Question about HP Compaq dc5100 PC Desktop
Dual Monitors I would like to run dual monitors on my computer at work. What is the cheapest video card I can get to have this option available? Current System Windows XP Pro SP2 Pent 4 3.00GHz 1 MB Ram Current Vid Card appears to be: Intel (R) 82915G/GV/910GL Express Chipset Family Thanks, Chris
    Genius:
  • 1,027 Answers
The intel 910gl chipset allows for dual monitor display.
The cheapest configuration for a work platform would be to use a splitter cable off the VGA.
LINK
Page 10 describes the setup.
Link for cable.
Posted on Apr 09, 2008
  • 385 Answers
This is a rather cheap one : MSI NX7600GS 256 MB Video Card
You can get it from Superwarehouse online at:
http://www.superwarehouse.com/MSI_NX7600GS_256_MB_Video_Card/NX7600GS-T2D256EH/p/1494596
Thanks,
Lolita
You can use two cheap cards on the machine .You don't have to get one card that runs two monitors. That is expensive.
Nov 03, 2015 | Option Computers & Internet
I have a Dell Dimension 2400 that I am running dual monitors on. I recently upgraded to Windows 7 professional from Windows XP and now I can't get both monitors to run at the same time. I have a Nvdia...
You should have 2 video ports on the 8400 GS card. One is the standard 15 pin VGA port and the other is the DVI port. You should be able to use these ports on the card to connect dual monitors. If you use the video port integrated on the motherboard you will bypass the 8400 GS card. Here's a link from Microsoft about running dual displays:
http://www.microsoft.com/athome/organization/twomonitors.aspx
The other issue is whether your monitors are DVI compatible.
Feb 10, 2011 | Dell Dimension 2400 PC Desktop
Need to connect 3 monitors. Want to use either a Nvidia 290 or ATI Radeon 9250 plus the VGA port. Installing the dual-video card disables the VGA port, cannot get it back. Help!!!
Use your AGP dual-video card for two and using a PCI VGA card for the third. It is best if the same manufacturer video driver is used for both cards, as two different ones could be problematic.
Jun 25, 2010 | HP Compaq Business dc7600 PC Desktop
INstalled video card to D945 Intel board, and now the onboard video does not work. I wish to run 2 monitors with same input.
Unfortunately most basic motherboard chipsets do not support multiple monitor setups.
They are designed to become inactive when you connect a slot based video card.
to use 2 monitors you would need to connect them both to the card in the slot if it supports dual monitors.
Mar 03, 2010 | Computers & Internet
Will a dell dimension 2100 support dual monitors
Yes it will but that will also depend on your graphics card to a degree.
To do it properly you need to install a new graphics card and disable the on-board graphics card from the bios.
Your new card should support std VGA as well as DVI
DVI is also capable of being hooked up to many large screen tvs
Aug 20, 2009 | Dell Computers & Internet
No display on Windows Vista need driver?
Make sure that the settings in the new video card are actually set to run both monitors.I see this happen in my comp. repair shop quite often. It is a common mistake.
May 04, 2009 | Dell 1703FPT 17-inch Flat Panel Monitor
I want to run 3 monitors on my dell vostro
Couple of points I’d like to mention. Vostro has two models slim and mini tower. Both of them are mostly similar so this should be applicable for whichever you have.
The default graphics card on the computer is integrated on the motherboard. When you add another video card, say to the PCI-Express 16x slot on the motherboard, this disables the integrated video card.
If the 2 monitors are connected to the video card, both would get display.
When the computer is turned ON, if you plug in the 3rd monitor to the integrated video card, you would not get any display on the 3rd monitor. BUT if you restart the computer with the 3rd monitor plugged in, the computer would give a signal to the 3rd monitor and disable the two monitors connected to the video card. This feature is added on purpose to diagnose any possible video card problems. Eg. Assuming there was a problem with the video card, if this feature were not available you would not get any display on the monitor from any of the ports and you would not be able to diagnose if the problem was with the monitor, integrated video or the video card.
Hope this helps. Please rate your feedback!
Thanks,
VJ
Mar 04, 2009 | Dell Vostro 200 Desktop Computer
Dual monitor, Intel 82915G & nVidia RIVA TNT2 64, FC6, Dell Gx520
Here is a little guide for setting up dual monitors with fedora core 6: http://blog.taragana.com/index.php/archive/how-to-setup-dual-monitors-on-linux-fedora-core/
I haven't had to use duals monitors with Linux yet but if this doesn't work let me know and I'll run some tests as I can easily set this up at work (we use the same computers and similar cards).
Jan 12, 2009 | Dell OptiPlex GX280 PC Desktop
Dual monitors
You'll need a dual-monitor video card in your computer. The GVLM1928 is basically two monitors on a shared stand. Each side of the monitor has a separate video connection.
Feb 26, 2008 | Computers & Internet
Switch to alternate 2 computers and dual monitors
What you probably want is a KVM (Keyboard, Video, Mouse) switch that supports dual monitors. It's a simple device that allows you to plug multiple computers into one set of monitors, keyboard, and mouse and switch between controlling them.
I don't know of any that support mixing analog and digital connections for the monitors, but using a VGA to DVI adapter for one of the monitors should solve that problem cheaply.
Dec 14, 2007 | Computers & Internet
HP Compaq dc5100 PC Desktop Logo
463 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
