Question about Refrigerators
Occassional dripping from slots at top of interior of refrigerator. slots are part of mechanism to set freezer temp
  • Refrigerators Master
  • 43,501 Answers
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
Water Running in Refrigerator from Freezeroccassional dripping from slots at top of interior - 2_bing.gif
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Posted on Jun 04, 2010
Frigidaire frig. model#FGHC2331PF7 is dripping onto top shelf and the filter has ice cycles and what temp should freezer and frig be
If it's brand new and leaking, call the place you bought it from and have them fix it. As for the temp settings; there is a center default in the freezer and you should start there, the fridge also has a default which should be OK. If you need it colder turn it up in small increments and give it a day before you make any additional adjustments. The "cold" in a fridge or freezer also depends on how much stuff you have in the unit, and how often you have the door open.
Sep 08, 2014 | Refrigerators
Water dripping from top rear center of refer section. icing up and dripping, about a cup a day. seems unrelated to icemaker operations or humidity. What direction do numbers mean when setting temp for...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 26, 2010 | KitchenAid Refrigerators
GE Profile PSS26PSTA SS freezer problem
Forget the warranty - it is only for the compressor and that is usually five years. Did you check for freezer temp - wet cubes indicates too warm up there. Water dispenser lines may be clogged.
If low temps you may have low refrigerant or a defrost mechanism not working - if not working there should be ice buildup on line entering the evaporator in back of compartment.
Jun 16, 2017 | GE Profile PSS26NGS Side by Side...
Bottom freezer - Refrigerator top not cooling- All vents from freezer open , no food in the way. Is there a fan ?
Yes there is and it is located in the base panel of the fridge. Look for a set of slotted vents in the inside of the fridge and the fan is located behind those slots. This fan uses the freezer temp to control the fridge temp.
Good luck hope this helped you some
Dave
Jan 29, 2010 | Maytag MBR2256KES / MBL2256KES
Freezer is ice cold, but bottom isn't cold at all.
your fan motor that transfers cooling from the freezer to the fridge has gone out. What this fan does is maintain the temp of the fridge that you have set by pulling air from the freezer to meet the temp. To find this fan you need to look at the temp adjustment switch on the inside of your fridge. This will be located in a plastic tray assembly with vent slots cut into it. Right behind those vent slots lays the motor. Easy to remove take model and serial # to an appliance parts house for replacement.
Good luck hoped I helped you some
Dave
Jan 23, 2010 | Whirlpool ER6AHKXPQ Top Freezer...
Refrigerators Logo
27 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
