How to connect to NIB videonics boing box sound effects mixer to dj system?
gotgeek2
  • 565 Answers
SOURCE: what all can I attach a turntable ground wire to?
Connecting to another piece of equipment besides the mixer introduces the possibility of creating a ground loop, which, of course, is not desirable.
Just make a splice using Stakons (crimper). Just cut off the existing connector and crimp a (red) round crimp to the existing ground wire. Then take a length of same gauge and crimp a round a (red) spade Stakon on the other end. Then take a nut and bolt and connect the 2 round connectors and tape with good black tape (Scotch 33 or similar). That will get you through the Gig.
Posted on Feb 10, 2009
  • 44 Answers
SOURCE: I need a user manual for a Videonics MX1 digital
There is a manual in .pdf format available through the Videonics web site. I've included a direct link to the manual below. Once you get to it you can save a copy of it to your pc if you wish.
Hope it helps!
MX1 Manual
Posted on Oct 05, 2009
  • 5603 Answers
SOURCE: my effects on the behringer djx 700 dj mixer stop working how
This is a wild educated guess.
I repaired a Behringer guitar amp that had a DSP effects in it (BX1200 I believe).
The effects were on a seperate board and the board had its own 5 volt power supply. The filter capacitor for the 5 volt power on the board was UNDERSIZED and it had degraded causing the 5 volts to drop out of regulation, dipping to 4 volts. This caused the DSP effects to fail.
YOUR device MAY use the same DSP OR design.
Check the 5 volt power with an OSCILLOSCOPE to look for dips below the 5 volt operating point that occur at 120 HZ.
Posted on Oct 24, 2009
marsrover
  • 682 Answers
SOURCE: i have a dj mixer 600 and the effects went out do
1-try to reset it first-(power off -power on).
2-apply a spray contact cleaner in effect(volume or button)and move it on and off many times (or forward and backward)-you can get the cleaner from radio shack near your home.
3-if all above did not work send it to a repair center.
Posted on Nov 27, 2009
  • 135 Answers
SOURCE: Djm-909 DJ Performance Mixer with Effects System: Ch1 is really low and ch2 is really high with grou...
Unusual fault on a 909, they are usually pretty reliable.
I'd 1st check if it is correctly wired - i.e CD into "line" level input and not "phono" or vise versa.
http://stores.ebay.co.uk/methleykev
Posted on Jul 06, 2010
I cannot hook my Behringer mixer to the Pioneer EFX 500 it's not working
I presume you are using the send and return inputs on the EFX500.
Make sure the effect selector, CH Selector and EF On/off are set right. then use these in the insert chain of the mixer for the channel/bus/sub you want to use the effects on. Remember on the mixer it will be tip send and ring return. It would be useful if you said which behringer mixer (they make an awful lot of them from complex digital to simple DJ) and what you are trying to do with it.
It is clearly explained in the Pioneer manual under basic connections. If you are a DJ you may not be familiar with the Insert concept so get yourself down to a professional sound/PA outlet or Radioshack / Maplin and ask for a pair of insert leads.
May 23, 2016 | Behringer Music
My right channel upfader on my numark mixer is not working can this be fixed?
Yes take it to your local numark dealer and they will send it out or fix it right there. sounds like the faders blown.
Mar 15, 2011 | Nu Mark Numark Dxm06 DJ Mixer With 12...
Im thinking about buying a djx750 and have rokit 5 monitors. would this work? what is the best way to connect them, to have good sound? it is just for a home dj setup, all on one desk, two cd decks,...
Here is alink to the manual:http://www.behringer.com/EN/downloads/pdf/DJX750_P0956_M_EN.pdf You should have no problems hooking them up (RCA to RCA). I've been using a Behringer XenyX1222FX board in my recording system for about 4 years now and have been quite satisfied with it's reliability. Try to find a dealer who will demo the mixer for you.
Aug 24, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
May 06, 2010 | Pioneer Djm-909 DJ Performance Mixer with...
Hooking up sound system
The RSQ player goes into the input section of the mixer.
The mixer effect send goes to the Quadraverb input and the output of the Quadraverb goes back to the effect in on the mixer. Now the Main out on the mixer goes to the EQ then the EQ goes to the compressor/limitor to power amp to speakers.
Apr 02, 2009 | Stanton Sa3 DJ Mixer With Eq System
What do i need in a mixer? i want to connect my kaoss pad mini, and kaossilator, and obviously a couple of cdjs, and where do i connect them straight in the mixer or amp, im awaiting my purchase and just...
For dj use, industry standard would be something like a Pioneer DJM600 mixer. 4 channels w/ effects and a mic input. To use kaoss it's best to go into Send/Return input through the effects. By tapping on Send, all sound is sent out to the kaoss pad, and comes back into the mixer into the Return inputs. By doing this you can have the kaoss pad on sitting next to the mixer ready to apply effects all the time. Then connect the master outputs from mixer into your amp, or straight to powered speakers. Kaossilator is more of an instrument than effects unit, so plug in to channel 3 after your 2 cdjs in channel 1 and 2. You still have a spare channel left. I use 2 x 1200s and 2 x cdjs with kaoss pad through effects channel in this way. A 4 channel mixer is plenty.
Mar 25, 2009 | Korg Mini Kp Kaoss Pad
All of a sudden my Echo Indigo DJ soundcard will play both virtual CD players on my PCDJ software on one channel. For a while, I had cd 1 on one channel and cd2 on the other. I am using a pig tail plug...
I can run audio on 3 separate channels/outputs of my laptop
I use Tricerasoft Swift Elite DJ software but the areas you need to look at for troubleshooting are probably similar:
1) check the (PCDJ) software settings for selecting the channel outputs of your Indigo DJ on each deck/ player. NOTE: 1/2 and 5/6 are the same physical port (headphone port), while 3/4 and 7/8 are also shared on the Line Out port. So make sure you use for eg. one player uses 1/2, and the other player uses 3/4 ONLY IF you want them running out to separate channels on the mixer
I personally run both my decks off the same channel, ie 3/4 so that my software can do the mixing for me. My mixer only acts as an master control device where everything else connects
2) Make sure you check your IndigoDJ Console (installed to the Windows Start menu under Echo Audio, Indigo DJ), if you have any conflicts or if for some reason one particular channel pair gets inadvertently muted, resulting in no sound coming from the port.
3) I also use my onboad sound card (typically for previewing music or for an auxillary output). This is obviously controlled by the Operating system... in Windows is is through the Sound properties, default sound device. I recommend NOT using Indigo DJ as a default sound card -- but that is a personal preference.
So in this way you actually have 3 outputs for sound
As far as cabling is concerned, it depends on what you are connecting to. I use a 1/8 (mini computer) jack to 1/4 whcih then plugs into a direct box (eleminates any static hum etc), then from the DI box using an XLR cable to the mixer. Your setup may be slightly different.
Hope this helps!
Dec 01, 2008 | Echo Indigo DJ Sound Card
No output mixer settings
u need dj card hi tech stuf fnot sb lol ok go to guitar center get you self a in and out box usb midi ok has quder in in jacks for record players cd and software they make a dj labtop card also dual inputs hi tech gear not stander sb stuff ok tascam makes sum alot compains that do u wann wann run record player son to dj on with cool effects mensu ? try tractor software maby for lp and a nice in and out box ok
Jan 15, 2008 | Creative Labs Sound Blaster Live! 24-bit...
Outputting high pitched sounds and master balance switch problem
Maybe the issue is not with your mixer. Maybe its with one of the units you connect to the mixer. Does this happen in all the channels?
If the service company could not duplicate the problem, then the problem might be somewhere else. Double check and replace your cables going to your amp, as well as the cables coming from your CD players and such.
- OPTiC
DJ Equipment Repair & Service
A DJ Pro Audio Co.
Dec 06, 2007 | Pioneer DJM-600 Silver Professional DJ...
66 people viewed this question
 Grubhead
Grubhead
