Question about Mitsubishi WD-60735 Projection Television
I cannot shut off the closed captions - Mitsubishi WD-60735 Projection Television
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
You have two choices. either the CC is coming from the set (ie closed caption) or if you are using a box of some kind (cable, sat etc) it can come from that also/
If from the set you need a working originial remote to remove it, same with the box if it is causing it.
CC can come from either the set or a box hooked up to the set.
SD TECH
Posted on Jun 04, 2010
Shutting closed captioning off with out a romote for the tv
Is there a "CC" button on the remote control of your TV. If is, press it once. If not, enter into int Menu option to select the closed caption ON/OFF window, and make the closed caption function to OFF.
Jun 04, 2012 | Televison & Video
How to turn off CC without original remote27ms4504
Noway to turn off captioning right away without the original remote.But U can unplug the tv for an hour,tv well reset itself back to original setting.The Captioning will shut off buy itself.Because captioning reqiure CC buttion on orignal remote and must manually turn on and off.
Feb 08, 2010 | Philips 27MS4504 TV
Shut off captions
Captions are the closed captions for the deaf. There is a setting or menu for this. Look for it.
Jan 12, 2010 | RCA RCU300WBL Remote Control
Can't shut off closed caption no remote
Have you tried unplugging the entire device and plug it back in 15 secs later.
May 17, 2009 | Sanyo DS31520 31" TV
How do I shut off the Closed Caption feature?
Bluffy you should access the menue on your remote and be able to shut it off!
Feb 16, 2009 | Philips Magnavox 27MS343S 27" TV
Toshiba 62hx94 cant shut off closed caption have comcast cable How do I turn off closed caption on my TV. It suddenly turned on. can' turn off closed captioning 20" ws
The problem was with the Motorfolla Comcast cable box not my T.V. . I turned off my Comcast cable box, pressed menu on the remote to the cable box. This made a 16:9 ratio appear on the cable box's LED read out, and a bluish screen appear on my television. One of the options on my television was to turn on and off closed captioning. Therfore, I turned off closed captioning and the problem was solved.
Jan 30, 2009 | Televison & Video
Turning off Closed Captioning
On the 27" TruFlat the closed caption button is hidden within the DVD buttons. You have to press it multiple times to shut off closed caption. It seems to have multiple sources for closed captions. Press the button until no source appears on the screen. ITS CONTROLED AT THE REMOTE CONTROL - NOT ON THE ON-SCREEN TV MENUS. Good Luck
Nov 27, 2008 | RCA TruFlat 27F520T 27" TV
Cannot shut off Closed Captioning-HELP!!
I was assisted by an expert using the Premium Assistance Plan. The expert was very informative and I was fixed up in minutes! Thanks much!
Sep 08, 2008 | Radio Shack (15-2147) Remote Control
Spanish closed captioning stuck on Tobisha 46RV530U
Did you change the language to English? turn off closed cap.?
Jun 01, 2008 | Televison & Video
Close caption turns on and off by itself problem
Check the cable box to make sure the captions aren't truned on in the cable box.
If not -if it really is the Magnavox caption service- then -
This is assuming you have the original remote:
1 Press MENU to show the on-screen
menu.
2 Press VOL+ or VOL- until SET is highlighted.
3 Press CH+ or CH- repeatedly to
highlight CLOSED CAPTION.
4 Press VOL+ or VOL-
to display the
CLOSED CAPTION menu.
5 Press CH+ or CH- to select the
closed caption you want (OFF, CC-1,
CC-2, or CC-MUTE).
CC-MUTE sets
the TV to show closed captions when
you press MUTE. The TV volume will be
disabled until you press MUTE again to
restore the sound.
6 Press VOL+ or VOL-
to confirm your
selection.
7 Press TV/AV/EXIT to remove the
menu.
Feb 25, 2008 | Philips Magnavox 27MS343S 27" TV
Mitsubishi WD-60735 Projection Television Logo
157 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
