Question about Umax Astra 2200 Flatbed Scanner
I cannot install my scan with windows xp
Can you help me install my scanner, will it run in windows xp, is it possible to install 2 windows program on a pc?
    Brigadier General:
  • 6,966 Answers
What make and model of scanner? and how will it be connected to your PC, USB or Parallel port?
Posted on Apr 10, 2008
Scanner doesnt have a driver for windows 7
This may help. Depending on your version of windows 7 you may be able to run Windows XP as a virtual machine and still user your scanner under XP Mode. You will have to install the XP driver for your scanner on the XP virtual machine running on your Windows 7 computer.
Windows 7 has several built-in tools to help with program compatibility and Windows XP programs should be installed directly on Windows 7. Windows XP Mode runs many older Windows XP productivity programs and that are not natively compatible with Windows 7, thus helping realize cost savings and reduce possible operational downtime by extending the life of existing software.
HERE is the direct link to instructions on downloading and using XP Mode on Windows 7
Jul 18, 2011 | Office Equipment & Supplies
I have a Canon 4200F scanner and recently purchased a new computer with Windows 7 that is 64 Bit. When I try to use the scanner get a message that I need a WIA driver to use this device. Can you please...
Hi bjgestel !
This means there is no more support from HP for your unit under Windows 7 but Windows has a compatible driver included in it's system ( WIA ) .
The scanner should run smooth but with some restrictive functions . Normaly , it should run without having installed the HP XP driver/ sofware . If this not your case , there is a workaround after you installed the XP driver and made sure installation was successfull . The scanner will need to run with a third party application . Download FreeKapture from
http://download.cnet.com/FreeKapture/3000-2094_4-10673689.html
Launch Freekapture , clic on Scan , select WIA-Hewlett-Packard . Your scanner will run . If you choose HP's software, program will hang .
Note : no slides or negatives scans possible in WIA mode but the rest works .
Good luck !
fanaudi .
Feb 22, 2011 | Office Equipment & Supplies
Driver for Windows 7 and HP Scanjet 4470c
Hi ,
There are no drivers running under Windows Seven for this unit.
If you have the W XP install disc , you could install a virtual version of W XP on your HDD ( http://downloads.vmware.com/d/info/desktop_downloads/vmware_player/3_0 )
You could also partition your HDD (
http://www.partitionwizard.com/free-partition-manager.html ) and install W XP on the new one .
BUT :
Here is a workaround :
Make sure driver XP ( yes , XP ) is correctly installed . Then , go to http://download.cnet.com/FreeKapture/3000-2094_4-10673689.html and install FreeKapture , it's free .
Load FreeKapture , clic on Scan and select WIA Hewlett-Packard . Scanner works fine in this mode . If you choose HP PrecisionScan Pro , program will hang .
In any case , no slides or negatives scans possible but the rest works .
Regards ,
Thank you for visiting FixYa .
Jan 20, 2011 | HP Scanjet 4470c Flatbed Scanner
Driver for 5470c scanner will not work with windows 7
Hi ,
Scanjet 5470c does'nt work under W 7 . No drivers available .
Here are a few hints :
1° hint :
Do not connect scanner .
Load XP driver ( yes , XP) , reboot , connect scanner and wait for confirmation of successfull operation .
Reboot .
Dowload and install FreeKapture ( yes , it's free ) from http://download.cnet.com/FreeKapture/3000-2094_4-10673689.html
Open Freekapture , clic on Scan and select WIA-Hewlett-Packard . Scanjet 4470c works fine in this mode but if you choose HP PrecisionScan Pro , program will hang .
2° hint :
If you have the W XP install disc , you could install a virtual version of W XP on your HDD ( http://downloads.vmware.com/d/info/desktop_downloads/vmware_player/3_0 ) You could also partition your HDD ( http://www.partitionwizard.com/free-partition-manager.html ) and install W XP on the new one . Regards .
Jan 06, 2011 | HP Scanjet 5470c Flatbed Scanner
Scanjet 4470c. Can't get it to work with Windows 7. Any ideas on a solution or is there a Windows 7 driver out there?
Hi ,
I succeeded to make my Scanjet 4470c run in WIA mode under W7 32-bit Ultimate . Should also work with W7 64-bit .
Then , download and install FreeKapture ( yes , it's free ) from here : http://download.cnet.com/FreeKapture/3000-2094_4-10673689.html
Load Freekapture , clic on Scan and select WIA-Hewlett-Packard . Scanner works fine in this mode but if you choose HP PrecisionScan Pro , program will freeze .
Regards .
Dec 13, 2010 | HP Scanjet 4470c Flatbed Scanner
Anyone found driver for WINDOWW 7 & HP scanjet 4470c yet?
The only ways to get scanner 4470c run under W7 are these 3 options :
1° solution one : make sure driver XP ( yes XP ) is correctly installed . Download and install FreeKapture from http://download.cnet.com/FreeKapture/3000-2094_4-10711598.html . Load FreeKapture , clic on Scan and select WIA-Hewlertt-Packard . Scanner will work fine in this mode but if you choose PrecisionScan Pro , program will hang .
In any case , no slides or negative scans possible but the rest works .
2° solution two : if you have XP install disc , you can install a virtual version of XP on your HDD ( http://www.vmware.com/products/player/ )
3° solution three : if you still have XP install disc , partition your HDD and install XP on the new one (http://www.partitionwizard.com/free-partition-manager.html ).
Don't wait for HP to produce compatible drivers for this unit , it's useless . Regards .
Fanaudi .
Feb 26, 2010 | HP Scanjet 4470c Flatbed Scanner
Dimage Scan Dual IV is it compatable with Windows 7 32 bit?
Right now, the Konica-Minolta site lists the scanner as discontinued and has no drivers for Windows versions later than XP. The Microsoft Compatibility site lists it as "Information Coming Soon" You can try the generic driver that Windows will try to install (check if you need TWAIN or WIA drivers) or download the current driver and try installing it with XP SP3 compatability mode (right click on the file, select Properties, then the compatability tab.
If those fail, there is another option in Win7 Pro or Ultimate. Download and install the XP mode from Microsoft (2 downloads/installs). Then install the scanner inside the virtual computer running XP that results. You may need to save images to external media to share them between the two computers.
I hope this helps.
Feb 17, 2010 | Konica Minolta Dimage Scan Dual IV Film...
Hi, HP Scanjet 2200c (Scanner) does it work for windows 7?
Hi dorine...
HP Scanjet 2200c drivers (xp/vista/win7/win8/mac) can be found at driverupdate us It will take 2 mins from you to install...
I hope I have helped you...
enjoy
Oct 07, 2009 | HP ScanJet 2200C Flatbed Scanner
Diamge Scan II, Error = 5 Windows 2000, Error = 1 on Windows XP
Before you install try this.
1. Start -> Click Run
2. Enter msconfig and click ok
3. Click Startup tab
4. Uncheck program that you don't want to startup
You can disable programs that you don't want automatically load when you start your computer. By disabling these programs will help your computer startup faster.
5. Click Ok and restart
Now you should notice that your computer startup faster.
My Hot Tips to Make Your Computer Faster:
* Regularly check your startup folder to prevent malicious programs installed itself without your knowledge.
* Delete the temporary files from Temp folder (Start > Run > %temp% > delete all files).
* Upgrade your RAM to makes your computer boot faster : )
I hope this helps you to make your computer faster..
Sep 14, 2009 | Minolta Dimage Scan Dual II Film Scanner
HP 4470c flatbed
If you can get the software onto your computer, try right clicking on the scanner program--properties--compatability tab--check "run this program in Xp compatability". Worked for me in Vista
Jul 06, 2009 | HP Scanjet 4470c Flatbed Scanner
Umax Astra 2200 Flatbed Scanner Logo
42 people viewed this question
Top Umax Office Equipment & Supplies Experts
Tony
Are you an Umax Office Equipment and Supply Expert? Answer questions, earn points and help others
