Question about Craftsman 20 Hp 42" Deck Lawn Tractor
I have a 20 hp 42" deck craftman lawn tractor---runs good for 30 min. than starts missing---will only run at lowest throtle. I replaced the spark plug and gas line filter.
  • 420 Answers
It's overheating, remove the engine covering and clean the fins of the engine.
Posted on Jun 04, 2010
Craftman lawn tractor 20.0 HP 42" electric start blades will not engage
Check for voltage at the electric pto clutch connector if 12 +volts is there when the switch is on then the clutch is bad; otherwise, you need back through the wiring to find the problem.
Aug 08, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftman model 917.271920 run at high speed at the time.even with the throttle in idle position
If a cable operated throttle the far end of the cable may have broken or come off. Linkage between throttle cable and carburetor bent/broken/
missing, spring broken/missing. Shouldn't be too serious.
Apr 15, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I have a 15.5 HP, Craftman lawn tractor. I'm having problem with it staying running. It will run just find for 20-30 minutes and then stop abruptly. I have changed the spark plug, oil, cleaned the air...
Check the Blade Safety Switch. Also check if the Carburettor requires a good cleaning and overhaul or not. After that check if there is any air leak or air in the fuel line.
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Sep 29, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
The stars on the lawn tractor deck that hold the
This is a common problem with most of this era tractors the easist way to fix is pick up new ones either at NAPA auto parts store or TSC Tractor supply both carry new star washers to replace the worn ones, and it as simple as removing the old and replacing with the new. Hope this Helps Don
Nov 09, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
CRAFTMAN 20 HPmower WILL NOT START. I CAN JUMP THE
Hi, W/D here.
Try cleaning all of the contacts at the solenoid, and the wires that attach to it. That will probably get you going.
--W/D--
Aug 12, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Motor runs for 5-10 min. then starts missing and quits.
Check your spark first,if you do not have spark your problem is the coils-if you do have spark the problem probaly lies withone of your valves getting stuck after getting hot and soonas it cools down a little it closes and then you can restart it till it gets hot again.Hope this helps
Jul 04, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 20 Hp 42" Deck Lawn Tractor Logo
275 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
