Question about Linksys WUSB54GC 802.11g/b Wireless Adapter
The adapter overheats, and stops working. I have
The adapter overheats, and stops working. I have two of these, and the other one doesnt get hot, and works normally. any easy fix for this?
    Guru:
  • 868 Answers
Yup possible Lemon on the adaptor that Overheats replace it, Possible it may be hazardous if you use it, replace it just for you safety ^_^
one thing I can say is you cay ty replacing the power cord to check if there will be changes if not reycle it propely thanks ^_^
Posted on Jun 04, 2010
Testimonial: "thanks alot. I thought of the same thing, just after posting. The usb cable is quite long, and so I pulled it and replaced with shorter cord. could that have done it as well? Thanks again..."
Heater doesnt work
To troubleshoot this types of problem,click the link below :---
Car heater blowing warm, but not hot air?http://schematicsdiagram.blogspot.com/2011/12/car-heater-blowing-warm-but-not-hot-air.html
Engine Overheats and heater blowing cold?
http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
Heat blows cold on drivers side and hot on passenger side?
http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html
No heat on car? http://technoanswers.blogspot.in/2012/02/no-heat-on-oldsmobile-silhouette.html
Heater blows intermittently and temp gauge goes erratic?
http://technoanswers.blogspot.com/2012/01/heater-blows-intermittently-and-temp.html
Heater blows cold?
http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
Heater/AC blower motor not working?
http://technoanswers.blogspot.in/2012/02/heaterac-blower-motor-not-working-on.html
A/C, heater, defroster fan, not working? http://technoanswers.blogspot.in/2012/02/ac-heater-defroster-fan-not-working.html Heater problem?
http://technoanswers.blogspot.in/2012/02/heater-problem-on-isuzu-trooper.html
This will help.Thanks.
Mar 27, 2012 | 1994 Volvo 960
I have a 2004 Dodge Stratus, the car could be cold and the temp reads right in the middle and the fan is on. When I drive it, the temp gauge goes to hot and the temp light goes on. Radiator is full,...
For car running hot and overheating issues, I suggest to you go through this help links. Click this link below and go through the troubleshooting procedure to take care of the problems: ----Car runs hot? http://howtobyme.blogspot.com/2011/11/car-runs-hot-in-traffic.html
-----------All types of car overheating problems and troubleshooting?
http://technoanswers.blogspot.com/2011/11/all-types-of-car-overheating-problems.html
Car freeze overnight and started overheating while driving?http://technoanswers.blogspot.com/2012/01/car-freeze-overnight-and-started.html-----------Engine Overheats and heater blowing cold?
Car overheats and Air blows hot at idle?
http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
--------overheating? http://schematicsdiagram.blogspot.com/2011/12/buick-century-overheating.html
----------Car engine Overheats and transmission starts slipping?http://schematicsdiagram.blogspot.com/2011/12/car-engine-overheats-and-transmission.html
----------This details will help.Thanks.
Feb 10, 2012 | 2002 Dodge Intrepid
@runs hot motor feels slow doesnt hit hard
Bosch brute is made to work all day every day and will continue to do so if it is not over or under powered and properly lubed. If not powered correctly, motor will not turn at full rpm, get very hot and burn brushes to point that auto stop feature will stop motor (brush will push away from armature, or burn switch). The hammer will overheat if too long or wrong gauge of cord is used. Also if run on generator with voltage /cycles incorrect. Under normal use, motor will not get very hot. Another problem with overheating is that the grease will melt out of range to do any proper lubrication. If you are sure that it is getting proper voltage /amps then may need lubrication or bearing work. Remove bearing cover and turn armature by hand. It should be easy to turn. If stiff, suspect bearing/grease. With amp meter connected, check amp draw and compare to rated amps.
Mar 26, 2011 | Bosch Brute Breaker Hammer 11304
Car overheats. didn'T THINK FAN WAS WORKING BUT WHEN YOU TURN ON THE AIR CONDITIONING THE FAN WORKS.
You will need to see if the fan operates when overheating, there are diffrent sensors for the cooling and ac cooling, the good thing is that the fan works, this would tell me it may be a bad coolant temp sensor or thermostat, you will need to let it run and as the gauge passes the middle point feel to see if both upper and lower rad hoses are hot, if only one is hot then you may have a bad thermostat, is they are both hot and fan doesnt turn on and car overheats then you should replace the coolant temp sensor, stat with these tests and see the result, hope this helps.
Nov 04, 2010 | 1994 Ford Taurus
The Ac power supply on the motherboard gets hot and stops allowing the AC power to generate power and switches to battery and eats the battery power really fast. then won't charge until PC is completely...
So the DC jack on the motherboard is Heating Up? I'm assuming the AC Adapter (charger cord) is also HOT...??
Here's what your issue is:
1. You're using the wrong volt/amp Adapter..(charger) For Example.. Your Laptop needs a 19.5v Adapter and you are using an 18.5v
2. You're using a "generic" AC Adapter and Not an OEM one.. the generic adapters will overheat and sometimes even melt due to Cheap capacitors/resistors being used..
3. You need to clean your Fan/Heatsink.. Clean the heatsink cooling fins to free blockage and stop overheating issue..
Or .... 4. Possible faulty battery
Nov 16, 2009 | Toshiba Satellite A75-S211 Notebook
Compaq V2000 overheats at power-in plug.
Sounds like the power jack has a short and needs to be replaced.If it melted the ac adapter tip then its a ground problem in the power jack or where it connects to the mother board.
Aug 11, 2009 | Compaq Presario Notebook
I replaced the blower motor resistor to fix the
Did you inspect the connector on the harness side and resister side.. They can overheat and melt,
Jul 30, 2009 | 2002 Dodge Stratus
My dryers works when cold but stops working after it heats up.
does everything shut off or just heat if its just heat but motor works and drum is turning than-quickest sulotion would be cleaning the vents from the dryer and out through the wall or window whereever your vent goes. the reason it turns off is because it has a limit thermostat that turns off at about 150 degrees so when the vents are clogged the hot air cant escape anywhere so it stays in dryer and overheats quickly take off the vent in the back than turn on your dryer if it doesnt turn off clean your vents
if everything stops working than you most likely have a bad motor
good luck  feel free to reply with any questions
Jun 09, 2009 | Dryers
Car doesnt start
check your map sensor
May 02, 2009 | 1992 Honda Prelude
Linksys WUSB54GC 802.11g/b Wireless Adapter Logo
250 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
