Question about Jura Capresso Impressa F7 Espresso Machine
Jura f7 clean message wont disappear after running cleaning cycle
This is a duplicate post over at C3000. BillP called the tech support and the solution worked well. "Billy, thanks for sharing this fix. I am surprised the tech support would share this info. Yes, i found the round disk with the screw in the middle. For the F7, this disk is directly behind the spring loaded flap, which is right in the middle of the machine when the tray is removed. Sure enough, the disk itself and the surrounding was very dirty. This is the first time we got repeating Ready/Clean message. Reach in and up like Billy mentioned above, and clean as much as you can, a small hand is much more useful. I also cleaned mine with a kid's toothbrush, one that hand a flexible handle. I bent the toothbrush into a Z shape, it reached in and up very well. After cleaning, i ran a Clean without tablet and the message gone away. Thanks again Billy."
Posted on Oct 27, 2012
    Sniper:
  • 60 Answers
First you need to be sure that the cleaning program is completed, if you cancel the program before it`s completed the machine will keep asking for cleaning. If you have tried to run the program several times and the alarm still lights up, then there`s a software problem. The only way to reset this is then to change the Main electronic board, that is very expencive and you should really concider to live with the alarm
Posted on Jun 16, 2010
I cleaned my Jura Capresso with a tablet, but the message "Clean Machine/Ready" won't switch back to "Ready". Any suggestions?
Fortunately the problem you describe is not model specific. All Jura machines in the series C, E, F, J, S & Z models have the same problem. The Jura recommended maintenance is insufficient or erroneous. Here is how it occurs:
1- When new machine is set up, the instructions advice the owner to set up OK for use of Filter cartridges. This set helps only to display reminders for replacing the filter.
2- The initial set up instruction also advises that with regular use of Filter, descaling the machine will not be needed. That is really not accurate. Consequently, the reminders for descaling are delayed for over one year or more. This causes serious consequence with accumulation of Calcium deposits in the entire hydraulic and coffee system.
3- Use of Filters alone does not prevent Calcium deposits. Cleaning tables recommended & sold by Jura do not remove Calcium deposits in the coffee/water passages. The automatic descaling method recommended by Jura leaves the coffee side of the machine unclean. The error message in your machine is due to Calcium deposits in the Brew group, coffee outlet & the faucet dispensing coffee in the cup. I suggest all Jura machine owners should manually descale machine. Manually descaling includes use of 6 to 10 rinse cycles with descaling solution in the water tank. The error message "Clean Machine" is accurate. This error message is pointing to descale the Brew group, coffee outlet tube and coffee dispensing faucet by using rinse cycles.
After the rinse cycles are complete, refill Descaling solution in the water tank & continue descaling the rest of the machine by using hot water dispensing function, ½ cup at a time until the tank is empty. Finally, give a final flushing of machine to flush out remaining descaling solution inside the machine.
Services Unlimited Inc Parts Guru Since 1988
Oct 06, 2016 | Jura Capresso Impressa Coffee Makers &...
I have a jura capresso impressa f7 machine and when I cleaned it (using cleaning tablet) it made some strange sounds and the screen reads "Fault 8" - I removed the tray and cannot re-insert it as the...
Check to see if there is a lever that may need pushed in as you put the tray bad in...not sure as many of the machines are different...but it's worth a try! :)
Jul 30, 2014 | Jura Capresso Impressa F7 Espresso Machine
Clean unit
After making approximately 200 coffees, the internal brewing chamber and the
brewing unit must be cleaned (of coffee oils, etc.). The display will show
CLEAN UNIT alternating with the regular message. This indicates that it is time
to run the tablet cleaning cycle
Feb 20, 2012 | Jura Capresso C1500 Espresso & Coffee...
Error message Fault 5
The message 'FAULT 5' on the Jura Impressa F7, appears when there is a problem with the heating sensor. Normally it needs service or replacement. You can try to unplug it from the power supply for an hour and then open it again. See if it works.
Dec 22, 2011 | Jura Capresso Impressa F7 Espresso Machine
Cannot push tray completely in - looks like a flap is stuck in the back of the machine
We had this error when it asked is to remove the tray during the cleaning cycle. The fix was to just finish the cleaning cycle without the tray in and at the end the flap was back in place and we could fit the tray in again.
Jul 17, 2010 | Jura Capresso Impressa F7 Espresso Machine
Tray missing
On the right side inside you can see a small slot. Try using a screwdiver or something to click this small microswitch, if the message disappears, then you need to check your tray and see if something is broken. You can also try to move a little on the tray when it`s in the machine. However if clicking on the microswitch doesn`t help, you need to have this switch replaced in a servicecenter
May 27, 2010 | Jura Capresso Impressa E8 Espresso/Coffee...
Jura E9 grinder spins but does not grind
I had a similar problem, and solved it by turning the grinder by hand against resistance. Apparently the grinder wasn't really turning during the cycle and needed to be cleared. If your beans are "hopping" this may be a different problem.
Aug 14, 2009 | Jura Capresso Impressa E9 Espresso Machine...
Jura Capresso C3000 keeps saying clean unit
We have the S8 here at our office. Ran the cleaning cycle and "Clean Now" message was still on and beeping afterwards. Read the Feb 28 comment and carefully cleaned everything that had grounds stuck to it. Ran the cycle again and it worked. Thanks all.
Feb 28, 2009 | Jura Capresso Impressa S8 Coffee Maker,...
Clean machine/machine ready light won't go away
Have experienced the same problem for the last nine months. Was finally able to solve it today by following this guide: http://www.wholelattelove.com/articles/jura_capresso_cleaning_guide.cfm
Having cleaned the shower screen I ran the regular cleaning cycle and now the display indiucates "Ready" as it should do.
Sep 07, 2008 | Jura Capresso Impressa E8 Espresso/Coffee...
Jura impressa s9
you need to clean / lubricate the "plungers". The normal clean cycle will strip off the lubricant over time. See my post here:
http://www.fixya.com/support/t348905-malfunction_8
Feb 18, 2008 | Jura Capresso Impressa S90 Espresso...
Jura Capresso Impressa F7 Espresso Machine Logo
532 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Steve
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
