Question about Fuji FinePix S5200 / S5600 Digital Camera
Display reads card not initialized - Fuji FinePix S5200 / S5600 Digital Camera
  • 6 more comments
  • yellowstars May 11, 2008
    okay im having trouble with my camera this is the first and i need it fix bad before tomorrow.
    Okay if the memory card is inseted into the camera the messages comes up as "CARD NOT INITIALIZED" and I can't take any pictures, but if the memory card is not in I'm able to take pictures. Why is that?
    The thing is that I'm able to upload it onto the computer, it's just that I can't take any pictures with the memory card in it.
    P.S.
    Really need help, Plz anywho help
  • lcebovic72 Jul 19, 2008
    display sayd card not initialized, how do i fix it?
  • Anonymous Aug 09, 2008
    card not initiaaaaaaalizing is whats on the screen
  • Anonymous Nov 02, 2008
    i just says card not initialized..... T.T
  • Anonymous Nov 15, 2008
  • AGoulet233 Nov 27, 2008
    Problem started with "card Error" then I bought a new card and now it reads" card not initialized" please help or I am buying a nikkon !!!!
  • Anonymous Dec 02, 2008
    AHHH! needz to take picturez! card not initialized! WTFOMGBBQ!
  • Anonymous Jan 19, 2009
    what shuld i do?
Simple : plug the camera on the computer. Go to "My Computer". Select the camera. Right Click. Format the card. (Format) Presto, everything works again!
Posted on Dec 09, 2008
How do I reset KBD300 pleco keyboard
To initialize the keyboard, wait five seconds after powering-up the CM6700, enter the number for the
monitor you are viewing (1-4), and press MON. The LED display shows the number entered.
NOTE: You must re-initialize whenever power is cycled.
Source: http://www.jmacsupply.com/v/vspfiles/files/PMFiles/Pelco/Instructions/KBD300A-InstallationManual.pdf
Jan 15, 2015 | Pelco Kbd300a Pushbutton Control Keypad W/...
Beep codes
AMI BIOS beep codes Below are the AMI BIOS Beep codes that can occur. However, because of the wide variety of different computer manufacturers with this BIOS, the beep codes may vary.
Beep Code Descriptions 1 short DRAM refresh failure 2 short Parity circuit failure 3 short Base 64K RAM failure 4 short System timer failure 5 short Process failure 6 short Keyboard controller Gate A20 error 7 short Virtual mode exception error 8 short Display memory Read/Write test failure 9 short ROM BIOS checksum failure 10 short CMOS shutdown Read/Write error 11 short Cache Memory error 1 long, 3 short Conventional/Extended memory failure 1 long, 8 short Display/Retrace test failed Award BIOS Beep codes that can occur. However, because of the wide variety of different computer manufacturers with this BIOS, the beep codes may vary. Beep Code Description 1 long, 2 short Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information Any other beep(s) RAM problem. If any other correctable hardware issues is found the BIOS displays a message. No Power, Loose Card, or Short.1 Short BeepNormal POST, computer is ok.2 Short BeepPOST error, review screen for error code.Continuous BeepNo Power, Loose Card, or Short.Repeating Short BeepNo Power, Loose Card, or Short.One Long and one Short BeepMotherboard issue.One Long and Two Short BeepsVideo (Mono/CGA Display Circuitry) issue.One Long and Three Short Beeps.Video (EGA) Display Circuitry.Three Long BeepsKeyboard or Keyboard card error.One Beep, Blank or Incorrect DisplayVideo Display Circuitry. Phoenix BIOS Q3.07 OR 4.X Beep Code Description and what to check 1-1-1-3 Verify Real Mode. 1-1-2-1 Get CPU Type. 1-1-2-3 Initialize system hardware. 1-1-3-1 Initialize chipset registers with initial POST values. 1-1-3-2 Set in POST flag. 1-1-3-3 Initialize CPU registers. 1-1-4-1 Initialize cache to initial POST values. 1-1-4-3 Initialize I/O. 1-2-1-1 Initialize Power Management. 1-2-1-2 Load alternate registers with initial POST values. 1-2-1-3 Jump to UserPatch0. 1-2-2-1 Initialize keyboard controller. 1-2-2-3 BIOS ROM checksum. 1-2-3-1 8254 timer initialization. 1-2-3-3 8237 DMA controller initialization. 1-2-4-1 Reset Programmable Interrupt Controller. 1-3-1-1 Test DRAM refresh. 1-3-1-3 Test 8742 Keyboard Controller. 1-3-2-1 Set ES segment to register to 4 GB. 1-3-3-1 28 Autosize DRAM. 1-3-3-3 Clear 512K base RAM. 1-3-4-1 Test 512 base address lines. 1-3-4-3 Test 512K base memory. 1-4-1-3 Test CPU bus-clock frequency. 1-4-2-4 Reinitialize the chipset. 1-4-3-1 Shadow system BIOS ROM. 1-4-3-2 Reinitialize the cache. 1-4-3-3 Autosize cache. 1-4-4-1 Configure advanced chipset registers. 1-4-4-2 Load alternate registers with CMOS values. 2-1-1-1 Set Initial CPU speed. 2-1-1-3 Initialize interrupt vectors. 2-1-2-1 Initialize BIOS interrupts. 2-1-2-3 Check ROM copyright notice. 2-1-2-4 Initialize manager for PCI Options ROMs. 2-1-3-1 Check video configuration against CMOS. 2-1-3-2 Initialize PCI bus and devices. 2-1-3-3 Initialize all video adapters in system. 2-1-4-1 Shadow video BIOS ROM. 2-1-4-3 Display copyright notice. 2-2-1-1 Display CPU Type and speed. 2-2-1-3 Test keyboard. 2-2-2-1 Set key click if enabled. 2-2-2-3 56 Enable keyboard. 2-2-3-1 Test for unexpected interrupts. 2-2-3-3 Display prompt Press F2 to enter SETUP. 2-2-4-1 Test RAM between 512 and 640k. 2-3-1-1 Test expanded memory. 2-3-1-3 Test extended memory address lines. 2-3-2-1 Jump to UserPatch1. 2-3-2-3 Configure advanced cache registers. 2-3-3-1 Enable external and CPU caches. 2-3-3-3 Display external cache size. 2-3-4-1 Display shadow message. 2-3-4-3 Display non-disposable segments. 2-4-1-1 Display error messages. 2-4-1-3 Check for configuration errors. 2-4-2-1 Test real-time clock. 2-4-2-3 Check for keyboard errors 2-4-4-1 Set up hardware interrupts vectors. 2-4-4-3 Test coprocessor if present. 3-1-1-1 Disable onboard I/O ports. 3-1-1-3 Detect and install external RS232 ports. 3-1-2-1 Detect and install external parallel ports. 3-1-2-3 Re-initialize onboard I/O ports. 3-1-3-1 Initialize BIOS Data Area. 3-1-3-3 Initialize Extended BIOS Data Area. 3-1-4-1 Initialize floppy controller. 3-2-1-1 Initialize hard disk controller. 3-2-1-2 Initialize local bus hard disk controller. 3-2-1-3 Jump to UserPatch2. 3-2-2-1 Disable A20 address line. 3-2-2-3 Clear huge ES segment register. 3-2-3-1 Search for option ROMs. 3-2-3-3 Shadow option ROMs. 3-2-4-1 Set up Power Management. 3-2-4-3 Enable hardware interrupts. 3-3-1-1 Set time of day. 3-3-1-3 Check key lock. 3-3-3-1 Erase F2 prompt. 3-3-3-3 Scan for F2 key stroke. 3-3-4-1 Enter SETUP. 3-3-4-3 Clear in POST flag. 3-4-1-1 Check for errors 3-4-1-3 POST done - prepare to boot operating system. 3-4-2-1 One beep. 3-4-2-3 Check password (optional). 3-4-3-1 Clear global descriptor table. 3-4-4-1 Clear parity checkers. 3-4-4-3 Clear screen (optional). 3-4-4-4 Check virus and backup reminders. 4-1-1-1 Try to boot with INT 19. 4-2-1-1 Interrupt handler error. 4-2-1-3 Unknown interrupt error. 4-2-2-1 Pending interrupt error. 4-2-2-3 Initialize option ROM error. 4-2-3-1 Shutdown error. 4-2-3-3 Extended Block Move. 4-2-4-1 Shutdown 10 error. 4-3-1-3 Initialize the chipset. 4-3-1-4 Initialize refresh counter. 4-3-2-1 Check for Forced Flash. 4-3-2-2 Check HW status of ROM. 4-3-2-3 BIOS ROM is OK. 4-3-2-4 Do a complete RAM test. 4-3-3-1 Do OEM initialization. 4-3-3-2 Initialize interrupt controller. 4-3-3-3 Read in bootstrap code. 4-3-3-4 Initialize all vectors. 4-3-4-1 Boot the Flash program. 4-3-4-2 Initialize the boot device. 4-3-4-3 Boot code was read OK.
http://www.computerhope.com/beep.htm
Jul 09, 2014 | EliteGroup GeForce6100PM-M2 Motherboard
What is causing an HP LaserJet 8150 Error 82.0180?
It's from your jet direct card. Turn off the by weDownload Manager Pro" style="background-color: transparent !important; border: none !important; display: inline-block !important; float: none !important; font-style: normal !important; font-variant: normal !important; font-weight: normal !important; font-family: Arial, Helvetica, Verdana, Tahoma, sans-serif !important; height: auto !important; margin: 0px !important; min-height: 0px !important; min-width: 0px !important; padding: 0px !important; vertical-align: baseline !important; width: auto !important; text-decoration: underline !important; background-position: initial initial !important; background-repeat: initial initial !important;">printer andarrow-10x10.png pull out the network card. Turn the printer on and verify it goes to ready. Turn off and reseat the card and see if the printer comes to ready.
If yes - upgrade the jetdirect firmware and by weDownload Manager Pro" style="background-color: transparent !important; border: none !important; display: inline-block !important; float: none !important; font-style: normal !important; font-variant: normal !important; font-weight: normal !important; font-family: Arial, Helvetica, Verdana, Tahoma, sans-serif !important; height: auto !important; margin: 0px !important; min-height: 0px !important; min-width: 0px !important; padding: 0px !important; vertical-align: baseline !important; width: auto !important; text-decoration: underline !important; background-position: initial initial !important; background-repeat: initial initial !important;">the printerarrow-10x10.png firmware
If no, try the other EIO by weDownload Manager Pro" style="background-color: transparent !important; border: none !important; display: inline-block !important; float: none !important; font-style: normal !important; font-variant: normal !important; font-weight: normal !important; font-family: Arial, Helvetica, Verdana, Tahoma, sans-serif !important; height: auto !important; margin: 0px !important; min-height: 0px !important; min-width: 0px !important; padding: 0px !important; vertical-align: baseline !important; width: auto !important; text-decoration: underline !important; background-position: initial initial !important; background-repeat: initial initial !important;">slotarrow-10x10.png.
If that still doesn't work, try a cold reset with the card installed (hold down the green button as you power on, in 5-10 seconds the display will flash cold reset and you can let go and see if the printer comes to ready) Good luck! :)
May 25, 2012 | HP LaserJet 8150 Printer
My olympus cann't read my xd card; it only displays "clean card" or "format" on it. notes on screen: clean the terminal of the xD card with the dry cloth. Options are: xD...
Get an inexpensive card reader and use it to download your pics to your computer. Then, format the card in the camera to erase and initialize it. It should work properly then and your pics will be safely stored on your computer. typrice_129.jpg
Feb 15, 2011 | Cameras
When new Compact Flash Card installed in Fuji S7000 display says "Card not initialized" How do I initialize card/
Go into the menu and find "format" (or it may be called "initialize")...follow the on-screen instructions.
Sep 27, 2010 | Fuji FinePix S7000 Digital Camera
Display reads "card slot not initialized"
Turn the printer on.
2 As the printer performs its power-on sequence, press and hold the PAUSE/RESUME (HP Color
LaserJet 4600 models) or MENU (HP Color LaserJet 4610n and 4650 models) button until all
three lights on the control panel are lit.
3 Press . The message INITIALIZE DISK appears on the control-panel display.
4 Press The printer initializes the hard disk and continues its power-on sequence.
Feb 26, 2009 | HP LaserJet 4650n Printer
Card Not Initialized Error
Get the photos you want to keep off the card, and reformat it in the camera. Just deleting pics won't help. More than likely corrupted memory, and needs reformatting, Has worked for me several times.
Mar 13, 2008 | Fuji FinePix 6800 Zoom Digital Camera
Memory Card
Format the card in the Camera- read your manual
Jul 31, 2007 | Fuji FinePix A500 Digital Camera
Fuji FinePix S5200 / S5600 Digital Camera Logo
147 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
