Question about Dishwashers
The pump keeps running untill it's turnd off at the mains model AEG
    President:
  • 1,902 Answers
You have a bad pump. basically once you kill the power the pump shuts off. Which tells me that the control board is telling the pump to shut down but the pump is not understanding what it is supposed to do so it continues to run. By replacing the pump everything will work fine again. You can go to your local appliance store and buy a new pump and install it. It will come with a set of install instructions
Posted on Jun 04, 2010
AEG FAVORIT DISHWASHER, PUMP KEEPS GOING WHEN TURNED OFF, UNLESS TURNED OFF AT MAINS
check the sum pump drian valve make sure it not cog up with tash because if it block can cause the drain pump to ruin ok
Nov 02, 2017 | AEG Dishwashers
E1O DISPLAYED
The other E10 fault is a clogged drain pump. Instructions to clean and free this are in the user manual obtained here. http://www.aeg.co.uk/Support/Manuals/
Peter Kay
Mar 08, 2014 | AEG Lavamat 16810 Front Load Washer/Dryer
Pump will not stop running
It is difficult to answer the question with so few symptoms. The question would be whether the pump stops when you open the door? If not, then should checked for correct door switch, otherwise I think you need to replace the main board. If you see diagram bellow you can see that the motor is driven by the triac which is probable remain in the open position and constantly power supply motor. Some model has relay which switch between wash motor and drain motor and there is possible that relay stuck and motor also running constantly.
22778750-fvdtzpxoyys0i2rs1v4qjxt5-4-0.jpg Dado
Jan 09, 2014 | AEG 21 in. Favorit 45250Vi Built-In...
Error c3
http://www.aeg.co.uk/Support/Troubleshooter/?Command=Detail&CatId=98&SymptomId=1412&DetailId=1412shows AEG's meaning for a C3 error code
Feb 06, 2013 | AEG Washing Machines
MY 2000 3.0 JAGUAR S-TYPE WAS ALSO RUNNING FINE ONE DAY WHEN I WAS COMING HOME 4RM THE STORE PULLING INTO MY DRIVE WAY MY CAR WAS ALSO RUNING FINE NO SIGNS NO SHAKING NOTHING AT ALL AND IT HAD HALF TANK...
SOUND LIKE FUEL PUMP NOT WORKING.TURN ON IGNITION SWITCH LISTEN FOR FUEL PUMP NOISE.SEE IF PUMP RUNNING IN FUEL TANK.IF NOT CHECK FUEL PUMP FUSE AND RELAY.IF ALL IS GOOD FUEL PUMP FAULTY.HAVE CAR CODE SCAN FOR FAULTY PCM AND ECM WHICH CONTROLS THE FUEL PUMP PRESSURE TO THE FUEL INJECTORS.
May 05, 2011 | 2000 Jaguar S-Type
My AEG Lavamat 62810 keeps coming up with an error code E60. What is this?
On my AEG Lavamat 62810, when I turn on a wash cycle a motor (pump?) runs for 10–20 seconds then the machine switches off, with no error message. When this happened a few weeks agao running a drain cycle seemed to cure it; now the same thing happens on spin/drain/rinse cycles too. Any ideas?
Aug 06, 2010 | AEG Washing Machines
Aeg dischwaher model oko favorite
This seems like the anti flood system (polystireen float / micro switch) at the base of the washer is triggered,\. This puts the washer in pump out mode and stops inlet of water via the inlet solinoid. Dry the water on the base and then check for any water leaks. (pipe leak
Nov 15, 2008 | AEG 18 in. Favorit 64800 Free-standing...
Drain pump keeps running AEG oko favorit
Aug 29, 2008 | AEG Favorit 50500 Built-in Dishwasher
Problem C2 with AEG Lavamat 86741
Find the drain pump (on most front loaders, it's at the bottom of the machine at the front - often with an access hatch).
Open it up (you may want to tip the machine backwards and put a basin underneath to catch the water - and be prepared to close up again if the basin gets full before the machine is fully drained). Check that the pump impeller isn't jammed with a collection of old coins.
My next move would usually be to set the machine going in a part of the cycle where the drain pump is supposed to be running, and to give the impeller a quick flip with my fingertips (taking great care to avoid injury). If the pump doesn't run until you flick it, but then starts, this is a sure sign that you need to replace the pump motor - a quick, cheap and easy fix.
If the pump starts by itself, the the problem is more likely to be one of blocked hoses.
If the pump won't start at all, either by itself or when you flick the impeller, you need to check whether the pump is getting electricity. Do this by disconnecting the machine from the mains, connecting a voltmeter across the two terminals on the pump, then switching back on and selecting a bit of the cycle where the pump is meant to run. If you see mains voltage, then again you want to change the pump motor. If you don't, then check all the associated wiring before starting to look at the main timer. Disconnect the power before removing the voltmeter connections.
A.
Mar 05, 2008 | AEG Lavamat 88840 Front Load Washer
Dishwashers Logo
104 people viewed this question
Top Dishwashers Experts
