garmin.com/garmin/cms/site/us/support/searchsupport
Search for: "How do I reset my gpsmap 76"
Oct 06, 2007 | Garmin GPSMAP 76 GPS Receiver
I cannot acquire satellites signal. What to do ?
I experienced the same problem about acquiring satellite signal even when it's a clear sunny day. After 30 mintues, it was still searching! The unit appeared to have "stuck" in this acquiring mode. The following worked for me: 1) open the GPS antenna 2) press the bottom left screen while holding the power button to turn the unit on 3) enter maintenace mode 4) select diagnostics 5) clear error report, do NOT clear any user data 6) restart unit the usual way My GPS 350 was able to acquire satellite signal in less than 1 minute after the above steps were taken.
Jul 21, 2007 | Garmin nuvi 350 GPS Receiver
Garmin nuvi 765T GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
