Question about Kitchen Ranges
I couldn't open MW door so I filed down the black plastic bits (on the door) that slot into the slots on the front of the MW. Now the door opens and closes OK, the light comes on and the numerical countdown starts on the timer but the MW doesn't start heating. Have I ruined any chance of it working again by my "filing down" the black plastic bits or what can i do?
    Sergeant:
    Champion:
  • 311 Answers
Yes. you need to replace the part you basically ruined.
Posted on Jun 05, 2010
How can I buy a replacement door for a 302 dishlex ?
I was looking for the same thing myself for our Dishlex 300 a few months back. Our problem was 1/ the handle wasn\'t releasing the door catch,
also 2/ the micro switch in the catch wasn\'t getting pressed down properly to tell the machine the door was closed, so the dishwasher wouldn\'t start. Both problems were related to the plastic ramp inside the door being worn where the tongue of the catch goes in.
We couldn\'t find one in NZ, so I made a tapered flat piece of wood to push the catch down between the main body and the door whenever we want to open it.
For the switch problem it was a bit harder - I opened up the plastic box at the top front of the machine (with the power off of course) and built up the plastic ramp that triggers the switch, using glue and then a file to shape it after the glue hardened.
I hope this is helpful.
Cheers.
May 26, 2014 | Dishwashers
How do I replace ink jet in officejet 4500
Step one: Remove the old cartridges
1. Press the power button to turn on the product
2. Open the front access door. The carriage moves to the far right side of the product
3. Wait until the carriage is idle and silent, and then lightly press down on the cartridge to release it.
To replace the tri-color cartridge, remove the cartridge from the slot on the left.
To replace the black cartridge, remove the cartridge from the slot on the right.
Pull the cartridge toward you out of its slot.
Step two: Install the new cartridges
1. Remove the new cartridge from its packaging. Be careful to touch only the black plastic.
2. Gently remove the plastic tape by pulling the pink pull tab
3. Hold the cartridge with the HP logo on top, and insert the new cartridge into the empty cartridge slot. Make sure you push the cartridge in firmly until it snaps into place.
If you are installing the tri-color cartridge, slide it into the left slot.
If you are installing a black cartridge, slide it into the right slot.
4. Close the front access door.
May 27, 2013 | HEWLETT-PACKARD Officejet 4500 All-in-One...
How to change the ink cartridge
Checking the ink levels
  1. Open the HP Director .
  2. Click Settings , point to Print Settings , and then click Printer Toolbox .
  3. After the Printer Toolbox opens, click the Estimated Ink Level tab.
  4. For information on obtaining replacement cartridges, click Print Cartridge Ordering Information .
Replacing the print cartridges
  1. Make sure the HP all-in-one is on. WARNING: If the HP all-in-one is off when the print-carriage access door is lifted to access the print cartridges, the HP all-in-one will not release the cartridges for changing. Damage may occur to the HP all-in-one if the print cartridges are not docked safely on the right side when you try to remove them.
  2. Open the print-carriage access door by lifting from the front center of the device, until the door locks into place. The print carriage is on the far right side of the HP all-in-one. c00228292.jpg 1 - Print carriage access door 2 - Print carriage
  3. When the print carriage is idle and silent, press down on the end of each cartridge to snap it out of the carriage. If replacing the tri-color print cartridge, remove the print cartridge from the slot on the left. If replacing the black or photo cartridge, remove the print cartridge from the slot on the right. c00228293.jpg 1 - Print cartridge slot for the tri-color print cartridge 2 - Print cartridge slot for the black and photo print
  4. Gently pull the print cartridge toward you, out of its slot.
  5. If removing the black print cartridge to install the photo or gray photo print cartridge, store the black print cartridge in the print cartridge protector.
  6. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections. c00228294.jpg 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape c00228295.jpg
  7. Slide the new print cartridge forward into the empty slot. Push the print cartridge forward until it clicks into place. If the print cartridge you are installing has a white triangle on its label, slide the print cartridge into the slot on the left. The label for the slot is green with a solid white triangle on it. If the print cartridge you are installing has a white square or a white pentagon on its label, slide the print cartridge into the slot on the right. The label for the slot is black with a solid white square and a solid white pentagon on it. c00228296.jpg
Jan 21, 2011 | HP OfficeJet 6210 All-In-One InkJet...
How to load the ink cartridge
Jan 14, 2011 | HP OfficeJet 6210 All-In-One InkJet...
We have a Universal Shredder 38103 at our office. The "open door" indicator is on and won't turn off. We have turned it off, unplugged it, cleaned it, vacuumed it out, removed as much loose paper bits as...
On the upper right corner of the bin opening you will see a slot in the black plastic. I taped a part of a business card into the slot and it now works. Just make sure to unplug the machine when the door is open.
Sep 28, 2010 | Universal Office UNV-38016 Shredder
Brothers MFC 7420 keeps displaying Back Door Open. Have cleaned etc. everything suggested on help websites, nothing works. Help coxmwc@aol.com
The back door is a double door. Inside the gray door is a black plastic paper guide that hinges down, also. Mounted on the inside of that is a thin, black rod, leading to a lever on your right, that swings through a slot in the side of the machine. Sometimes the lever gets bent so it doesn't fit into that curved slot. If that's your situation, gently force it back into the slot so it can block the sensor that tells it the back door is closed, and you'll be printing again.
Nov 01, 2009 | Brother MFC 7420 All-In-One Laser Printer
The brother fax 2820 keeps signaling to me to close the back cover no covers are open
Open that back cover, and you'll see another, black plastic plate that also can be pulled to swing down. Running across that plate is a skinny black rod. At the right-hand end (when you're peering in the back of the machine) it has a couple of right-angle bends, ending in a vane that should swing through a curved slot in the side wall inside the machine. That vane interrupts a sensor to tell the machine that the door is open or that paper is jammed in the back. Sometimes it gets bent with the vane outside the curved slot. Gently bend it enough to drop it into the slot, close everything up, and try it out.
May 13, 2009 | Brother IntelliFax-2820 Laser Fax
I do not know the combination number. We have a 3100 sentry Thank you Donna
if it is open already... Take off the plastic inside cover. lock the door "WITH IT OPEN " . turn it several times to the right then watch the inside most slot line up. Write that # down. Turn it to the left past that number and continue on till the middle slot lines up to the inner most slot. Write that # down. Then turn to the right until the outer most slot in the last disk lines up to the other two and write that # down.... Then OPEN the door. Now you put the combination where you wont love it hopefully. This will only work if the safe is locked open. Hope it helps.
Apr 08, 2009 | Sentry Fireproof Safe
I can't find my manual--model C4280-----I need to replace the black ink cartridge---I've got the door open and can see the cartridges---how do I release them to come out?? Thanks, Dennis Crawford
To replace the print cartridges
1.
Make sure the HP All-in-One is on.
CAUTION: If the HP All-in-One is off when you open the print cartridge door to
access the print cartridges, the HP All-in-One will not release the cartridges for
changing. You might damage the HP All-in-One if the print cartridges are not
docked safely when you try to remove them.
2. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
3. Open the print cartridge door.
The print carriage moves to the far right side of the HP All-in-One.
4. Wait until the print carriage is idle and silent, and then lightly press down on a print
If you are replacing the tri-color print cartridge, remove the print cartridge from the
slot on the left.
If you are replacing the black or photo print cartridge, remove the print cartridge from
1 Print cartridge slot for the tri-color print cartridge
2 Print cartridge slot for the black and photo print cartridges
5. Pull the print cartridge toward you out of its slot.
6. If you are removing the black print cartridge in order to install the photo print cartridge,
store the black print cartridge in the print cartridge protector or an airtight plastic
container.
7. Remove the new print cartridge from its packaging and, being careful to touch only
If you go here you can download the user manual.
http://h10032.www1.hp.com/ctg/Manual/c00896316.pdf
Jun 18, 2008 | HP Office Equipment & Supplies
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
