Hdd maxtor thanks for the help but not sure that will work its for a specific type of maxtor hard drive are there programs like this for my type
    Scholar:
  • 50 Answers
Sorry about that last link. Go here..
http://www.maxtor-hdd.narod.ru/
Navigate to the larger chart in this page, and select the third link on the list. If you read across, it identifies itself as the hard drive you mentioned - Calypso family, 80GB.
That will get you what you need.
Posted on Apr 09, 2008
HDD NOT WORKING PERFECTLY
I'm confused. Is the maxtor drive 250GB? Have you partition it to 30GB? Or is it that the computer only reads 30GB instead of 250GB? Does this drive have Windows on it? Also you might want to check your BIOS (Motherboard input/output system) by pressing Del key or F12 and see if this drive is the startup Drive. If you don't have Windows on this drive, make sure it is NOT the startup drive. Hope this helps.
Dec 09, 2013 | Maxtor Hard Drive
I wish to upgrade my Maxtor 32049H2 HDD (20gb) to a Maxtor DiamondMax 10 6B300S0 (300gb) HDD, The KM400-M2-3.0 Motherbourd specs indicate that the HDD is compatable other than the cabling to the Newer...
The new HDD uses a SATA data interface as well as a SATA power interface. You will need a SATA cable as well as a power supply that supports the SATA power connectors. Since this is an older machine you will probably need to buy a SATA cable and a Molex to SATA power connector. This should cover any cabling issues that you are having.
May 05, 2011 | EliteGroup KM400-M2 Motherboard
Hdd c: problem
Quick format only marks the disc as empty.
Try performing a CHKDSK /F /X /R C:
also do a full format next time, you may want to replace the hard drive, or you could try a program like HDD REGENERATOR or SPINRITE to fix it. These programs may not fix the hard drive as if it is too damaged but they may help in some problems.
Dec 28, 2008 | Maxtor Hard Drive
Maxtor External Hard Drive Unrecognizable, Makes Beeping, Grinding Sounds
I experienced this when I plugged it on a USB socket that has low power..
Aug 29, 2008 | Maxtor / DiamondMax 10 / 80GB / 7200 / 8MB...
Maxtor diamondmax plus 9 6y080l0
If you have you primary HDD set on Cable select, and the secondary HDD is set on anything other then Cable select (with the jumper settings on the back of the HDD) then there will be an error.. Also, if you primary is set to master/slave and the same for the secondary, it will cause problems.
Another thought, if one of your drives is SATA and the other IDE, if the IDE is set to master, there may be an issue as SATA HDD's will try to post as the master drive
Mar 24, 2008 | Maxtor Hard Drive
Hard Drive Problems
I suspect that the ribbon cable (seatbelt looking cable) in the computer has possibly come loose. Especially if both HDD's can't be seen.
Possible too that the CMOS has lost the specifications of the HDDs. Press F2 or DEL key while booting (depends on the CMOS/computer type).
Or, both hard drives have gone bad, which is unlikely that both at the same time went out.
Please rate FixYa! or clarify with more information or testing results.
Dec 15, 2007 | HP Compaq Presario SR1265CL-B...
Maxtor 160 hdd
What do you need to do with it? I am not sure you have a proplem.
Nov 24, 2007 | Maxtor Hard Drive
The noise on hard disck
the drive is starting to fail. back up your data & star getting prices on a replacement drive. you can go to maxtor.com & download a promram called powermax. it is a dos based program that is made by maxtor to test there drives. it usually needs a floppy disk. there is no repair for this type of fault in a drive. but powermax may give you a little more info. on you drive. good luck
Feb 28, 2007 | Maxtor 6Y080P0 80GB Ultra ATA133 7200rpm...
Computers & Internet Logo
81 people viewed this question
David Payne
David Payne
