Question about LG Washing Machines
Istarted a load ,little water came in and it stoped .the not was overload moter
    Brigadier General:
  • 3,513 Answers
Please check this site in the bellow link to diagnose your problem in your washer…
http://www.washerhelp.co.uk/diy-repair-help.html
It can be the coupling broken which joins the motor to the gear box. Look and see or listen if the motor is running then if nothing else is working coupling is broke, easy to replace.
Or
May be the symptom that u described vaguely is related with lid switch malfunction. The lid switch is usually located on the right hand side under the cabinet. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the right side of the wash tub opening. Make sure the lid strike is still on the lid and intact, first. Then, check the mounting screws that hold the lid switch in place (two screws along the tub rim on the right hand side). Often all that is required is to tighten up the mounting screws and this will realign the lid switch where it can be properly activated by the lid strike. If the lid switch is broken, you can find a replacement at searspartsdirect.com. Just type in your model number and look under the "Top and Cabinet" heading for item number 11 for the lid switch and item number 20 for the lid strike (if needed).
Let us know if you want something more else please accept the solution.
Thank You for contacting Fixya.com
Posted on Jun 04, 2010
EPIC 400 tread mill starts but slows down &blows breaker moter run fine with no load belt backed off re set speed sensor changed power cord pluged .in to circit board ran fine for 2 hrs then stoped
motor brushes are bad. when they wear out, the motor loses torque and draws more amps. they can be replaced fairly easily once you get the motors out.
Oct 03, 2015 | Epic 400 Mx Treadmill
Stoped program runtime
Usually a Run-time event means you have a block of continuous data in a stream. Like a sponge overloaded with water that can not accept additional fluids. This is a coding problem with the software and activity with instruction sets. You may jsut have to start over with the task at hand and see if you can overcome the problem. Try a second time.
Jan 05, 2015 | Roxio Easy Media Creator 10 Suite
No seems to be getting in, wash comes out damp n dirty
Is this a new washer or has there been a change in it's functionality?
Front loading washers do use very little water. One must be careful not overload them and also to be sure to use the detergent that is made for them. Can you see the clothes and water sloshing around? Try a small load with HE detergent and make sure to use the very small amount recommended and let me know if you still have a problem.
May 07, 2014 | Frigidaire ATF6000ES Front Load Washer
Moter seems hot,freezer also makes a loud clicking sound every 30 secound
The clicking noise is the overload and relay trying to start the compressor. If you continue to let it click it will eventually break your compressor. Replace the over load and relay.
Dec 28, 2011 | Freezers
Model # LAT9757AAE - Washer fills with water and then everything stops. It will not wash, spin or empty.
it can be two things 1 the presure switch is faulty and is stoping the cycle
two the moter has gone check the brushes and wiring for breaks MAKE SURE U PULL THE PLUG FIRST
Jul 28, 2009 | Washing Machines
My washer won't spin out the water in the spin cycle.
first off lighten the load.take wet laundry to a laudry mat complete the cleaning process then call a apliance repair technitian at your local apliance repair shop. give them the make and model of your machine most likely with the water your elcctric moter is in need of a little r&r
Jun 22, 2009 | Washing Machines
Washer stoped spinning
It is a 4 out of 10 on the repair scale.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 29, 2009 | Kenmore HE2 Plus Front Load Washer
I was kneading dought with my professional 600 and it stoped all of a sudden...there is a smell from the moter
when the kitchenaid overheats when mixing dough many times its just the thermister that has blown. This part is available from radio shack for about$1. 125v 135-150 degrees. just repace it and you may be in luck. the thermister acts as an overload fuse when the motor get bogged down and overheats instead of the motor blowing the thermister blows to protect the motor.
Dec 05, 2008 | KitchenAid KP2671 Professional 6 Series...
Washing Machines Logo
14 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
