Question about Yamaha HTR-5730 Receiver
Sounds like polarity is wrong on one of the speakers?
I've tried switching the cables around, the speakers are new wharfdale speakers. Perfect sound on the right speaker and a low echoing distorted sound from the left??? Nothing wrong with cables or speakers, the problems must be the receiver.
Driving me nuts, any ideas?
//Martin
  • martin738 Jun 06, 2010
    Thank you vtargueza200, this would be the obvious problem. However it's not a question of polarity, that was the first thing i tried. It is acting like a polarity problem though that's what so weird. I beleive there's something wrong in the receiver.
    Champion:
  • 222 Answers
You have to make sure the speaker's are connected properly (positive out to positve in negative out to negative in)
Posted on Jun 06, 2010
How do I troubleshoot a "check speakers" warning when they are connected properly?
Sounds like your using the YPAO to check and setup your speakers but if the speaker in question is a bipole, dipole, oe omnipole those types of speakers will fool the YPAO and you might get a result that tells your the speaker polarity is wrong, so if you are 100% sure the wires are correct then just ignore that warning. I have Ominpole speakers myself and I always get an error telling me to switch the wires and change polarity but even if I do that I get the same error so I just have to make sure the wire are hooked up right and ignore that error
Aug 18, 2014 | Yamaha RX-V659 Receiver
Tip
Using Proper Speaker Polarity
Sound system speakers have standard polarity which is indicated either with a "+" or a "-", or with Red and Black colors near the speaker terminals. This same polarity marking is also found on the sound system amplifier section. Most speaker cable has a polarity indication; either color coded, or a physical difference in the wires. Reversed polarity results an obvious decrease in bass, and a hollow sound in the mid range frequencies. If your speaker cable has no obvious polarity indication, you can check the polarity as follows; connect a 9V battery to each speaker cable for no more than about a second; long enough to see the woofer cone move. When the + battery terminal is connected to the + speaker lead, the woofer cone will move out. When you have this situation, label the positive speaker lead, either with tape, or by tying that wire in a simple knot. Make sure both cables are checked.
on Oct 06, 2010 | Audio Players & Recorders
How do I diagnose and fix my laptop's sound problem? Should I just throw it out the window?
which operating system
You receive an error that states: There might be a problem with your audio device
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have selected the correct speaker settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place icon in taskbar for any
further volume control settings you will need to right click on the speaker volume icon system select adjust volume
click start control panel sounds and audio volume advanced speakers select the appropriate speakers
from the drop down list or navigate to the device manager scroll to system devices + to expand system
speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
hope this helps
Jun 26, 2012 | Fujitsu Siemens Amilo Pi2515 Laptop...
Hi there just bought some wharfdale monitor speakers yesterday they seemed to go good and today they are creating wierd high pitched crackly sounds without even playing anything.. can you please help?
Do you live near an airport or some other place with a lot of radio traffic? I've had a similar problems with some of my speakers because of intense radio frequencies. if the problem persists in other places that the speakers are placed, perhaps you might need to run some shielded cable to block interference.
May 13, 2011 | Wharfedale DP8.2A Diamond Pro Active...
I just replaced the wiper motor on my 98 camry, and now their working backwards. Where did i go wrong?
It sounds like the polarity might be wrong. Switch the wires around and see what you get!
May 04, 2011 | 1998 Toyota Camry
Just bought a denon, and wharfdale 9.1 speakers
this is the cable
http://en.wikipedia.org/wiki/RCA_connector
basicly a phono jack cable
very cheap in shops/ebay ect
rca stands for radio corporation of america
May 10, 2010 | Denon AVR-2105 Receiver
I installed my new speakers but can't get any sound. I have tried all usb ports and still no sound. What have I done wrong? I am not very good with PC problems.
Hi , your Speakers do not connect Via USB , They connect via a Green Input Jack on the PC...Try find that input aswell as the Green Color coded Cable from your Speakers and plug that in..
You should have perfect sound then..
Happy new year Bud ;)
Dec 30, 2009 | HP Compaq Computer Speakers
Amp playing speakers very quietly
it sounds like you have the polarity of the speakers hooked up wrong on one of them, try unhooking the new speakers you added and hook them back up one by one, when the music gets fuzzy then reverse the wires for that speaker, this should cure your problem.
Mar 07, 2009 | Kicker 06ZX750.1 Car Audio Amplifier
My tweeter in my atlantic 500 isnt working.
If you did not hear any sound from the tweeter, but you did on the new one, the old one is bad my friend. I tried to find an original replacement for you but I could not find it. I did however speak to someone on your behalf about your problem. I was informed that if you call them at 1-877-732-5374 and give them the dimensions, they can get you a nice not too pricey replacement that should sound good to you. I was told they go for about 70 to 100 bucks. Good Luck
Jun 05, 2007 | Wharfedale Atlantic 500 Main / Stereo...
Yamaha HTR-5730 Receiver Logo
89 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
