Question about Motorola Mobility RAZR V3
I had a Motorla RAZR V3 phone (AT&T service) where the charging port broke so the battery could not be recharged. I took it to a battery specialist who charged it outside the phone and bought a new phone. On my old phone, I had about 200+ text messages in the inbox, all LOCKED so I would not delete them by accident. They are now gone. They are not on the sim card that moved to the new phone and they cannot be gotten off the old phone, with a recharged battery, even when I put the original sim card back into it. Is there anyway to access them. AT&T says this is a problem with the RAZR3 and said Motorola does not have software to get them back for privacy reasons. I don't understand how LOCKED messages could go away, Some of these are very personal, like the last message I got from my deceased father. I can't believe Motorola would make, and AT&T would sell, something like this without warning that you can't count on these things being saved, even when you have taken the time to LOCK them. Suggestions, including paying for service or software, are welcome. Thanks.
  • 12,061 Answers
I am very sorry but what you have been told is indeed true. You see, the phone stores the data in an encoded form in NVRAM, now this data. is inside the actual Phone, NOT on the SIM card, as such, if you cannot access the Phones, internal memory, then there is no way to communicate with "it" to access the data area. it is just that simple. Even if you were to be able to repair the internals of the phone, that still would not allow you to access the data as it has most likely been erased as the machine goes to preinitialize. Then it will simply flush the memory to set it up again.However IF it is still there maybe you can access the data and download it and try to encode it.
If you haven't doesn't anything to the phone, and you can access your phone with USB cable or bluetooth, then using "Hacking" software you may be able to access the information, however it will not be in "English" it will be in "Code" and as such, there is your problem, as you cannot "Decode" this without special software, and that according to Motorola, there is none. but please try these hacking links.
Have a look at these hacking sites below they may offer some help. www.hackthev3.com/
it.toolbox.com/.../how-to-hack-modify-your-motorola-razr-12749
Below is the Google link to the hacking software copy past to the address bar, and there will be many many site to investigate. http://www.google.co.nz/search?num=100&hl=en&&sa=X&ei=d3oITL-5DZi8M9SP0LUE&ved=0CBkQvwUoAQ&q=motorola+hacking+software&spell=1
Posted on Jun 04, 2010
  • marcusp844 Jun 04, 2010
    Thanks, I will try the hacking software.
    I sort of understand that, when the phone lost power and reinitialized, that could delete messages, though that sounds a lot more like a bug than a feature.
    But, if the messages were locked, why doesn't that override the reintialization/deletion? Or, put another way, what does "locked" mean if it doesn't mean "don't delete?"
    Thanks.
PC SUITE
I googled "motorola razr usb driver" and the first hit was this blog which has zip files and instructions for V3, V3c and V3m drivers.
Works great for me!
If the link doesn't work for you, just use this URL:
http://blog.gruby.com/2006/11/27/charging-a-motorola-razr-over-usb/
Jun 06, 2010 | Motorola Mobility RAZR V3m Cellular Phone
V3 not charing
Try a known good charger and battery. If it still doesnt charge then its your charging port on the phone itself. If its ever been snagged while plugged in, high chances are that its the port itself and the best bet is to sell the phone on ebay and get another razr. Theyre fairly cheap now and plentiful. :)
Jan 18, 2010 | Motorola Mobility RAZR V3
I have the same problem but I can't enter the debug menu using
I have a Motorola RAZR V3x which has worked reliably for about 3 years. Very recently (having been recharged a couple of hours earlier & without any prior suggestion of impending battery failure), the phone has refused to turn on and attempts to charge it with the factory charger do not even light the blue charge indicator. An attempt to charge it through the computer's USB port lit the blue charge indicator for about 1 second but also failed to charge the battery.
Aug 19, 2009 | Motorola Mobility RAZR V3
Motorola RAZR V3M phone won't recharge
first check the charger it must be faulty or if the charger is fine then u need to replace the charging connector
Aug 17, 2009 | Motorola Mobility RAZR V3
Holding a charge
Their website says only 6 hours of talk time for that battery. Could be that's all your gonna get from it. Every phone I've ever owned has needed to be recharged every other day and sooner if it's used more.
Dec 22, 2008 | Motorola Mobility RAZR V3t Cellular Phone
My Motorola razor will only turn on.
you need to have the usb port replaced or service.
Jul 05, 2008 | Motorola Mobility RAZR V3
Invalid Battery
Totally discharging the battery is the way to go. But what you can also do to use your phone in the meantime is this. Plug your charger into the phone withOUT your battery in. It will tell you "Unable to Charge." When it says this, put the battery in. It might tell you "Invalid Battery" a couple more times, but it did eventually say "Charging Battery" for me. After that, simply turn the phone on and it will return to normal. This is when you drain the battery completely. Once I did that, I did not get the invalid battery error again.
May 14, 2008 | Motorola Mobility RAZR V3
Dead battery won't recharge
if it still new and you've still got the warranty then you should ask for replacement of the whole unit.
seems that the problem of your phone is the unit itself, the charging circuit migth have disorders/malfuntioning.
ever tried checking for the specifications and directions for charging the unit.
i greatly suggest that if you got the warranty still, have it replaced.
good day!!!
Feb 28, 2008 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
20 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
