Ac not working
Lost power today, when power came back, the outide compressor didnt work. (Gibson) Electric company came out to check electric, we have full 240 volts. he checked the fuses in the disconnect and they are good. I reset the thermostat and the compressor started to make a buzzing sound, but the fan on the condensor unit did not come on. I have shut off power to the unit. Help
    Guru:
  • 587 Answers
The buzzing sound, along with the fan motor not running, usually indicates low voltage to the contactor and the contactor is not engaging or closing the points and it usually buzzes when this happens.
You first need to check and see if you are getting 24 volts to the contactor coil. You should at least have 21 volts, if not check for loose or dirty connections, if none, check the voltage at the transformer to see if you're getting 24 volts there.
Posted on Jun 04, 2010
I have a Arctic King through wall AC model MWW-12ERN1-MI0 and the compressor will not engage to cool the air. Can anyone help me diagnose and fix this problem?
On the ac unit electric section, check for power at Y1, should have power, possibly to x or c ( common terminal).
Check for power across the compressor contactor, should have power or something is open such as a pressure switch or compressor protection. If there is control power at compressor contactor solenoid ( 24 volts control), then check for supply power on line side of contactor, then on load side of contactor (supply voltage e. g. 230 volts. If all voltages are present, then check the compressor for opens and electric continuity.
CAUTION: electricity is dangerous, can kill and/ or cause fires. Do not attempt if not aware of safety procedures.
Aug 08, 2017 | Heating & Cooling
Dometic AC B59516.711 15,000 BTU, while on generator power the AC works during day while it hot but once the sunsets and it cools down, compressor kicks on it drags the gen down and shuts it off.
something else besides the ac is stopping ( overloading) the genset
if it works well during the day, the compressor has to be working so the ac is not the problem
a 4000 watt gen set has a duty cycle load of around 3000 watts full time so any additional power requirement besides the ac will overload it
electric stoves , microwave ovens , hot water elements , anything that consumes power after dark will when combined with the ac will overload and shut down the gen-set
Jun 26, 2017 | Electrical Supplies
Lights are blinking
What is the make / model of your air conditioner. With out that information i cant help you with your ac repair problem. If you need any other AC Advice. Check us out online. WPB AC Repair Company .
May 14, 2016 | Heating & Cooling
IS CHEAPEST GUITARS THAT SELLS GIBSON A LIGETIMATE COMPANY?
GIbson does make a Hummingbird Pro Acoustic Electric. It lists for over $3K but can be readily found just over $2K new. You should be able to look at the markings on the guitar and do a little sleuthing to attempt to confirm validity. They are copies on the market. You need to tell us more about "Cheapest Guitars" if you want us to comment on their business practices - what city are they in?
Nov 29, 2014 | Gibson Hummingbird Pro Acoustic-Electric...
Ac problem
jump the low or high pressure switchs this switchs are located on the a/c lines of tje compresor not run check power to the compresor if you have power maybe the compressor is gone check the a/c control pannel to and take a second opinion before expend money
Aug 04, 2012 | 2006 Kia Sedona
2001 Dodge Stratus AC goes on and off?
Check the fuse for a/c compressor make sure it is completely pushed in slot then check wiring going to the high and low pressure switchs also if you have electric fans on radiator make sure it comes on when you turn on the a/c that would most likely be the cause of intermittent a/c issue also check plug on compressor if it was a lack of freon it wouldn't work at all
Jul 14, 2017 | 2001 Dodge Stratus
Ac blow hot air.has been recharged
First you need to check if the compressor is actually kicking in when started and you can do that by looking at it and you will see if it is working or not. If not working you ned to check the folowing : 1- AC compressor is getting electric , if not check the relay for the AS compressor. 2- Check if the AC compressor's clutch is kicking in (that is the part that is located on the front of the compressor , where the belt is fitted) 3- Check the compression of the AC compressor via a proffessional.
Jul 18, 2009 | 2000 Jaguar S-Type
The air on my 1998 chevy suburban blows but it doesn't get cold. I put free-on in it. It only took a little. The compressor will turn manually & will not kick on. fuse ok. electricity in harness ok....
Probably the electric clutch of the compressor is not working. This is the part that uses the power generated from the drive belt to drive the compressor. Normally if this is working, you would hear a sound in the engine compartment once you turn on the ac. Otherwise you may have only the AC blower spinning. If they check out OK, the thermostat may not be working. Your AC will not engage because it may be getting the wrong signal thermostat.
Jun 15, 2009 | 1998 Chevrolet Suburban
Top oven appears to have no power going to it.
Contact an electrician and or the power company.
I believe you have lost the neutral/ground in your power service.
Feb 21, 2009 | Maytag CWE5800A Electric Double Oven
Heating & Cooling Logo
97 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
