Can turn on my bluetooth on my gateway laptop the light is not coming up.
    Guru:
  • 868 Answers
Try uninstalling the drivers for your Bluetooth download new driver from the gateway website specific for your machine to see if the Bluetooth device will be detected or respond properly on the system if not and you install the drivers you will get an error saying device not found or not detected on the machine meaning that the Bluetooth on your computer is busted
Posted on Jun 04, 2010
Tiene bluetooth la gateway 6307
You will find out if you try the following. To turn the Bluetooth radio on: 1 Enable the Bluetooth radio by sliding the wireless network switch to the ON position. If the Bluetooth radio does not turn on automatically, press FN + F6.
Jun 18, 2014 | Gateway M6307 Notebook
Como activo el bluetooth de la gateway 6307
Juan Manuel,
I have to apologize that I can only post this in English. I was able to understand your question though.
You want to know how to turn on the Bluetooth Features of your Gateway 6307.
Try the instructions below:
1. Enable Bluetooth on the mobile phone or other Bluetooth enabled device. This procedure is dependent on the make and model of the phone or the device. You need to see the user manual accompanying your mobile phone or device to see how to enable Bluetooth.
2. Turn on your Gateway laptop. Check the area next to the clock in the System Tray. There should be an icon with a stylized "B" on a blue background. This is the Bluetooth icon. Double-click on this icon and select "Enable."
3. Go to Control Panel. Locate "Bluetooth Configuration" and double-click on it. A window should pop up.
4. Select the Accessibility tab. Check the option "Let other Bluetooth devices discover this computer." A check mark should appear against this entry 5. Select the Local Services tab. Startup type for all services should be set to "Auto."
6. Select "OK" and click. Wait for a few seconds. Your laptop should have Bluetooth enabled by now.
I hope this helps.
I cant enable bluetooth on my pc
If it is an old laptop, it may not have come equipped with a Bluetooth device. You can buy an external Bluetooth transmitter which would plug into the USB port.
Mar 28, 2014 | Computers & Internet
How to activate bluetooth
How to Use the Bluetooth in the Gateway Laptop
ou may have bought a new Bluetooth-capable device like a Bluetooth mobile phone, and may want to load some ringtones or media files that you have stored on your Gateway laptop. This might be the first time you are ever attempting to communicate with a Bluetooth device using your laptop. Normally, Bluetooth has to be enabled on both the devices attempting to communicate. It is no good if Bluetooth is enabled on only one of the devices. All attempts at communicating via Bluetooth will fail. However, if Bluetooth is enabled on both the devices, bringing the two in close proximity is enough for the devices to detect each other. While this is what should happen and it happens most of the time, sometimes the devices need a helping hand. Here's where you come in.
Instructions
1Enable Bluetooth on the mobile phone. This procedure is dependent on the make and model of the mobile phone. You need to see the user manual accompanying your mobile phone to see how to enable Bluetooth.
2Turn on your Gateway Laptop. Check the area next to the clock in the System Tray. There should be an icon with a stylized "B" on a blue background. This is the Bluetooth icon. Double-click on this icon and select "Enable."
3Go to Control Panel. Locate "Bluetooth Configuration" and double-click on it. A window should pop up.
4Select the Accessibility tab. Check the option "Let other Bluetooth devices discover this computer." A check mark should appear against this entry.
5Select the Local Services tab. Startup type for all services should be set to "Auto."Select "OK" and click. Wait for a few seconds. Your laptop should have Bluetooth enabled by now.
Tips & Warnings
If your laptop does not detect the mobile phone even now, turn off the phone and turn it on again while keeping it close to the laptop.
Jan 07, 2012 | Gateway MD7820U (L-LX.W730X.007) PC...
My Laptop's Bluetooth Won't Turn On. I Push FN + F6 (Which Is To Turn On Bluetooth) And It Doesn't Work. It Just Keeps Telling Me Bluetooth Off. My System Information Says This Driver Is Off. Any Help...
Which model laptop is this? Many of the Gateway laptops have 2 switches for the Bluetooth. There is a physical switch on the front or side of the system that needs to be turned on for both the wireless LAN and the Bluetooth to work.
The physical switch needs to be in the ON position, then you can use the FN-F6 to toggle the bluetooth specifically on and off. Depending on the model there will be another toggle, possible FN-F2 to toggle the wireless Lan on and off once the switch is turned on.
Dec 29, 2009 | Gateway Notebook PC - Mobile AMD Athlon...
How to install a intergrated bluetooth module in a Gateway laptop
Did it ever worked?
If you have never tried it before, it probably did not come with it. you can check to see if there is one already installed. It is is usually found near your ram. If it is there and and does not work, you can try to reload the drivers..if that does not work, it is probably fried.
Let me know if it works
Apr 10, 2009 | Computers & Internet
The computer will not boot up
sounds like there might be a hardware problem, like the memory might have come loose, and needs to be reseated. the cmos battery is bad. the processor could be bad.
Apr 02, 2009 | Gateway Computers & Internet
FN F2 to turn on wireless not working.
check it isnt disabled in the BIOS settings
Mar 12, 2009 | Gateway M680XL PC Notebook
Computers & Internet Logo
184 people viewed this question
David Payne
David Payne
