Question about Cyber Acoustics CA3602 2 Speakers
Sound not working from speakers
I have put all the connections in the right order, plugged it in, and I know my power source is fine. I tested it with my MP3 player as suggested, and still no sound. Help!
4 Suggested Answers
madansakre
  • 51 Answers
SOURCE: logitech Z-2300 computer speakers
Please recheck the connection of subwoffer once again..
thankyou...
Posted on Jan 04, 2008
  • 619 Answers
SOURCE: Speaker has sound when powered .
Hi , open the control panel /select to classic view,select add hardware to locate some drivers cyber acoustics speaker just follow the instruction to connect the speaker.
check also the device maneger the connection of the device.
Posted on Jan 12, 2008
RyanFanMan
  • 342 Answers
SOURCE: Connected new CA-2014 speakers to
you may need to check the sound card on your system if it is not showing up then you may need a new driver, or the volume is on mute
Posted on Mar 20, 2011
Headphone jack on my compaq presariocq62 is not working
hi
maybe you have loss in jack connection otherwise check sound setting in volume bar right corner of desktop
Dec 04, 2012 | Compaq Presario 700 470024-192 Notebook
DVDRHD400F tuner has no sound.
First of all check all your audio connections make sure the output o of the receiver goes to the input of your tv.
Keep me posted.
Thanks,
Lee
Jul 19, 2008 | Wharfedale DVD-M3 DVD Player
Hello, I just bought a BEHRINGER MS40 from an authorized dealer "SENIA" from Romania, I'm from Romania by the way, the woofer speaker from the right side is making noises when the frequency is...
Have you connected the Left speaker to the right speaker using the supplied cable? If not, connect the cable to the socket on the back of the right speaker labelled "to left speaker" and on the left speaker, to the socket labelled "from right speaker"
If this still doesn't solve the problem, try swapping the input cables (put the white plug in the red socket and vice versa) to see if this makes the left speaker produce sound, if it does, check the connection at the source to check the plug(s) are in all the way. If there is still no sound in the left speaker, unplug everything and do the following:
connect the left and right speakers with the supplied phono lead (Probably black) between sockets labelled "to left speaker" and "from right speaker"
then connect the source to any of the inputs on the back of the right speaker (ensure if using the red and white phono inputs that both are connected)
finally plug in power source.
Hope this helps
May 04, 2011 | Behringer Ms40 Digital Monitor 40watts
Speakers have no sound
Please check the below mentioned things :
Verify the AC power cord is plugged into the wall outlet. Turn the VOLUME knob on the right speaker until you hear a click sound. An LED will light next to the knob when the power is ON. Turn the VOLUME knob clockwise to raise the volume. Check volume level on the computer sound card or alternate audio source device, and set at mid-level. Check plug connections on the audio source. Make sure the signal cables are inserted firmly into the correct jacks. Make sure the 3.5mm stereo cable is connected and fully inserted into the "line-out," "audio-out," or the headphone jack of the audio source. Test the speakers on another audio device. Remove the 3.5mm stereo cable from the audio source device and connect it to "line-out," "audio-out," or the headphone jack of another audio source.
And if in in case u r unable to get it working ..
Replace the speakers ..
Jan 24, 2011 | Altec Lansing VS2120 Computer Speakers
No Sound At all from the Speakers. I have plugged and replugged in the connections. I am getting power but absolutely nothing out of the speakers. Some minor static if I wiggle the power cord,...
no sound at all it was working fine before i got additional speakers creative sarrounding withe 2 mini and 1 sub buffer how to test it its just not comming on now
Jan 03, 2011 | Bose Companion 3 Computer Speakers
How do you install it correct
the audio source's output should connect to the inputs of the TS-WX11. caution on power supply connection: don't reverse the polarity of the positive and the negative wires.
Remember also to set your HU's output in order for it to work. If it does not work yet please give the details on your HU and other devices being used.
Aug 10, 2009 | Car Audio & Video
Creative Inspire T6100 5.1 - No Power
Turn the volume on the right speaker up?
Sep 27, 2008 | Audio Players & Recorders
Cant connect rear speakers
Hey there Subaquakid, the nature of surround systems is to identify separate extra channels of information and send them to the right address, being the selected speaker. In order for the rear speakers to work they need to be sent a signal. The media which you are using may not have the rear channel encoded. therefore the rear speakers have nothing to announce. Please ensure your source cd has the suround feature encoded. Hope this helps. Good Luck!
Jan 28, 2008 | Dell WL6000 Computer Speakers
Cyber Acoustics CA3602 2 Speakers Logo
35 people viewed this question
Top Cyber Acoustics Audio Players & Recorders Experts
mukhtar21 shaikh
mukhtar21 shaikh
Carlos L. Burgos
Carlos L. Burgos
Are you a Cyber Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
