Question about LG LRFD25850 French Door Refrigerator
My LG LRFD25850ST has water collecting in freezer under the drawer that is freezing. Dont know where the water is coming from. Also have occassional water on floor in front of fridge we think is coming from water dispenser. Dont know if it is related issue or not.
  • LG Master
  • 43,501 Answers
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
Water Running in Refrigerator from Freezermy LG LRFD25850ST has water collecting in freezer - 2_bing.gif
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Posted on Jun 04, 2010
Model LFX28968ST. Why is water dripping onto lower freezer drawer?
Richard, sounds like the drain plug/ hole is plugged.
Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
LG Freezer repair French Door bottom Freezer model
Appliance Repair Forums
LG 819 739 refrigerator not cooling or water leakage how to fix repair by...
How to Unclog Refrigerator Drain Line
Mar 12, 2016 | LG Refrigerators
Water in the bottom of the fridge
In the freezer compartment, there is a drain. This drain gets plugged up. When the freezer defrosts the evaporator the water from it runs down to that drain. If that drain is plugged up, the water from the defrost can't drain out. The water will collect under on the bottom and then freez when the freezer starts up again. Take out the bottom drawers and us a hair drier to melt the and unplug the drain.
If that doesn't work, let me know.
Sep 24, 2014 | Refrigerators
Water does not drain and freezes under freezer draw
I am sending a couple links for the LG manuals but that sounds to me that water is either overflowing into freezer compartment from the fresh food compartment or when the freezer goes into defrost the drain that carries the water out to a condensate pan below refrigerator (Location #105A) has either ice or sludge caught in the drain. Here is the=> LRFD22850 Exploded View then scroll to page 44 where you will see the location number 319A That will be the condensate/drip collection tray where the water from defrost should be going. If the drain location # 105A is the drain assembly, pipe Z coming from under your freezer drawers. Where you say you see the water pooling and freezing. And the Service manual Click Here=> LRFD22850 Service Manual I will try to make this simple but I must try to explain with photos and notes with other links=> Leaking Refrigerators Just What May Be Happening and here=> Leaking Refrigerators! This may take some detective work because as you see any place there is water there may be water flowing down to the area below freezer drawers so look for any water that may be coming even from the water filter area inside fresh food compartment.Even a slight lean will cause the water to pool up and freeze there and close the drain slowly. If you should need parts scroll to page 51 in your Service Manual and on left is the photo location and on right is the part number under the model LRFD22850 then enter the part numbers into search feature here=>
Repair Clinic or Sears Parts Direct Here is the new=> Adobe Reader X
I also will be here to answer any questions you may have, Thanks, Sea Breeze
Jun 05, 2011 | LG LRFD22850 Bottom Freezer Refrigerator...
Our lg fridge freezer leaks water on to floor every 2 weeks
If the water is collecting and freezing on the bottom of the freezer then the drain under the evaporator in the rear of the freezer section is plugged.
Nov 17, 2010 | LG Refrigerators
Water collecting under the freezer drawer, then freezing
We just had a similar problem with our Maytag side-by-side in the bottom of the freezer. Just as you described...sort of a glacier on the floor of the freezer that slowly melts toward the door. After several attempts to remove the ice, only to have it form again, my husband spoke with a helpful sales person in an appliance center. He said there's a drainage plug/line on the back that's supposed to funnel condensation to the evaporation tray underneath. It gets clogged and frozen. Sure enough...my husband pulled out the freezer, opened the visible line and it was all frozen and full of gunk. He had to use a hair dryer to thaw it out, then flushed it. It was amazing how much stuff came out of there. We've had no more problem since.
Apr 21, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Leaking water from freezer side-by-side GE refrigerator
Hi, It sounds like the defrost drain is plugged. You will need to remove the rear inside panel in the freezer and unp,ug the drain. Once you remove the rear panel, you should see a collestion of ice under the evaporator coil. Locate the drain hole and clear the ice. Flush the drain hole out with hot water to make sure it will drain. You might have to run a wire through the drain or you can flush water through it with a baesting serienge.
I hope this helsp you. Please let me know if I can assist you further.
Vic
Jul 01, 2009 | Refrigerators
Underneath the crispers is full of water sometimes even freezes Underneath the crispers water collects, but it does not freeze.
Here is a link to help you resolve the problem I also have an even better link but on-line is moving slow at moment. Anyway you will need to take the part out from back and clean the blockage., Let me know if this helps, Sea breeze
http://appliancejunk.com/forums/index.php?topic=1309.0#top
http://servicepartstec.blogspot.com/
May 19, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
Roper Refrigerator
open the freezer compartment loo for ice build up on floor of frezer especally towards rear behind back panel. sounds like you have a clogged/frozen defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials)
Mar 05, 2008 | Roper RT21AKXKQ Top Freezer Refrigerator
Water under drawers, condensation on top of freezer
Water collecting on the top of a freezer, I have to wipe it every week, it is on the outside of the freezer, on top of the formica surface. Please Help.
Jan 12, 2007 | Kenmore 72202 / 72204 / 72209 Top Freezer...
LG LRFD25850 French Door Refrigerator Logo
595 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
