Question about GE WBSR3140DW Top Load Washer
Squeaking washer I just replaced the belt. It is now spinning it just squeaks for the first 3 seconds then quiets?
  • 4,102 Answers
Hi it could be that the belt is to tight or slightly to lose so if the noise dont stop over 2 days then i would try tightening the belt slightly then give that a try but wait till you have used it a couple of times as it might just be that the belt needs wearing in slightly so the noise might stop after couple of uses.
Let me know how you get on or if you need further assistance ok
Posted on Apr 09, 2008
Hoover 2300L 6.okg boss. Squeaking when agitating back& forth, not when spinning. Is this a bearing problem? & is it replacable. If so, from where in south australia? Or wherever.?
Washing machines don't usually run silently, but in most cases, a squeaking noise that occurs while the washer is agitating the clothing is not normal and signifies a problem. If the noise only happens when the washing is agitating, the problem is likely connected to the motor or your water pressure. Depending on the specific cause, you may feel comfortable fixing it yourself. Otherwise, call a professional.
Other People Are Reading
The Agitator
  • Agitators are located in the center of the drum, or basket, of top-load washing machines. Front loading washing machines do not use agitators -- instead, gravity moves the clothes from the top of the drum to the bottom. Agitators usually consist of a tall cone fitted with arms at the base. The purpose of the agitator is to rotate the clothes and soapy water around the tub to clean the clothes. The agitator itself is not usually the cause of the squeaking noise. It is powered by the drive mechanism, which consists of a motor, clutch and gears.
Motor Problems
  • A repetitive squeaking noise during the agitation cycle may signify a problem with the motor. Specifically, the belt on the motor may be wearing out. Some motors use rubber couplers, which also wear out easily. The belt is necessary for the agitator to turn, but over time, it wears thin, just like the belts in your car's motor. An easy way to test for this problem -- if you're handy -- is to take the belt off the motor and then run it. If the squeaking noise stops, the problem is indeed your belt. Of course, this means your agitator won't move. Replacing the belt should fix the problem.
Water Pressure Issues
  • The tub, or drum, fills with water right before the agitator turns on, and water continues to circulate throughout the washing process. As the tub fills and water circulates, you may hear a squeaking or squealing noise if you have high water pressure. This sound is caused by the force of the water moving through the pipes. To adjust this, turn the knobs on the hot and cold valves on the pipes that go into your washing machine.
Considerations
  • New washing machines may squeak at first as the parts "warm up," according to the GE Appliances website. The noise should disappear after five complete washing cycles have run on the machine. Unbalanced loads, overly heavy loads and loose items in the drum may also cause noise when the agitator comes on, but these things usually do not produce a squeaking sound.
Read more :http://www.ehow.com/info_12131280_washer-squeaks-agitating.html My Washer Squeaks When Agitating eHow
Jun 14, 2015 | Hoover Washing Machines
Mazda protege makes a squeaking noise when I start driving?
If your Mazda Tribute's engine has a rumbling noise when you start it, this is most likely from the drive belt. You will need to replace it.
May 30, 2013 | Mazda Protege Cars & Trucks
1992 Mazda MX3 is sweeking when I turn car on...might be some sort of belt but I'm not positive.
Sounds like the belt, you're right on track. Check the belt(s) and replace if neccesary. If belts are fine, check for tightness. Should be about a 1/4" flexibility when you push down on them. If all is ok, belt dressing should take care of the problem.
Now, if for some reason, one of the components that run off the belts may be going bad, specifically a/c compressor. If it's starting to lock up, it will make your belt squeal and finally snap.
Mar 31, 2010 | Mazda MX-3 Cars & Trucks
1988 jeep cherokee, 4.0. newer water pump *few months maybe* doesnt over heat, no leak, but it squeaks, just like a bad idler pulley would. when running i sprayed oil in on it and it stop squeaking for a...
Take the belt off check the clutch fan and spin all the pullies insure they spin freely and do not wobble if any do replace them if all checks out ok put a new belt on. make sure the belt tension is not to tight should have about 3/4 inch play.
Oct 05, 2009 | 1988 Jeep Cherokee
Kenmore top-loading washing machine squeaks
Hi
Thanks for using FixYa. Please check if there are any sucked small clothes, safety pin, lint or debris in the water pump. If the pump is fine then the squeaking sound may be due to gear dogs in the agitator or bad gear case. The washer will spin and agitate at the same time. If the washer is still under warranty then do not try to open, repair or replace any part to void the warranty.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 13, 2009 | Kenmore 22422 Top Load Washer
Squeaks really loud while agitating. Drains great, and works well other wise. Could the belt be going bad?
Could either be the drivebelt slipping or, if an older machine could be the main bearing getting dry.
May 20, 2009 | Washing Machines
Kenmore front loader washer squeaks in washer mode and shakes in spin.
shocks made of plastic squeaks, a little greese may help
Nov 08, 2008 | Washing Machines
High pitch squeak when on spin cycle
looks like you need to replace the main DRIVE BELT , first open the panel to access inside the washer , give it a test wash and look at the bottom where the belt is , check if belt is tight , if you still hear the squeak try lubricate spray to the pulleys and avoid spaying the MAIN BELT . hope this info works
Apr 18, 2008 | Crosley CW5000 Front Load Washer
GE WBSR3140DW Top Load Washer Logo
94 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
