Question about Dryers
Simpson Sirocco 350 Dryer cuts out after 5 minutes I am told it is the heat sensor attached to the red button inside the door but not sure how to access the sensor to replace it.
  • 40 Answers
Its probably NOT the sensor causing the problem. Have you checked the fan belt, that its not broken, come off the pulley or stretched? Put your hand over the airvent outlet at the back after it has been running a few minutes, if there is a lot of hot air coming out, then belt is ok. If not, replace the fanbelt with a new one, and problem will be solved. The sensor pops out because of overheating - usually because either the fan belt is broken or stretched, or the lint filter is blocked. Hope this helps!
Posted on Aug 20, 2010
Simpson clothes dryer sirocco 455 5kg the power shorts out when we turn it on ?
check the heating element.remove back panel to access it
May 31, 2015 | Dryers
Is it a big job to replace the heater element on the Simpson Sirocco 350 dryer?
It won't be the element unless a wire from it is grounding against the casing. You most likely have some sort of issue with the home breaker.
Mar 15, 2014 | Kenmore 500 6952 Dryer
Lg dryer dle7177 cutting off during cycle
I had a tumble dryer that stopped working and after much investigation it turned out to be an internal thermostatic switch and lots of fluff around the internal filters. ( Mine had 2 of them 1 would cut the heat and kick back in when the temperature dropped and the other one would completely cut all power rendering the drier non usable until cicuit breaker thermostat was replaced. The reason they cut out is to prevent overheating and possible fire. When the thermostat gets to certain temperature it breaks the circuit. Apparently you shouldn't stop the drier until it has completely cooled down as there will be too much heat which could cause a fire, which is why most drier cycles have 10 minutes of cool/ non heated air at the end. So in conclusion I would take all the filters out and give them a good clean and try to avoid opening the door while there is still a lot of heat in the drier. I'm not sure if this will help but its a starting point.
Feb 03, 2013 | Dryers
My Simpson Sirocco 3500 clothes dryer emits burning smell!
1)check for something stuck between drum and dryer housing 2)check for stuck vent flapper at exhaust opening outside 3) check dryer lint screen
Nov 05, 2009 | Dryers
I have 2 simpson sirocco 350 dryers and neither will dry clothes as soon as a bit of heat happens they turn off is there something that I did'nt take out of them when Ifirst got them? Hoping you can help....
difficult one , but drier will typically switch off if the over temp. sensor activates. Suggest you move the drier away from the wall or any area that could block air flow into the air ducts and retest. Very unlikely both would do the same thing. Common denominator is its position..
Sep 14, 2009 | Siemens Dryers
Diagram of how to replace drive belt on simpson sirocco 500 tumble dryer
May 12, 2009 | Dryers
When the dryer is on high or medium heat, it trips the power breaker of the house. it does not do this on air only/no heat", which makes me think of a short in heating unit.
the dryer is run by a universal motor, and these motors (while being very robust) can draw more current if the torque put on the drive train is overloaded. try running dryer with less clothes.
Simpson Sirocco 350 Dryer not heating
I repaired my broken fan belt with a drop of super glue - there is virtually no load on the belt and it now works perfectly again. A 30 sec quick fix.
Mar 21, 2009 | Dryers
Condensation is forming on the walls when I use my clothes dryer
Simpson may have a kit available for accomplishing this. Also, your dryer may have several optional ways of venting.
Mar 27, 2017 | Dryers
there is an oval cover on the back of the dryer. Remove this cover and you will probably find a broken fan belt. A replacement costs about $20 Aus.
NOTE: If you have been using the dryer for a while in this condition there will certainly be moisture inside the dryer. Replace the belt and leave the dryer for a few days to dry itself out (motor and electricals) before firing it up.
Oct 08, 2008 | Maytag 7.0 Cu. Ft. Electric Dryer
Dryers Logo
856 people viewed this question
Top Dryers Experts
