Question about Hitachi 51F500 51" Rear Projection HDTV-Ready Television
Problem with tv
After the TV is on for a period of time, the picture becomes fuzzy and jumps around. I can turn the set off, and let it "cool down" and everything is back to normal, but eventually it will do it again. Is this common or do I have a unique problem?
  • pdaddyslim Apr 09, 2008
    it does it on all the inputs: satellite, video games, dvd, etc.
    Sergeant:
    Champion:
  • 375 Answers
Sounds like cold solder connections .
Posted on Apr 13, 2008
    Scholar:
  • 170 Answers
Does it do this on video inputs? if not then you have a possible bad tuner.
Posted on Apr 09, 2008
Anyone have problems with Panasonic TC-P60ST30 with white fuzzy picture mal-function?
Try going into set up menu and look for a screen degauzing function or try setting the screen temp. to warmer or cooler.
Aug 11, 2017 | Panasonic Viera Plasma TV TC-P60ST30
Curtis Mathes TV
the convergence ic must be faulty
Mar 01, 2008 | Televison & Video
It has shrunk to about 6 inches all the way around the screen so the total picture sizr is 36 inches instead of the 42 inches otherwise clear picture little fuzzy when turning on but becomes a clear
Don't know what wires your using to connect to tv. It does matter, sometimes the connections go bad, either at the tv or cable box. Have you tryed to stretch picture in settings?
Feb 10, 2012 | Toshiba 42H82 42" Rear Projection...
Jumping picture on Toshiba flat screen model 36HF732
see ur proplem is u hit up or down or previous to much and it thinks ur still pressing it if u have a bos just turn it around and hit reset beleive me its happened before
Mar 26, 2009 | Televison & Video
TV freezes for a short period of time.
First a couple of questions:
1) What is the make and model please?
2) When the picture freezes, is it like a snapshot photo? or does the screen blank?
This sounds like an interruption in the digital data stream. If the picture remains on the screen, the "new" frame information is not being received nor processed. This can be as simple as a bad cable connection or noise on the digital information data lines.
Check to see if there is any pattern to when this occurs. For example, does it happen more frequently after the set has been on for a while? Try cooling down the set to see if temp effects the behavior.
Please update this and we'll work to resolve it.
Thanks,
Dan
Mar 16, 2009 | Televison & Video
Toshiba CX36H60 Cold start woes
check the capacitor in the SMPS and around Mr. Flyback
Nov 13, 2008 | Toshiba CX36H60 TV
TXJ2066 Samsung
  • your problem is due to crt getting weak
  • because of that you are getting fuzzy picture.
  • good luck.
Oct 23, 2007 | LG 30FS1D TV
36" tube tv. picture fuzzy and out of focus
It sounds like you may have a G1 intermittent short in the picture tube, which unless it is still in warranty would not be worth repairing.
Jan 02, 2007 | Philips 36PW9525C 36" TV
Sanyo TV model DS25710 or DS25730
Set has a bad vertical sweep IC. Also This Sanyo has a tendancy , when the IC blows out , to take the fusable resistor in the sweeo supply that feeds the vertical IC. This set should only be serviced by a trained technician because of ther high Voltage that lingers within. This repair should run you antwhere from 85.00 to 150 bucks. Good Luck
Jul 31, 2006 | Sanyo DS24205 24" TV
Hitachi 51F500 51" Rear Projection HDTV-Ready Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
